Go to Post I'm not the only one confused. Perfect. - MikLast [more]
Unread 30-03-2014, 23:33
Re: Autonomous timing of events are to fast
Originally Posted by grosh View Post
Could you check to see if I've added them correctly?
I don't understand what your "read global variable" loop is intended to do. It's going to be continuously overwriting the global with the current motor value, which is likely to interfere with anything else trying to write the global. If that loop was newly added as part of implementing the global variable, remove it.
There is nowhere I can see that actually sets the motor value. You replaced the spot in Periodic Tasks where that was being done with another global variable write, where all you needed to do was replace the constant 0 with a read of the variable. The only places that should be writing the global are what used to be setting the motor value in the autonomous sequence.
I also don't see why you added a rearMotors global. Was something interfering with it as well?
