Go to Post All screws are not created equal. - Al Skierkiewicz [more]
Unread 31-03-2014, 13:40
Jibsy's Avatar
Jibsy Jibsy is offline
Mentor - 3756, 4525
AKA: Jared Baribeau
FRC #3756 (Ramferno)
Jibsy will become famous soon enoughJibsy will become famous soon enough
Re: How to improve power in piston shooter
Originally Posted by LR_connor View Post
We are currently using our pistons as an extra push for a pass as we are a inbound robot. Our pistons are not strong enough to shoot over the truss and i feel as though it would be a nice improvement to get working. Any help on how to get pistons to shoot higher and farther would be greatly appreciated.
Depending on your setup, a potentially easy improvement is to add gas springs alongside the pneumatic cylinders to assist them on the way up.
I'm surprised that I haven't seen this done yet given how much it could add.
All of the force that the cylinder is using to launch is also being used to retract (not as strong on retract, but still packs a punch). Rather than having all of that go to waste, you can use it to store up energy in a gas spring. Something like these:
http://www.mcmaster.com/#gas-springs/=rc2sdb
You may also need to employ some of the tricks people have mentioned already about increasing the flow rate of your cylinder - otherwise the spring may just be slowed right down resulting in more than enough power, but not enough speed.
Best of luck!
Unread 31-03-2014, 14:18
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Best of luck!
Nearly every pneumatic launcher I have seen doesn't plumb the retraction of the cylinder at all. Most of them rely on gravity for return. This allows the cylinders to fire much faster as they don't have to exhaust through tubing or a solenoid.
