Go to Post Mob JVN for autographs - Jay Trzaskos [more]
Unread 02-04-2014, 19:59
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Labview disabled compressor runs *AT REGIONAL IN MATCH 1 TOMMOROW*
Originally Posted by NotInControl View Post
Also this is dependant upon where you start your compressor code from. If you start the compressor call in robot init, it has the potential to run during disabled.
This is not exactly true.
All of the outputs (PWM and Relay) are disabled in hardware when the robot is disabled. Even if you try to set them (there's no harm in setting them continuously while disabled), they will not be set because of the disable circuit.
However, there are some cases where the buffers for the relay outputs can fail in such a way that they ignore the disable circuit but otherwise work fine.
Running code while disabled can also help with troubleshooting code, as you can look at what it is trying to do without letting it do it.
Kettering Motorsports
Unread 02-04-2014, 20:07
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
I've seen this problem on and off for several years. For us, it was never consistent. Maybe once every 50-100 cycles the compressor would kick on as soon at the robot was turned on. All we would have to do is cycle the robot again and it would function as intended. I have seen this happen at least on time in the past 5 seasons. Is your situation repeatable?
Unread 02-04-2014, 20:18
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
While inspecting at the Sacramento regional, I came across a team that had this issue, or one similar to it.
Their compressor would run whenever the robot was powered on. They said "It has always done that.", which unnerved me a bit.
Long story short, they had the Spike relay for the compressor plugged into a PWM port with the jumper in place for use with a servo.
The jumper provided +6vdc to the center wire, thus telling the Spike to go into forward at all times.
So, check the wiring.
Unread 02-04-2014, 22:09
Arpan Arpan is offline
Olin class of 2019
FRC #3061 (Huskie Robotics)
Arpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud of
This is what we think happened.
