Go to Post Hard work is a necessary prerequisite for luck. - Ian Curtis [more]
Unread 23-03-2014, 16:59
Ikillee Ikillee is offline
FRC #4733
Ikillee is an unknown quantity at this point
Air controlled solenoid valve
We have this solenoid valve that is controlled by air rather than electricity. Its kind of hard to explain. It looks exactly like a normal double acting solenoid valve except it has two more holes for the air to control the valve.
The reason we decided to use a air controlled valve rather than an electrically controlled one was because the airflow was very restricted with our original solenoids. The problem is the air controlled valve is huge. It has output holes at 3/8" diameter. We're not sure if this is legal.
Below I've attached a picture of the box it came in. One of the teachers took it with him to find connectors for it. Any suggestion as to whether this is legal or not is appreciated.
Unread 23-03-2014, 17:09
CENTURION's Avatar
CENTURION CENTURION is offline
King of unreasonable designs
AKA: Evan the Shop Princess
FRC #1306 (BadgerBOTS)
CENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant future
Re: Air controlled solenoid valve
This is not a solenoid valve at all.
Solenoid valves are controlled by a solenoid, which is basically an electromagnet. This allows them to be activated electrically.
What you have there is an air-op valve. It, as you said, is controlled by a change in air pressure.
As far as I know, air-op valves are not legal for FRC use. I could be wrong on that though.
FRC #1306 - BadgerBOTS - Mechanical/Machining/Safety/Marketing Mentor
FTC #6806 - Ratchet Robotics - Head/Founding Mentor
2010 - Wisconsin Regional Chairman's Award Winner - Wisconsin Regional Quarter-finalist - Curie Division #5 Seed, Quarter-finalist
2011 - Wisconsin Regional Innovation in Control Award Winner - Wisconsin Regional Quarter-finalist
2012 - Wisconsin Regional Engineering Inspiration Award Winner - Wisconsin Regional Semi-finalist
2013 - Wisconsin Regional Chairman's Award Winner
Unread 23-03-2014, 17:20
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Attachment 16634
Originally Posted by "FRC rules R77
R77
The only pneumatic system items permitted on 2014 FRC ROBOTS include the items listed below.
A. Items available in the 2014 KOP,
B. Pneumatic pressure vent plug valves functionally equivalent to those provided in the KOP,
C. Solenoid valves with a maximum 1/8 in. NPT port diameter,
D. Solenoid valves that are rated for a maximum working pressure that is less than 125 psi rating mandated above are permitted, however if employed, an additional pressure relief valve must be added to the low pressure side of the main regulator. The additional relief valve must be set to a lower pressure than the maximum pressure rating for the solenoid valve,
E. Additional pneumatic tubing, with a maximum 0.160 in. inside diameter, functionally equivalent to that provided in the KOP,
F. Pressure transducers, pressure gauges, flow control valves, and connecting fittings,
G. Pressure regulators with a maximum outlet pressure of no more than 60 psi,
H. Pneumatic cylinders,
I. Pneumatic storage tanks, and
J. Compressors compliant with R79.
Above emphasis mine.
Pneumatically controlled valves are not legal on FRC robots, nor are valves with greater than 1/8" NPT ports.
___________________
- Tennyson, Ulysses
Unread 24-03-2014, 20:41
goofy173's Avatar
goofy173 goofy173 is offline
Electronics Mentor
FRC #2867 (ElkLogics)
goofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to all
I think the regular Pesto FRC approved solenoids are good enough. They are actually electric and air actuated.
There is an electric solenoid that allows air to a pneumatic plunger which then switches the ports. That's why you have to have air to those solenoids for them to switch.
They can also be a little complex to open up and clean as I did with 3 of ours. I was also a little interested in the insides anyway.
Unread 31-03-2014, 19:30
FRC #4733
Can we bypass using solenoids by using a servo to release the air into the solenoids.
Unread 31-03-2014, 19:44
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Basically. No. Valves you can use are limited. Q&A has essentially said you cannot use a servo to turn a valve. In other years, they had a different answer.
