Go to Post Every game design should be a means to an end. - Mark McLeod [more]
Unread 23-03-2014, 18:56
Week4 Twitter data analyses
This thread is for discussion of Week4 Twitter data analyses posted here:
http://www.chiefdelphi.com/media/papers/2985
I will be adding additional analyses as time permits. Special requests will be considered also.
Unread 23-03-2014, 19:40
mmaunu's Avatar
mmaunu mmaunu is offline
FRC #2485 (W.A.R. Lords)
mmaunu is a jewel in the roughmmaunu is a jewel in the roughmmaunu is a jewel in the roughmmaunu is a jewel in the rough
Re: Week4 Twitter data analyses
Let me start by saying thanks for all that you do for this community...I have grown tremendously over the last several years reading your posts.
What is uCCWM? CCWM without foul points?
2014 Las Vegas (Winners with 987, 2478; Excellence in Engineering)
2014 San Diego (Finalists with 987, 3250; Quality Award)
2013 Inland Empire (Winners with 1538, 968; Excellence in Engineering Award)
2013 San Diego (Finalists with 2984, 4322; Creativity Award)
2012 Las Vegas (Finalists with 2034, 3187; Quality Award)
Unread 23-03-2014, 19:41
Navid Shafa Navid Shafa is offline
FIRST Hiatus/Retired?
Navid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond repute
I really like EPA. Certainly more useful for cross event comparisons than raw OPR/CCWM. Wish we could tie in average event score or something of the like to EPA. Being able to view OPR separate from fouls and EPA certainly helps remove outliers from the data.
Thanks for the data as usual.
2015 & 2016 Fantasy FIRST Champions [Rotten Fruit Alliance]
Elgin Clock Award Winners: '13, '15, '16
Team 1983 | Alumnus, Former Mentor| Team_ 360 | Former Coach | Team 5803 | Former Mentor
"Once a Skunk, Always a Skunk"
Founding Member
Unread 24-03-2014, 10:26
Yes. It's CCWM without foul points (the "u" stands for Unpenalized). Sorry about that. I forgot to explain it.
uCCWM = ( final - foul ) - ( op_final - op_foul )
"regular" CCWM = ( final - op_final )
also:
EPA = ( final - foul ) - uAvg
DPR = op_final
uDPR = ( op_final - op_foul )
Unread 24-03-2014, 14:41
I just added a spreadsheet showing the average alliance scores (win, lose, all, unpenalized all, fouls) for each event.
Look for Average Alliance Scores at each Event near the bottom of the list of attachments:
Not sure what the best way would be to integrate these with EPA.
Unread 25-03-2014, 18:10
I'd like to get some feedback on which of the attachments you'd like to see again for Week5. I need to pare it back a bit.
Unread 25-03-2014, 19:53
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
Posting here because it's a very similar subject.. On request of some twitter people, I used the @frcfms data to determine the % of matches determined by fouls (any change in result, including from or to ties) over the past three years, broken down into years and categories such as quals, semifinals, or 3rd match of an elimination series. Those statistics are available here: http://goo.gl/mKuTXS.
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 31-03-2014, 15:55
brennonbrimhall brennonbrimhall is offline
Free Agent
AKA: Brennon Brimhall
brennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to all
Any chance we could get the number of data points (FMS tweets) you used? Stuff like that's really important for generating standard errors for confidence intervals and seeing just how much of a change there's been for this year. As Walter Lewin is fond of saying, "any measurement is useless without a knowledge of the uncertainties."
  1. How easy would it be to post your dataset in a format that Excel tolerates? Doing so gets you out of 2-3.
  2. Is it possible to see the percent of matches that have been decided by fouls, broken down by week and by match type (qualification/elimination)?
  3. Using assist scores, would it be possible to determine the average number of cycles an alliance generates? Again, is it possible to see averages per week, by match type?
Team 20, 2012-2014: 4 blue banners, 5 medals, and 9 team awards.
Church of Jesus Christ of Latter-day Saints, 2014-2016: Missionary, Colorado Denver South Mission.
Unread 31-03-2014, 16:18
Thanks to Brandon, the raw Twitter data is available in CSV format this year. Knock yourself out. CSV files open directly with Excel if you have the file associations set to tell Windoze that Excel is the proper app to use to open them.
