Go to Post You will find that most people in good companies are real people that share the same values and concerns as all of us. - ebarker [more]
Unread 29-03-2014, 06:02
TikiTech's Avatar
TikiTech TikiTech is offline
Mr. H
FRC #3880 (Tiki Techs)
TikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really nice
Re: urget help needed with c++ code
#include "WPILib.h"
#include "Math.h"
//#include "VisionProcess.cpp"
int shot = 5;
Victor *intakeL;
Victor *intakeR;
Gyro *gyro;
Encoder *encoderL;
Encoder *encoderR;
ADXL345_I2C *accel;
//DriverStationLCD *driverStation;
DigitalInput *pressure;
Relay *presser;
Servo *cameraTilt;
Servo *cameraTurn;
AnalogChannel *armPotent;
class RobotDemo : public SimpleRobot
Talon yLeft;
Talon sLeft;
Talon yRight;
Talon sRight;
Joystick stick; // only joystick
Joystick assistick;
Jaguar armL;
Jaguar armR;
Solenoid shooterL;
Solenoid shooterR;
Relay shifter1;
Relay shifter2;
static const float Kp = 0.05;
int ang;
public:
RobotDemo():
yLeft(1),
sLeft(2),
yRight(3),
sRight(4),
stick(1), // as they are declared above.really are they ? not sure maybe.
assistick(2),
armL(5),
armR(6),
shooterL(1),
shooterR(2),
shifter1(2),
shifter2(3)
GetWatchdog().SetEnabled(false);
yLeft.SetExpiration(0.1);
sLeft.SetExpiration(0.1);
yRight.SetExpiration(0.1);
sRight.SetExpiration(0.1);
armL.SetExpiration(0.1);
armR.SetExpiration(0.1);
intakeL = new Victor(7);
intakeR = new Victor(10);
gyro = new Gyro(1);
encoderL = new Encoder(6,7);
encoderR = new Encoder(8,9);
pressure = new DigitalInput(5);
presser = new Relay(1);
cameraTilt = new Servo(9);
cameraTurn = new Servo(8);
armPotent = new AnalogChannel(2);
//driverStation = DriverStationLCD->GetInstance();
//ADXL345_I2C- = new Accelerometer(1);
* Drive left & right motors for 2 seconds then stop
void RobotInit()
//SmartDashboard::init();
encoderL->Start();
encoderR->Start();
void Autonomous()//range: 6ft-
//cout<<"in auton \n";
encoderL->Reset();
encoderR->Reset();
Wait(0.5);
int t = 0;
while((fabs(encoderL->GetRaw())<4500||fabs(encoderR->GetRaw())<4500) && t<200)
yLeft.Set(0.7);
sLeft.Set(-0.7);
yRight.Set(-0.7);
sRight.Set(0.7);
Wait(0.005);
t++;
t = 0;
while((fabs(encoderL->GetRaw())<4700||fabs(encoderR->GetRaw())<4700) && t<200)
yLeft.Set(0.4);
sLeft.Set(-0.4);
yRight.Set(-0.4);
sRight.Set(0.4);
Wait(0.005);
yLeft.Set(0.0);
sLeft.Set(0.0);
yRight.Set(0.0);
sRight.Set(0.0);
armL.Set(0.5);
armR.Set(0.5);
Wait(0.8);
armL.Set(0.0);
armR.Set(0.0);
Wait(0.2);
shooterL.Set(true);
shooterR.Set(true);
Wait(0.3);
shooterL.Set(false);
shooterR.Set(false);
Wait(0.2);
t = 0;
while((fabs(encoderL->GetRaw())>0||fabs(encoderR->GetRaw())>0) && t<150)
yLeft.Set(-0.7);
sLeft.Set(0.7);
yRight.Set(0.7);
sRight.Set(-0.7);
intakeL->Set(0.6);
intakeR->Set(-0.6);
Wait(0.005);
t++;
t = 0;
while((fabs(encoderL->GetRaw())<250||fabs(encoderR->GetRaw())<250) && t<150)
yLeft.Set(-0.5);
sLeft.Set(0.5);
yRight.Set(0.5);
sRight.Set(-0.5);
Wait(0.005);
t++;
yLeft.Set(0.0);
sLeft.Set(0.0);
yRight.Set(0.0);
sRight.Set(0.0);
Wait(1.5);
intakeL->Set(0.0);
intakeR->Set(0.0);
Wait(0.5);
t = 0;
while((fabs(encoderL->GetRaw())<2000||fabs(encoderR->GetRaw())<2000) && t<150)
yLeft.Set(0.7);
sLeft.Set(-0.7);
yRight.Set(-0.7);
sRight.Set(0.7);
Wait(0.005);
t++;
t = 0;
while((fabs(encoderL->GetRaw())<2100||fabs(encoderR->GetRaw())<2100) && t<150)
yLeft.Set(0.4);
sLeft.Set(-0.4);
yRight.Set(-0.4);
sRight.Set(0.4);
Wait(0.005);
t++;
yLeft.Set(0.0);
sLeft.Set(0.0);
yRight.Set(0.0);
sRight.Set(0.0);
Wait(0.3);
shooterL.Set(true);
shooterR.Set(true);
Wait(0.3);
//cout<< "out of auton \n";
* Runs the motors with arcade steering.
