Go to Post If your robot can't play at least two matches on one battery, your mechanical design and/or driver strategy needs some rethinking. - Al Skierkiewicz [more]
Unread 01-04-2014, 20:00
Oblarg Oblarg is offline
AKA: Eli Barnett
4'' Plaction on AM14U?
Has anyone swapped the 4'' HiGrip KOP wheels with 4'' plaction? If so, how did you account for the difference in width of the wheels? We're considering doing this on our robot, but are unsure if the plaction wheels (which are wider) will actually fit for the center wheel, which has two pulleys on it with little/no clearance on either side.
"The breakfast of champions!"
Unread 01-04-2014, 20:05
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
How much wider are they? You could chuck em up in a lathe and skinny them up a little
Unread 01-04-2014, 21:30
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Re: 4'' Plaction on AM14U?
They should work. AM sells a plaction upgrade kit and it doesn't include wider churros. You might need to make new spacers though.
Plaction upgrade kit
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 01-04-2014, 22:26
orangemoore orangemoore is online now
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
It's really hard to do. We ended cutting down the center wheels and created our own custom spacers.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 01-04-2014, 22:30
Lead Bumper Mentor
AKA: Mike Marandola
What do you mean by cutting down your center wheel? How much did you have to take off?
Unread 01-04-2014, 22:52
AKA: Roger Moore
I want to say we removed about 1/2" equally from each side of the wheel. We did not need to do this for the outer wheels because we just adjusted the spacers.
The red part in the picture is what we took off.
Name:	Wheel Cut-Off.png
Stronghold
Student 2013-2016
Unread 01-04-2014, 22:58
ItsElectronic ItsElectronic is offline
Team Captain
AKA: Terence
FRC #4461 (RAMEN)
Team Role: CAD
ItsElectronic is an unknown quantity at this point
Its quite do-able. We had to shave down the wheels, on a lathe, to where the pulleys were nearly flush to the wheel and cut down the hex spacer for the center wheel to where the pulley was nearly flush with the outer plates.
