Go to Post To me, being in FIRST is the biggest learning experience anyone can have. I want to give that experience to everyone I can, be it now or thirty years down the line. - BandChick [more]
Unread 29-03-2014, 19:46
dipmeinaluminum's Avatar
dipmeinaluminum dipmeinaluminum is offline
Michael Vilarelle Mentor
AKA: (Former Mentor 354 Westinghouse Pirates)
FRC #0333 (The Megalodons)
dipmeinaluminum is a splendid one to beholddipmeinaluminum is a splendid one to beholddipmeinaluminum is a splendid one to beholddipmeinaluminum is a splendid one to beholddipmeinaluminum is a splendid one to beholddipmeinaluminum is a splendid one to beholddipmeinaluminum is a splendid one to behold
8 volts over talons
Hi guys,
First, thank you to all of Long Island for having is this past weekend!
I'm having a weird issue, I'm using Talons to power CIM Motors for our shooter. When a button is assigned to them, the voltage reads 8Volts, when the joystick is applied I get the full volts, solid green and red lights.
After calibrations and such, I can't figure it out. Can we just not use assign buttons to talons?
We are using JAVA. Thank you in advance.
-Mike
Team#333 (2013-Present)
Team#354 (2000-2013)
https://www.youtube.com/watch?v=Bu5-NvMUQ-Y
Unread 29-03-2014, 20:36
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
Re: 8 volts over talons
Can you post the relevant part of your code?
Something like this should work:
if (joystick.getRawButton(SHOOTER_BUTTON))
    talon.set(1.0);
Sometimes a button on a joystick is read as an axis on the computer. For example, the xbox 360 controller finger triggers (bumpers or whatever they're called) actually count as axis and you'll get a variable value instead of a true/false.
Unread 29-03-2014, 20:51
TFleig78's Avatar
TFleig78 TFleig78 is offline
AKA: Tyler
FRC #0078 (Air Strike)
TFleig78 will become famous soon enoughTFleig78 will become famous soon enough
It seems like a code issue. Could you post the code? Also, are you using the command based model or the simple template?
Unread 29-03-2014, 22:45
JavaNoNothing14 JavaNoNothing14 is offline
FRC #2681
JavaNoNothing14 is an unknown quantity at this point
For the most part, when running a blank code it was essentially just a simple
if (js.getRawButton(11)){
   shooter.set(1);
After testing, it would only run at what seems to be 66% speed.
Unread 29-03-2014, 23:08
tStano tStano is offline
AKA: Sparks
Team Role: Electrical
tStano will become famous soon enough
Electrical resistance will make your voltage drop.
There is some resistance in a talon, but not that much. This particular talon could be a bad one though, with a greater resistance.
Wire has resistance as well. If you have long wire runs, the voltage could easily drop to 8v by the time it reaches the motor. This calculator shows you how severe that effect may be. http://www.calculator.net/voltage-drop-calculator.html
There could be a loose or badly terminated wire somewhere along the path. This would increase resistance, further lowering voltage.
Also, it is possible the value you get is what the current battery voltage is. These batteries don't always output 12v, but I'm sure you knew that.
It could also be that your voltmeter isn't great, or has poor connections.
If the lights on the talons are flashing as you press the button, I'd think it was code. if their not, its probably something else.
Your code looks correct, assuming it runs every loop.
Unread 29-03-2014, 23:24
TFleig78's Avatar
AKA: Tyler
You can debug by printing the values that the talons are set to.
You can do this by writing:
System.out.println(shooter.get());
Also, check the status lights on the talons.
Unread 29-03-2014, 23:28
FRC #2681
Its set to two talons, but for the sake of this i'm just writing the program as it would be if i only have one. The wire length is closer than any other motor control set up that we have.
So when I revised the program to have it read as such
if (js.getY()> 0)
shooter.set(1);
so if i move my joystick forward my shooter will go forward. When i run this program i have no problem at all, robot works fine and it reads 12+ V.
I've even switched out these talons with other talons to eliminate as much as could be and for some strange reason, being set to a button doesn't give it full speed.
Unread 29-03-2014, 23:31
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Originally Posted by JavaNoNothing14 View Post
   shooter.set(1);
First, I would personally supply "1.0" instead of "1" - I've had issues in the past (in other systems, not necessarily on an FRC system) with the conversion from int to double causing issues with stuff. This way you're supplying the double directly, instead of making the compiler convert it.
Try setting the speed to a variety of values (I would go 1.0, 0.9, 0.8, etc, all the way down to -1.0) and see what voltage you get out of the Talon for each value. Then do the same thing feeding in a joystick, printing out the joystick value as you go so you can get it at about the same values. This will let you plot two response curves, which may help us figure out what's wrong.
2016: Lake Superior WFFA
Unread 29-03-2014, 23:32
Mentor, LRI, MN RPC
if (js.getY()> 0)
shooter.set(1);
Ahh... more information, makes more thoughts... What other code do you have around this motor? I assume somewhere you're telling it to stop and/or go in reverse?
Unread 29-03-2014, 23:38
FRC #2681
I've stripped down the code, and removed it from all other variables, started a new file so all i have running is the button, and the js.getY(), (1 is being commented out when the other one is in use). And the results are still the same with the main program. It reads out 1.0 on the driver station, but shows a blinking light, and only reads ~8 volts on a voltmeter when done on a button.
Unread 29-03-2014, 23:46
Mentor, LRI, MN RPC
So with the striped down code, the only way to stop the motor is to disable the robot?
Try getting rid of the "if" part all together - just set the motor to 1.0 and see what happens. I would also try 0.9, see if the output value changes.
Unread 29-03-2014, 23:50
TFleig78's Avatar
AKA: Tyler
Also, it would be helpful to post all of the code so we can see what else might be affecting the output
Unread 29-03-2014, 23:54
FRC #2681
yea as i essentially just have the shooters set up to the drive train so its just the wheels running forward, rather than an arm just swinging around I didn't want to risk any other method of coding to be part of the issue. I'll try putting it on different speeds and seeing if the output values change
Unread 30-03-2014, 02:04
Programming
Makes no sense that the axis is causing the Talon to give a different voltage than the button. If it were an electrical problem, you should see consistent and identical results for axis vs. button.
One problem I've frequently seen is:
if (js.getRawButton(SHOOTER_BUTTON))
    shooter.set(1.0);
... 200 lines of code later ...
shooter.set(0.7);
Prints 1.0 but sets to 0.7.
If you're multi-threading, maybe something else in another thread is modifying the shooter?
It just doesn't make sense that the problem is electrical related. If you don't want to post your code, it's fine, but we can at least help you eliminate the possibility of the problem being your code.
Unread 30-03-2014, 10:35
FRC #2681
I tried opening a new project
public class WhyYouNoWork extends SimpleRobot{
        Joystick js = new Joystick(1);
        Talon shooter = new Talon(1);
public void robotInit(){
public void autonomous(){
public void operatorControl(){
   while(isOperatorControl() && isEnabled()){
            shooter.set(1.0);
