Go to Post It is great to see your friends and other teams succeed. - Bob Steele [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 03-04-2014, 17:57
Merfoo's Avatar
Merfoo Merfoo is offline
FRC #0955 (CV Robotics)
Merfoo is an unknown quantity at this point
Team 955's Scouting Program!
https://github.com/FRC-Team-955/Aeri...tScouting-1.2/
Run it from Github:
https://rawgithub.com/FRC-Team-955/A...ode/index.html
Unread 03-04-2014, 18:11
Monochromicon Monochromicon is offline
FRC #0955
Monochromicon is an unknown quantity at this point
Re: Team 955's Scouting Program!
You need two gamepads to run the program, the first one connected adjusts red team values, the second, blue. You can upload a match list text file, and it will automatically fill in the team numbers with each match number; an example file is attached.
After each match, hit the save button and it will generate a .csv file. Once you've got a collection of matches that you want to analyze, hit the "Create Master File" button, select the match files, and it will generate a complete file with all the teams and team scores.
Team values are averages and totals.
Key maps:
Right/Left Bumpers: Toggle between teams
Start: Toggle Teleop
Select: Toggle Autonomous
Autonomous:
A: Low hot goal
B: Low goal
X: High goal
Y: High hot goal
D-Pad: Starting Zone
Teleop:
A: Low goal
B: Truss score
X: Pass
Y: High goal
D-Pad: Zone Preference
Tags:
1: Defensive
2: Successful defense
3: Offensive
4: Successful offense
5: Broken
6: Can catch from player
7: Loose grip
8: Two Ball Autonomous
9: Good with (your team)
[IMG] code is Off
