Go to Post Unsure if I'll get it to work, but that's no reason to not try. - DonRotolo [more]
Unread 31-03-2014, 13:52
Ginger Power's Avatar
Ginger Power Ginger Power is online now
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
OPR for select matches?
I was wondering how to calculate OPR for only select matches as opposed to all the matches in a competition. Currently 4607 has an OPR of about 40. The first 4 matches we participated in we were barely working. I'm just curious how one would make the calculation based on match videos and other resources available. This is not a thread about the validity of OPR just how to make the calculation. Thanks.
Unread 31-03-2014, 14:07
blaze8902 blaze8902 is offline
AKA: Buddy McWilliams
FRC #4265 (Secret City WildBots)
blaze8902 is on a distinguished road
Re: OPR for select matches?
Short Answer? Not easily.
If you still want to try, or want an explanation as to why it is difficult, (Written by people far more knowledgeable on the subject than myself) then here's a link.
http://www.chiefdelphi.com/forums/sh...d.php?t=101390
As far as other resources available, for data regarding final match scores I suggest www.thebluealliance.com and the android app FRC Spyder.
(Be wary of any calculations done by Spyder. The app is well made, but the data this year is extremely hard to work with.
Unread 31-03-2014, 16:20
brennonbrimhall brennonbrimhall is offline
Free Agent
AKA: Brennon Brimhall
brennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to all
This reminds me of a question I had in my first FIRST year, and it's corresponding thread.
To quote/paraphrase:
Originally Posted by Tom Line
OPR is actually a system of simultaneous equations. The difficulty lies in solving that many simultaneous equations...
Each match has equations that lay out like this:
Robot_1_score+Robot_2_score+Robot_3_score=Red_Scor e
Robot_4_score+Robot_5_score+Robot_6_score=Blue_Sco re
So, if the system of equations for the event you attended is still solvable if you removed your first 4 matches, then yes, it would still be calculable.
I'd reccomend looking at Ed Law's CD Media post on the subject if you'd like to learn more.
Team 20, 2012-2014: 4 blue banners, 5 medals, and 9 team awards.
Church of Jesus Christ of Latter-day Saints, 2014-2016: Missionary, Colorado Denver South Mission.
Unread 31-03-2014, 16:43
Attached is the Qual Match Results for MNMI2. Tell me which matches you want to omit from the event.
Then I'll walk you through how to do the calculation.
Unread 31-03-2014, 20:07
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ideally I could eliminate the following matches:
Qualification match 4
Qualification match 19
Qualification match 29
Unread 31-03-2014, 20:51
Your OPR would then be 53.7
A.txt is the (sparse) design matrix which describes the alliances
b.txt is a list of alliance scores corresponding to the A matrix
teams.txt is a list of teams in the order they appeared in the data being processed
OPR.txt contains the OPRs. It can be calculated using Octave (or MatLab) using the following:
OPR = A\b
File Type: txt b.txt (852 Bytes, 7 views)
File Type: txt teams.txt (359 Bytes, 6 views)
Unread 31-03-2014, 21:09
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
OPR = A\b
Thank you for walking me through the process. I'm glad I was able to learn something from this. I'm always amazed by your math all over Chief Delphi.
