Go to Post it seems to have all the basic food groups: liquid, sugar, sauce, and robotics components. - ChrisMcK2186 [more]
Unread 30-03-2014, 21:04
LR_connor LR_connor is offline
LR_connor
FRC #5191 (LANCERobotics)
LR_connor is an unknown quantity at this point
How to improve power in piston shooter
We are currently using our pistons as an extra push for a pass as we are a inbound robot. Our pistons are not strong enough to shoot over the truss and i feel as though it would be a nice improvement to get working. Any help on how to get pistons to shoot higher and farther would be greatly appreciated.
Unread 30-03-2014, 21:10
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: How to improve power in piston shooter
It would help if you would give specs on what you are currently using to launch the ball.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 30-03-2014, 21:21
falconmaster's Avatar
Happy Birthday! falconmaster falconmaster is online now
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
1. Get the highest Cv flow valves you can get. KOP ones are about .25Cv, you can find others that are higher, we found some that were .8Cv, makes a big difference.
2. Mount solenoid valves with a double male nipple directly to the piston if you have the room. No using tubing is huge as well between solenoid and piston.
3. Next create a low pressure (60) reservior (tank) right before the solenoid with no elbow fittings and use the shortest length of tubing as possible. Length is bad, avoid length.
That should help
remember the solenoid (valve) openings must be 1/8" as per rules and must be able to operate at 120psi, Cv can be high as you can get....
Faridodin "Fredi" Lajvardi KD7WKD
Unread 30-03-2014, 21:25
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
Make sure your operating pressure is set to 60 PSI. If you are only pushing one direction, try removing the fitting from the return end of the cylinder. That might let the air leave that section faster, potentially giving you a more powerful shot, provided the cylinder will gravity return to its original position.
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
Unread 30-03-2014, 21:28
Nick.kremer's Avatar
Nick.kremer Nick.kremer is offline
FRC #3512 (Spartatroniks)
Nick.kremer is an unknown quantity at this point
As stated, it would really depend on your current setup, but my team also went through trying to increase range w/ pneumatic and these the fixes that helped us:
1. Higher air-flow solenoids.
2. If you are using some sort of level arm, extend the arm.
3. Leaving the return side of the pistons open to vent to the air, and have the pistons return some other way (ex: surgical tubing, vacuum, ect.).
4. We had a separate air tank for each piston on our shooter, thus adding more air volume on the 60 psi side.
5. If possible, mount solenoids directly to each piston
Here are some ideas that either didn't help us or didn't apply in our situation, but may benefit you:
1. Adding more pistons.
2. Increasing piston bore.
3. Assisting the pistons (ex: surgical tubing, spring, ect)
Hope this helps,
-Nick
Check out Team 3512's Website!
Like us on Facebook!
Unread 31-03-2014, 08:57
kmusa kmusa is offline
AKA: Karlis Musa
FRC #0639 (Code Red Robotics)
kmusa is just really nicekmusa is just really nicekmusa is just really nicekmusa is just really nice
Originally Posted by falconmaster View Post
... and must be able to operate at 120psi, ...
Not quite right.
Per R77-D, if the solenoid valves are rated for less than 125 psi, an additional pressure relief valve must be added to the low pressure side of your system, and set to a pressure lower than the rating of the valve.
The interesting part of this is actually setting the valve. When we cranked up our low pressure side to 100 psi (the max of the regulator, but below the rating of our solenoids), we discovered a couple of marginal fittings.
-Karlis
"A society without contrasting ideas will never move forward; however those contrasting ideas must be based on fact, must be rational/logical, and must be presented in a respectful manner." -Arthur Dutra IV
"If the district can spend $1.5M on turf, it should be able to fund a FRC team." -Sophie Halter
Unread 31-03-2014, 09:35
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
Hope this helps,
-Nick
Increasing the diameter of your cylinders will most likely REDUCE the "power" of your shot, because it will slow the full activation of the cylinder (bigger cylinder - more to fill). If you need a certain amount of surface area to generate enough lift, then the fastest way to activate that would be increasing the number of cylinders - each with their own solenoid - and DECREASING the size of each cylinder, so they each fill quickly.
We used three .75" diameter by 12 stroke cylinders. The solenoids we are using are from McMaster Carr, and have about three times the flow rate as the standard KOP solenoids. Our shot can cross the truss and reach the human player from the center of the white line.
Two more things...(1) if you are using the cylinders in a direct pushing action, like us - we found that it was essential to have the ball resting on the plungers of the cylinders before the shot rather than have a space between the ends of the cylinders and the ball. Apparently the impact with the ball disrupted the action enough to dissipate some of the power transfer...so "push" don't "punch". and (2) don't try to fix multiple cylinder rods together into one plunger...it is nearly impossible to gang them together without introducing some friction on at least one of the rods, thus reducing power. We made a loose gathering gasket out of bicycle tube to keep the ends of the three cylinders together.
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Unread 31-03-2014, 11:36
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
As, if not more important than pneumatic design, is the kinematics. As much as possible, you what the line of action of the cylinder should be perpendicular to the axis of rotation.
Unread 31-03-2014, 12:48
Oblarg Oblarg is online now
AKA: Eli Barnett
Not necessarily. The dynamics of these shooters is extremely complicated; quite a few designs rely on starting at a significant mechanical disadvantage to work properly.
"The breakfast of champions!"
Unread 31-03-2014, 12:59
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
Doesn't change the importance of the kinematics, which is probably what I should said. Even so, the more efficient the kinematics, the less air you have to use to get energy into the ball.
Unread 31-03-2014, 13:40
Jibsy's Avatar
Jibsy Jibsy is offline
Mentor - 3756, 4525
AKA: Jared Baribeau
FRC #3756 (Ramferno)
Jibsy will become famous soon enoughJibsy will become famous soon enough
Depending on your setup, a potentially easy improvement is to add gas springs alongside the pneumatic cylinders to assist them on the way up.
I'm surprised that I haven't seen this done yet given how much it could add.
All of the force that the cylinder is using to launch is also being used to retract (not as strong on retract, but still packs a punch). Rather than having all of that go to waste, you can use it to store up energy in a gas spring. Something like these:
http://www.mcmaster.com/#gas-springs/=rc2sdb
You may also need to employ some of the tricks people have mentioned already about increasing the flow rate of your cylinder - otherwise the spring may just be slowed right down resulting in more than enough power, but not enough speed.
Best of luck!
Unread 31-03-2014, 14:18
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Best of luck!
Nearly every pneumatic launcher I have seen doesn't plumb the retraction of the cylinder at all. Most of them rely on gravity for return. This allows the cylinders to fire much faster as they don't have to exhaust through tubing or a solenoid.
Unread 31-03-2014, 14:51
LR_connor
here is the link http://www.princessauto.com/pal/en/P...nder/8188211.p to the specs on our pneumatic cylinder
Unread 31-03-2014, 14:54
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I think he wanted to see the whole launcher setup, not just the specs on the cylinder.
Do yo have a few pictures of your robot that would show us how it works?
Unread 31-03-2014, 14:57
LR_connor
That should help
Thank you for the information do you have any recommendations of where we can get some?
