Go to Post Expect a lot of noise, unexpected things going wrong, and most of all, tons and tons of fun. - nitneylion452 [more]
Unread 30-03-2014, 21:21
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
Re: How to improve power in piston shooter
Originally Posted by LR_connor View Post
We are currently using our pistons as an extra push for a pass as we are a inbound robot. Our pistons are not strong enough to shoot over the truss and i feel as though it would be a nice improvement to get working. Any help on how to get pistons to shoot higher and farther would be greatly appreciated.
1. Get the highest Cv flow valves you can get. KOP ones are about .25Cv, you can find others that are higher, we found some that were .8Cv, makes a big difference.
2. Mount solenoid valves with a double male nipple directly to the piston if you have the room. No using tubing is huge as well between solenoid and piston.
3. Next create a low pressure (60) reservior (tank) right before the solenoid with no elbow fittings and use the shortest length of tubing as possible. Length is bad, avoid length.
That should help
remember the solenoid (valve) openings must be 1/8" as per rules and must be able to operate at 120psi, Cv can be high as you can get....
Faridodin "Fredi" Lajvardi KD7WKD