Unread 31-03-2014, 16:23
Free Agent
Sweet! Thanks for pointing me in the right direction.
EDIT: It doesn't seem like assist points are part of the FMS feed. Is there another resource out there I could mine for analysis?
Unread 31-03-2014, 16:44
jlmcmchl jlmcmchl is offline
FF - The Breakfast Company
AKA: Jordan McMichael
FRC #0027 (Team RUSH 27)
jlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud of
The only true way to know assist points by match is to recalculate them after every match based on USFIRST's ranking page. Otherwise, you need a new data source from FIRST, i believe. The scoring/index.lasso page on USFIRST (You can find it's link and related links via a google search) looks promising, but I haven't found any match information from there.
Field reset: Kettering Kickoff ('13, '14), Kettering ('14, '15), Bedford ('14), Woodhaven ('16), Carver ('16), Einstein! ('16)
Referee: Bedford ('15), MARC ('15, '16), Kettering Kickoff ('15, '16), Kettering District (#1&2: '16), Troy ('16)
Unread 31-03-2014, 17:01
Twitter data1 has final score, foul points awarded, autonomous, and "TeleOp"2 for each match
Match Results has final score for each match
Team Standings has Assist, autonomous, Truss&Catch, and "TeleOp"3 for each Team (total of all alliance scores for alliances on which the team played).
1The usual Twitter data caveats apply.
2Twitter "TeleOp" is equal to Assist + T&C + Goals
3 Team Standings "TeleOp" is equal to Goals + Fouls
Unread 31-03-2014, 18:10
Free Agent
I thought I'd post my analysis -- I was looking to see if the proportion of matches that ended in fouls was increasing, decreasing, or staying the same. I ran a Chi-Square GOF test on the expected number of matches decided by fouls against the number of matches played that week times the total average rate of matches decided by fouls.
My null hypothesis was that each match had the same proportion of matches decided by fouls. With the percentage of matches that are decided by fouls being 23.34%, my x^2 value ended up being 46.4. I came up with a p-value of 5.06945E-07. So clearly, weeks and match type produce different numbers of matches decided by fouls.
	MDBF	Played	Expected	Difference	X^2		Std. Resid.
1E:	29	159	37.11062625	-8.110626253	1.772598979	-1.331389868
1Q:	228	783	182.7523293	45.24767072	11.20287612	3.347069781
2E:	61	205	47.84703385	13.15296615	3.615699965	1.901499399
2Q:	312	1039	242.5027716	69.49722845	19.91674046	4.462817547
3E:	48	264	61.61764359	-13.61764359	3.009531137	-1.734800028
3Q:	293	1237	288.7160042	4.283995754	0.06356634	0.25212366
4E:	41	245	57.18304045	-16.18304045	4.579868371	-2.140062702
4Q:	253	1184	276.3457955	-23.34579549	1.972261479	-1.404372272
5E:	64	283	66.05224673	-2.052246727	0.063763412	-0.252514182
5Q:	340	1493	348.4664465	-8.466446515	0.205703353	-0.453545316
But, there's not really a solid trend. I would have liked to see the number of matches decided by fouls go down by week, but it's not that clear cut. It will be interesting to see Week 6 results and how they compare.
Name:	Difference By Week.png
ID:	16724  Click image for larger version
Name:	% Difference By Week.png
Unread 31-03-2014, 18:12
Free Agent
That's too bad that FIRST doesn't give that to us on a per-match basis. Thanks for the clarification.
Unread 31-03-2014, 18:56
Join the chorus. Talk it up. Find out if there's a mentor on your team who might know someone within FIRST who would have the interest and authority to make that happen.
http://www.chiefdelphi.com/forums/sh...58&postcount=4
http://www.chiefdelphi.com/forums/sh...61#post1144161
http://www.chiefdelphi.com/forums/sh...1&postcount=15
http://www.chiefdelphi.com/forums/sh...4&postcount=20
http://www.chiefdelphi.com/forums/sh...6&postcount=17
http://www.chiefdelphi.com/forums/sh...65&postcount=3
http://www.chiefdelphi.com/forums/sh...81&postcount=9