//////////DRIVESTICK CONFIG////////// ********** = TO DO //////////ASSISTICK CONFIG//////////
// Btn 1 A Button //null // Btn 1 1 Button //
// Btn 2 B Button //SHOOTER Safety Button (Both buttons // Btn 2 2 Button //
// Btn 3 X Button //null must be pressed // Btn 3 3 Button //
// Btn 4 Y Button //SHOOTER Fire Button to shoot) // Btn 4 4 Button //
// Btn 5 L Bumper //TOOL OUT/PASS ********** //
// Btn 6 R Bumper //TOOL INTAKE **********
// Btn 7 Back Btn //null
// Btn 8 Start Btn //null
// Btn 9 L Joy Click//null
// Btn 10 R Joy Click//null
// Axis 1 L X Axis //null
// Axis 2 L Y Axis //DRIVE +Forward/Reverse-
// Axis 3 + L Trigger //ARM DOWN **********
// Axis 3 - R Trigger //ARM UP **********
// Axis 4 R X Axis //STEER +Right/Left-
// Axis 5 R Y Axis //null
void OperatorControl()
//cout<<"In Operator Contrl";
//int logcounter = 200;
//int *CamTurn;
//int *CamTilt;
//bool *Pv;
int h=1;
//float *P;
int *angle;
while (IsOperatorControl())
/*if(logcounter >0)
cout<<"running userctrl \n";
logcounter--;
*angle = int(gyro->GetAngle());
if(((stick.GetRawAxis(2))>0.15 || stick.GetRawAxis(2)<(-0.15)) || ((stick.GetRawAxis(4)>0.10) || (stick.GetRawAxis(4)<-0.10)))
/*if(logcounter >0)
cout<<"running drive \n";
logcounter--;
yLeft.Set(-stick.GetRawAxis(2)+(stick.GetRawAxis(4)));
yRight.Set(stick.GetRawAxis(2)+(stick.GetRawAxis(4 )));
sLeft.Set(stick.GetRawAxis(2)-(stick.GetRawAxis(4)));
sRight.Set(-stick.GetRawAxis(2)-(stick.GetRawAxis(4)));
else if((fabs(stick.GetRawAxis(2))>0.15) && ((fabs(stick.GetRawAxis(4))<0.10)))
/*if(logcounter >0)
cout<<"running straightdrive \n";
logcounter--;
yLeft.Set(-stick.GetRawAxis(2)-(*angle*Kp));
yRight.Set(stick.GetRawAxis(2)+(*angle*Kp));
sLeft.Set(stick.GetRawAxis(2)+(*angle*Kp));
sRight.Set(-stick.GetRawAxis(2)-(*angle*Kp));
else
yLeft.Set(0);
yRight.Set(0);
sLeft.Set(0);
sRight.Set(0);
if(assistick.GetRawButton(5)) //ARM UP
//cout<<"arm up \n";
armR.Set(-0.5);
armL.Set(-0.5);
else if(assistick.GetRawButton(6)) //ARM DOWN
//cout<<"arm down \n";
armR.Set(0.5);
armL.Set(0.5);
else if(fabs(stick.GetRawAxis(3)) > 0.3 && !assistick.GetRawButton(5) && !assistick.GetRawButton(6)){
armR.Set(stick.GetRawAxis(3));
armL.Set(stick.GetRawAxis(3));
else{
armR.Set(0.0);
armL.Set(0.0);
if(!pressure->Get())
presser->Set(presser->kOn);
else if(stick.GetRawButton(1)||pressure->Get())
presser->Set(presser->kOff);
if(stick.GetRawButton(10))
shifter1.Set(shifter1.kOn);
shifter2.Set(shifter2.kOff);
Wait(0.2);
else if(stick.GetRawButton(9))
shifter1.Set(shifter1.kOff);
shifter2.Set(shifter2.kOn);
Wait(0.2);
else
if(stick.GetRawButton(4) && stick.GetRawButton(3) && !assistick.GetRawButton(2))// && stick.GetAxis(3)>0)
shooterL.Set(true);
shooterR.Set(true);
Wait(0.25);
else if(stick.GetRawButton(4) && stick.GetRawButton(3) && assistick.GetRawButton(2))// && stick.GetAxis(3)>0)
shooterL.Set(true);
shooterR.Set(true);
Wait(0.10);
else
if(stick.GetRawButton(6) || assistick.GetRawButton(7)) //TOOL INTAKE
//cout<<"intake on\n";
intakeL->Set(0.8);
intakeR->Set(-0.8);
else if((stick.GetRawButton(5) || assistick.GetRawButton(8)) && !assistick.GetRawButton(7)) //TOOL OUT/PASS
//cout<< "pass on \n";
intakeL->Set(-1.0);
intakeR->Set(1.0);
else
intakeL->Set(0);
intakeR->Set(0);
if (h%48 == 0)
//*P = armPotent->GetAverageValue();
//*Pv = presser->Get();
//*CamTilt = int(cameraTilt->Get());
//*CamTurn = int(cameraTurn->Get());
//*Pot = int(armPotent->GetValue()); *G = int(gyro->GetAngle());
