Go to Post But, as a mentor I should caution you that FIRST is not about you its about the students. - SomeoneKnows [more]
Unread 05-04-2014, 08:09
pblankenbaker pblankenbaker is offline
FRC #0868
pblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of light
Re: Dual Ultrasonic error
In looking through the Ultrasonic sensor source code (thanks for pasting in the link), it shows that the m_task variable associated with the background thread is static (a single instance for all Ultrasonic objects).
In looking at the comments for the setAutomaticMode() method, it looks like this method manages all of the configured sensors (to keep them time sequenced so they don't interfere with each other).
So, my best guess is that you only need to call setAutomaticMode(true) one time (even though it is not a static method).
Can you try changing your code to:
ballSonar = new Ultrasonic(Map.ARM_SONAR_INPUT, Map.ARM_SONAR_OUTPUT);
ballSonar.setEnabled(true);
wallSonar = new Ultrasonic(Map.LAUNCHER_SONAR_INPUT, Map.LAUNCHER_SONAR_OUTPUT);
wallSonar.setEnabled(true);
// Enable automatic pinging on all sensors (not sure why this method
// wasn't declared static in Ultrasonic class)
wallSonar.setAutomaticMode(true);
