Go to Post Nothing says poor quality like a wrinkle in duct tape. - Matt C [more]
Unread 31-03-2014, 07:44
mlantry mlantry is offline
I'm back
AKA: Matthew Lantry
mlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud of
VexPro sprocket wear
After a season and a half of wear our 15 tooth Vex sprockets that are apart of our drivetrain wore down to nothing at the Bridgewater-Raritan District. The quality of the sprocket was awesome consider we played at a total of 4 districts, at champs, at MAR champs, through offseason events and a lot of driver practice.
Matthew Lantry
Team 4475 2014-present
-College Mentor 2014-????
Team 1676- 2011-2014
-Mechanical 2011-2014, Subteam leader 2013-2014
-Robot Operator 2014
George G. White FLL mentor 2011-2014
“Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute.”
Unread 31-03-2014, 09:57
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: VexPro sprocket wear
That's rather concerning. I wouldn't expect that at all. Were they way over tensioned or something?
Unread 31-03-2014, 10:05
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I'm confused. Where these on your competition robot at Bridgewater? Or your practice robot? Did you re-use these sprockets from last year?
Unread 31-03-2014, 10:07
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: VexPro sprocket wear
With no lubrication, and aluminum in contact with steel, wear would be expected. Most teams concerned about weight use aluminum, and will easily last a competition season. How did the other sprockets fare? Were they aluminum as well?
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 31-03-2014, 10:48
Andrew Lawrence
Posts: n/a
OP mentioned using them at MAR Champs and offseasons, so I assume these started their lives in the beginning of the 2013 season.
Unread 31-03-2014, 10:49
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I gathered that much, but was confused as to how they failed at an event this year. I'm assuming they must have been harvested from last year's robot, but I know better than to assume.
Unread 31-03-2014, 10:52
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
We used some 34(?) tooth sprockets on our ANSI 25 chain drive last year, and I am not even sure much of the anodizing has been worn off, even after 2 regionals, TRR, and a hundred hours of demoing
Unread 31-03-2014, 11:33
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I'm guessing poor sprocket alignment? If the sprockets aren't in line with each other, you could get significant wear from the side plates of the chain rubbing against the side of the sprocket. That's about the only way I can think of that you'd get that kind of wear pattern on the sprocket. I assume that once the sprocket was worn thin enough the teeth sheared off and then the sprocket was replaced.
Unread 31-03-2014, 11:46
I'm back
AKA: Matthew Lantry
They were from last year and we reused them and during bridgewater them just wore out bad
Matthew Lantry
Unread 31-03-2014, 11:47
I'm back
AKA: Matthew Lantry
nah we abused them with improper tension and they began to wear excessively from chain skipping the teeth wore down quickly. after we replaced them we were sure to have the chain properly tensioned and lubricated in order to avoid the problem again
Matthew Lantry
Unread 31-03-2014, 17:02
DonRotolo's Avatar
Back to humble
FRC #0832
Matt, still going to argue that the chains aren't too tight?
Sigh. I tried.
These sprockets are in no way faulty, we absolutely abused them beyond reasonable, with chain tension so high the chain actually made a "sproing" sound when plucked, no lubrication at all on dirty, used chain, and a very small diameter (15T) coming off the ball shifter (very high power transmission with about 90 degrees of wrap).
On Team 1676, the adult mentors advise and sometimes cajole, but we don't overrule a student decision (except for safety). Maybe there's some education that happened here. Finally.
sheesh.
Unread 31-03-2014, 17:17
T^2 T^2 is offline
FRC #5499
Is there anything wrong with keeping chain a tiny bit loose?
Unread 31-03-2014, 18:29
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Sigh. I tried.
sheesh.
Truth.
The chain should move up and down a distance proportional to the length of the chain.
Unread 01-04-2014, 00:41
Botwoon's Avatar
Botwoon Botwoon is offline
A.K.A. Matthew Ruane
FRC #0207 (Metalcrafters)
Botwoon will become famous soon enough
Cyclists sometimes call it track slack. A loose chain is a fast chain.
