Go to Post Coaxial swerve modules with a suspension and differential aren't normal. But on Winnovation they are. - Andrew Schreiber [more]
Unread 01-04-2014, 13:51
mechinn's Avatar
mechinn mechinn is offline
FRC #0869 (Power Cord 869)
mechinn is just really nicemechinn is just really nicemechinn is just really nicemechinn is just really nice
Re: LEDs
869 used a combination of an Arduino and Adafruit NeoPixel LED strips (http://www.adafruit.com/products/1460)
We used various combinations of digital outputs from the digital sidecar to send signals to the Arduino and had it do different things depending on what the robot was doing such as having blue/red depending on what the FMS told us our color was with
DriverStation.getInstance().getAlliance()
or our award winning countdown color rotation and blinking to let our drivers know how little time is left in the match without looking up from the robot based on the match time
DriverStation.getInstance().getMatchTime()
Unread 03-05-2014, 23:41
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
Re: LEDs
You may or may not have seen the LEDs we used on our robot this past season, so I don't know if what I'm talking about makes much sense out of context. We ordered a bunch of yellow LEDs being our team color and all and wired them up each separately so that each section of 3 was addressable. We arranged them in a pattern we liked on the robot and cut and soldered wire to the correct length to reach our micro controller. We used an 8052 based board that our electronics mentor made to control them. We had digital inputs in from the sidecar so that the cRIO had some input to the system. We also used an analogue pressure transducer to give a readout of our pneumatics pressure to give us visual feedback as to what we were sitting at. If I can, I will find a video of the system in action
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 04-05-2014, 12:29
Re: LEDs
Originally Posted by Raymond07 View Post
What is it about LEDs that attracts this kind of post? Team Element is in California, not Minnesota.
Unread 04-05-2014, 14:31
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
Re: LEDs
Well seems like we have LED vendors spamming the forums and apparently when I search specific model numbers especially the one that starts with "ws2" and ends with "812" CD is on the front page of searches for discussions.
Team 3476| Mentor| 2014 - Current
Team 3309| Mentor| 2011 - 2016
Team 766 | Mentor| 2006 - 2011 | Alumnus | 2002-2005
Unread 04-05-2014, 21:02
kellymc kellymc is offline
FRC #0766 (Bears)
kellymc is a splendid one to beholdkellymc is a splendid one to beholdkellymc is a splendid one to beholdkellymc is a splendid one to beholdkellymc is a splendid one to beholdkellymc is a splendid one to beholdkellymc is a splendid one to behold
Re: LEDs
We had a strip of LEDs on our pickup arm, they were wired to an arduino and a maxbotix ultrasonic sensor. We programmed the arduino to light up the LEDs in different colors depending on how far the robot was from the wall to give the drive team a visual indication of when to shoot.
Unread 05-05-2014, 23:29
nathanwalters nathanwalters is offline
nathanwalters has much to be proud ofnathanwalters has much to be proud ofnathanwalters has much to be proud ofnathanwalters has much to be proud ofnathanwalters has much to be proud ofnathanwalters has much to be proud ofnathanwalters has much to be proud ofnathanwalters has much to be proud of
Re: LEDs
Most people have covered the whole NeoPixel/Arduino design pattern, so I'll skip over that. One thing that hasn't been mentioned that my team (111) did is robot-Arduino communication. We had an I2C link between the robot and the Arduino. Whenever we wanted to update the LEDs on an event, say, the start of a match, raising our arms, or shooting, we'd send a command/payload byte combination to the Arduino which would then update the LEDs. The relevant Java class of our 2013 code is here: https://github.com/wildstang111/2013...ems/WsLED.java
Unread 06-05-2014, 20:19
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Re: LEDs
Could you post a copy of your Arduino code as well? I'd like to implement this in LabView.
Unread 23-05-2014, 15:35
DohertyBilly DohertyBilly is offline
Team Role: Tactician
DohertyBilly is a glorious beacon of lightDohertyBilly is a glorious beacon of lightDohertyBilly is a glorious beacon of lightDohertyBilly is a glorious beacon of lightDohertyBilly is a glorious beacon of lightDohertyBilly is a glorious beacon of light
Re: LEDs
This year we actually changed the way we communicated with the LEDs. We changed the strip we used (from LPD8806 to Adafruit NeoPixel) and the NeoPixel library disabled interrupts over I2C. Long story short, we lost control a few times. Because of this, we used the 4 leftover digital I/O ports on the sidecar to just send a binary number to the arduino, which changed the pattern based on that.
Unread 23-05-2014, 19:43
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Re: LEDs
We decided to do the same thing because we had a lot of leftover I/O pins (we use six of them for the LEDs). I was thinking about trying I2C but the cRIO would not cooperate in the limited amount of time I had, so it seemed more reliable just to use digital I/O.
Its good to know that the AdaFruit libraries disable I2C, because that could have caused lots of headaches.
