Go to Post I just want to see Aerial Assist again. Played on Lunacy regolith. With minibot poles. Which are on coopertition bridges. Is that too much to ask for? ;) - M. Lillis [more]
Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
Unread 04-04-2014, 22:17
Oblarg Oblarg is online now
AKA: Eli Barnett
Main breaker tripping, dead CIM
After having nearly no problems with our drive for all of Greater DC, our robot started tripping our main breaker in matches today (problem arose as the day went on, in our last two matches we tripped the breaker about halfway through). Upon testing, we discovered a few things:
1) From a cold start, it takes ~20 seconds of pushing against a wall to trip our main breaker.
2) The wires going to the breaker from the battery heated up noticeably during this time.
3) One of our CIMs was badly damaged; the front ring was able to turn independently from the body of the CIM.
We replaced the CIM (and for good measure replaced the breaker), but are wondering why the problem cropped up so suddenly and if the dead CIM could have been exacerbating it. Any thoughts? We have not been able to test since replacing the parts, unfortunately.
We're running a 6-CIM modified KOP drive with HiGrip wheels geared for 14 fps.
"The breakfast of champions!"
Unread 04-04-2014, 22:24
Re: Main breaker tripping, dead CIM
Originally Posted by Oblarg View Post
...geared for 14 fps.
At CIM free speed?
Or 80% of CIM free speed?
Or something else?
Unread 04-04-2014, 22:32
AKA: Eli Barnett
At CIM free speed?
Or something else?
6.11:1 gearing with 4'' (probably now more like 3.75'' due to wear) wheels.
Unread 04-04-2014, 22:39
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
A dead CIM certainly could be the source of the problem.
Unread 04-04-2014, 22:47
m1506m's Avatar
m1506m m1506m is offline
FRC #1506
m1506m is an unknown quantity at this point
The faulty cim along with the 6 cim drive train, I've heard of 6 cim drives popping breakers.
Unread 04-04-2014, 22:50
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Damage to the CIM could certainly increase its power draw either through increased drag or due to an internal short.
The breaker is rated to trip in 20 sec with an aprox 200% over current situation. The breaker is thermal so short bursts of much higher current will cause the temp to rise and it to trip eventually. If enough heat is building up in the breaker to cause it to trip the wire will certainly be heating up as well. Extended use at near trip conditions will eventually cause fatigue of the internal materials and eventually lead to an early trip situation.
At peak power, ~2600 rpm a CIM draws 68 amps and as it speed decreases that current increases to 133 amps at stall assuming a full constant 12v is applied.
Unread 04-04-2014, 23:00
AKA: Eli Barnett
I imagine this likely has something to do with it suddenly getting a lot worse. We'll be sure to keep a few spare.
Unread 04-04-2014, 23:43
jeremylee's Avatar
jeremylee jeremylee is offline
FRC #2526 (Crimson Robotics)
jeremylee is a jewel in the roughjeremylee is a jewel in the roughjeremylee is a jewel in the rough
We also had 4" higrip kit setup. We were 7.08:1 in high gear with 3 cim ball shifters (6 full cims), and we never needed low gear even when we played heavy D as we never had any main trips through our two regionals.
Unread 05-04-2014, 09:10
aryker's Avatar
aryker aryker is offline
FRC #0868 (TechHOUNDS)
aryker will become famous soon enougharyker will become famous soon enough
Another thing that could compound the issues stated above is that when CIMs break, they sometimes short to their chassis, which in turn can short to your robot's chassis depending on how you have the CIM mounted. This in turn can cause some strange issues with other components. I've seen this happen several times before, where an electrically hot chassis can be traced back to a broken CIM.
Unread 05-04-2014, 14:01
Maximillian's Avatar
Maximillian Maximillian is offline
AKA: Max Westwater
FRC #5254 (HYPE)
Maximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant future
My team also had a problem with our breaker tripping with our 6 CIM drive train. It only became a problem in the later matches when we were playing heavy defense or were getting heavily defended ourselves. What we ended up doing was cooling down our main breaker right before our matches. We used a canned computer air duster held upside down and then sprayed it into the opening of the breaker. This got it cold enough that it wouldn't trip in the match for the most part. Its not the best solution but it ended up working decently well for us.
Unread 05-04-2014, 15:14
AKA: Eli Barnett
Well, swapping out the dead CIM unfortunately did not fix the issue; we were plagued by main breaker trips for all of our matches today.
After our last match, we went out to the practice field and tested a few things; during this time, I noticed that with a perfectly topped-up battery and no compressor running, we'd slip the wheels while pushing (as intended) and only draw 180 amps, which isn't a problem; this caused no heating of the wires and no breaker trip.
If the battery was slightly low and/or the compressor was running, we'd be unable to slip the wheels and our CIMs would stall, drawing 250 amps and causing massive heating and an eventual main breaker trip.
I'd imagine the problems we're having now, as opposed to at Greater DC, are due to an amalgam of factors; due to our robot's mechanisms being in a state of semi-operability, we weren't running our compressor during matches at DC. Moreover, our robot has gained ~6 lbs since then, and our gearboxes (they're WCP 3CIM SS gearboxes, so they're open) have been steadily accruing a layer of carpet fluff mixed in with the grease (we didn't have time to fully clean them out between matches).
It seems with our gearing/wheel COF/weight we're right at the boundary of what's operable. Does anyone have any advice (other than ditching a bunch of weight and cleaning out the gearboxes) for ensuring we're not tripping our breaker at worlds?
Unread 05-04-2014, 15:19
Best Available Data
FRC #1778 (Chill Out!)
I was always under the impression that once a main breaker had tripped you should replace it since it took less energy for subsequent trips. Is that actually true?
Unread 05-04-2014, 16:51
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
You could try implementing a voltage ramp in software. We did this in-between Central Illinois & St. Louis and never had another issue.
We did some testing on our practice drive at our school and found we were able to force the robot's radio or CRIO to reboot using 6 full sized CIMs geared similarly to what you described. Once we implemented the voltage ramp the problem was solved and we couldn't re-create the symptoms.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 05-04-2014, 17:07
AKA: Eli Barnett
How did you implement the voltage ramp?
If we were to use the simple slew rate limiter described by Ether, do you have any idea of what a sensible value for the limit should be? I'm not sure how fast the main loop is executing, and it seems it depends critically on that. We're coding in java.
Unread 05-04-2014, 17:41
MrRoboSteve MrRoboSteve is online now
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Another thing to check is whether the terminals on the main breaker are tight. I saw two teams this year with circuit breaker trips with a root cause of loose wires at the breaker.
I agree with the suggestion that you replace the breaker if it has been tripping regularly.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
