Go to Post I once started to build a time machine. But then I went back in time and told myself that it wouldn't work, so I gave up on it. -dave - dlavery [more]
Unread 07-04-2013, 13:53
Re: paper: Take-Back-Half Shooter Wheel Speed Control
Originally Posted by tr6scott View Post
The code is labview, more info from this link. http://www.chiefdelphi.com/forums/sh...d.php?t=113954
Doh. I remember our conversation now. I am starting to show my age. Sorry 'bout that.
Unread 07-04-2013, 14:59
tr6scott's Avatar
tr6scott tr6scott is online now
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Me too. NP.
The sooner we get behind schedule, the more time we have to catch up.
Unread 03-04-2014, 22:14
The Doctor's Avatar
The Doctor The Doctor is offline
Robotics is life
AKA: Hackson
FRC #3216 (MRT)
The Doctor is on a distinguished road
I have found this to be an acceptable take-back-half algorithm:
cval -= (cval - goodval) / 2;
Where cval is the current value of [whatever] and goodval is the ideal point (what you want it to be at)
cval += constrain(-(cval - goodval) / 2,-max,max);
This also works, but is constrains the value to within a maximum speed, the variable max. Function constrain below:
float constrain(val,min,max) {
          return val>max?max:val<min?min:val;
This seems a lot simpler than the previously posted code, and I was wondering if they are equivalent?
Unread 03-04-2014, 23:29
Ziv Ziv is offline
Has code to be writing...
FRC #0125 (Nutrons)
Ziv is a glorious beacon of lightZiv is a glorious beacon of lightZiv is a glorious beacon of lightZiv is a glorious beacon of lightZiv is a glorious beacon of light
Where's the feedback here? How do you find goodval? The fact that you're setting cval suggests it's an output, and if you somehow knew the ideal output (namely goodval) then you wouldn't need closed loop control in the first place.
Now, if you instead have
cval -= (sensorval - goodval) / 2;
which seems to be what you were getting at, then what you secretly have is an integral controller (just the I from PID) with coefficient 1/2.
Unread 04-04-2014, 12:01
Yes.
And, just because it's an integrator, and its gain is 1/2, does not make it a TBH algorithm. The hallmark of TBH is the unique way that the output is reset at each zero crossing.