//cout<<("LeftEncoder: "&& *L &&" RightEncoder: "&& *R &&" Gyro:"&& *G &&" Pressure Switch: "&& *Ps &&" Compressor: "&& *Pv);
///*cout<<("ArmPotentiometer: "); cout<<(*Pot);cout<<("\ncamTurn: ");cout<<(*CamTurn);cout<<("\nGyroscope Angle: ");cout<<(*G);cout<<"\n";
//cout<<"ArmPotent: "<<*P<<"\n";
h++;
Wait(0.03); // wait for a motor update time
//cout<< "out of usercntrl \n";
void Test() {
START_ROBOT_CLASS(RobotDemo);
Team 3880 - "Tiki Techs" "Mr. H" - Tiki Technologies Coach / Mentor
Kealakehe High School Robotics - Kailua-Kona, Hawaii
__________________________________________________ _____________________________
2016 Hopper Division | Orlando Regional Engineering Inspiration Award | Hawaii Regional Chairman's Award & Finalist & Woodie Flowers Finalist
2015 Carson Division | Silicon Valley Regional Engineering Inspiration Award | HI Regional Regional Winners & Engineering Inspiration & Deans List Finalist
2014 Newton Division | Hawaii Regional Engineering Inspiration Award & Deans List Finalist
2013 Newton Division | Inland Empire Regional Regional Chairman's & Creativity Award | Los Angles Regional Engineering Inspiration Award | | HI Regional
2012 Curie Division | Hawaii Regional Engineering Inspiration Award
2011 Newton Division | Hawaii Regional Regional Winners & Industrial Design Award
Unread 29-03-2014, 07:58
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Something in your auton code looks wrong. I'm bolding the line your should add:
yLeft.Set(0.7);
sLeft.Set(-0.7);
yRight.Set(-0.7);
sRight.Set(0.7);
Wait(0.005);
t++;
t = 0;
yLeft.Set(0.4);
sLeft.Set(-0.4);
yRight.Set(-0.4);
sRight.Set(0.4);
Wait(0.005);
t++;
Also, in OperatorControl, you're using "angle" as a pointer, which seems unnecessary and dangerous. Change " *angle " everywhere you see it to just " angle ".
I don't see anything obviously wrong with your code. I'd recommend taking out all those Wait calls in OperatorControl, because you'll lose control of the robot for the entire duration of that Wait. So if you're turning and you trigger that Wait(0.25), you'll keep turning for 0.25 sec, no matter what you do on the controls.
Generally, I'd recommend trying the robot in Practice mode, so it runs through Auton and into Teleop in the same sequence it would on the field. I'd also recommend running NetConsole while you're on the field, so you can get any debugging statements or exceptions that will tell you what's killed your robot.
Unread 29-03-2014, 11:43
TikiTech's Avatar
Mr. H
I will forward this to my student programmer. Keeping my fingers crossed.
The strange thing is that in practice mode in the pits and on the practice field we are not having any issues. It is only on the FMS that it doesn't work. the only thing that it will do is run the auto correctly and then no teleop. If the auto code is removed then we do not do anything. Looks nice sitting there though.. I am hoping it is related to the *wait command you mentioned. We will find out in 3 hours when we go back to our last day of competition.
Thank you very much for your time and suggestions.
Aloha
Unread 31-03-2014, 03:32
TikiTech's Avatar
Mr. H
Thank you for your help!!
After showing the ideas here it was decided that it was better to start from scratch. A much simpler code was written from scratch with no more waits nor improper use of *
Downloaded the code and from then on, all was well..
Except some missed possession calls in the semi finals and a replay I am still not sure why....
Aloha!
