Go to Post If your robot can't play at least two matches on one battery, your mechanical design and/or driver strategy needs some rethinking. - Al Skierkiewicz [more]
Unread 01-04-2014, 00:10
Alfredp832 Alfredp832 is offline
WINT 3794
FRC #3794 (Wint)
Alfredp832 is an unknown quantity at this point
Sensor doubt!
Hello! last week we were talking about sensor and their aplications so we were thinking on using a magnetic sensor for a team project, the question is FIRST allow us to use them? and if its allowed, does Labview can program it?
Unread 01-04-2014, 00:11
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Re: Sensor doubt!
Depends on the specs of the sensor. Link?
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 01-04-2014, 00:12
MrTechCenter's Avatar
MrTechCenter MrTechCenter is offline
INTENSITY
AKA: Harsharan "Harsh" Dhaliwal
FRC #2073 (Eagleforce)
MrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant future
Re: Sensor doubt!
What kind of a magnet sensor? Like the kind you use on a magnetic piston?
2011 Sacramento Regional Finalists; 2011 MadTown Throwdown VIP Excellence in Engineering Award; 2012 Sacramento Regional Innovation in Control Award; 2012 Silicon Valley Regional Judges' Award; 2012 CalGames Autonomous Challenge Award; 2012 MadTown Throwdown Finalists; 2013 P0W3RH0U53 PWNAGE Gracios Professionalism Award; 2014 Central Valley Regional Innovation in Control; 2014 Sacramento Regional Innovation in Control; 2014 Curie Division Gracious Professionalism Award; 2015 Sacramento Regional Innovation in Control
Unread 01-04-2014, 07:46
Re: Sensor doubt!
There currently is no specific rule against sensors provided they fit the other rules. For instance, you may not use a 110 vac sensor on the robot. You may even use a laser operated device provided the laser is contained and sealed such as a laser gyro or accelerometer.
Unread 01-04-2014, 09:00
Danny Diaz's Avatar
Danny Diaz Danny Diaz is offline
Smooth Operator
AKA: FrankenMentor
None #0418
Danny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond repute
Send a message via AIM to Danny Diaz
Re: Sensor doubt!
418 has several magnetic sensors on our robot this year, we use them for detecting position. For example we have an impact plate on our shooter, and on the back of the impact plate we have several magnets; the magnets trigger a reed switch mounted on our robot and they tell the robot when the impact plate has reached its maximum pullback position.
The magnetic sensor acts just like any digital microswitch would, when the magnet gets near it the sensor closes the circuit and changes value. LabVIEW reads the DIO line just fine.
-Danny
Danny Diaz
Former Lead Technical Mentor, FRC 418
Unread 01-04-2014, 11:54
Mulcahy's Avatar
Mulcahy Mulcahy is offline
FRC #0987 (High Rollers)
Mulcahy is on a distinguished road
Re: Sensor doubt!
Why not use a PNP inductive sensor? It works like a magnet/reed switch without the danger of accidentally being triggered by a collision. It can be wired directly to the DSC.
Unread 01-04-2014, 13:11
Re: Sensor doubt!
How would you wire a PNP sensor to the Digital Sidecar?
Unread 01-04-2014, 13:24
Pratik Kunapuli's Avatar
Pratik Kunapuli Pratik Kunapuli is offline
Probably browning-out on Astro-Turf
FRC #1648 (G3 Robotics)(EWCP)
Pratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to all
Re: Sensor doubt!
-Danny
We use the Hall Effect Sensors from WCP [link] on our Catapult to detect the loaded position. It is plugged into the Digital IO on the Digital Side card and Java just reads it as a digital input.
Official Driving Record: 101-59-0
2012-2015 Student 341 Miss Daisy
2015-Current Mentor 1648 G3 Robotics
Unread 03-04-2014, 23:11
WINT 3794
FRC #3794 (Wint)
Re: Sensor doubt!
The sensor is like the one used in an AGV that follows magnetic tape but i dont know if just with a DIO i can do it
Unread 04-04-2014, 02:00
Danny Diaz's Avatar
Smooth Operator
AKA: FrankenMentor
None #0418
Re: Sensor doubt!
Ok, so here's my general debugging guidelines when it comes to "strange" sensors:
(1) Can the device be powered using 5V or 12V? If so, it can be directly powered by one of the Digital or Analog input banks (5V) or it can be powered by a branch off the Power Distribution Board (12V). If not, you've got to figure out how to power it otherwise (if less than 12V but more than 5V, consider a voltage divider off a 12V PDB branch. If less than 5V, consider a voltage divider off the 5V DIO or Analog sensor lines (if using a DIO or analog input - see later)). If more than 12V, it's likely not going to be supported.
(2) When you power the device up, what voltages do you see on the signal line of the device (when compared to the common line of the power supply you're using)? If it's 5V or less, and is more-or-less a binary value (you see more than 3V when one condition is met - seeing or not seeing the magnetic tape - and less than 3V when the other condition is met) then you can use it on the DIO.
There ya go, in a nutshell.
-Danny
Danny Diaz
Unread 04-04-2014, 21:21
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Sensor doubt!
Like Danny said: If you can power it, it is very likely you can get the information from it.
I cannot imagine any real sensor that Labview would really be unable to use.
