Go to Post Multiple event winners are what drive me and my friends to be better and achieve more. - Akash Rastogi [more]
Unread 31-03-2014, 14:57
LR_connor LR_connor is offline
LR_connor
FRC #5191 (LANCERobotics)
LR_connor is an unknown quantity at this point
Re: How to improve power in piston shooter
Originally Posted by falconmaster View Post
1. Get the highest Cv flow valves you can get. KOP ones are about .25Cv, you can find others that are higher, we found some that were .8Cv, makes a big difference.
2. Mount solenoid valves with a double male nipple directly to the piston if you have the room. No using tubing is huge as well between solenoid and piston.
3. Next create a low pressure (60) reservior (tank) right before the solenoid with no elbow fittings and use the shortest length of tubing as possible. Length is bad, avoid length.
That should help
remember the solenoid (valve) openings must be 1/8" as per rules and must be able to operate at 120psi, Cv can be high as you can get....
Thank you for the information do you have any recommendations of where we can get some?
