Go to Post There are laws of physics, useful rules of thumb, and cold hard economics that come into play to be sure but at it's core Engineering is Art. For these artists, there is no substute for the sound engineering judgement. - Joe Johnson [more]
Unread 05-04-2014, 07:36
MysterE's Avatar
MysterE MysterE is offline
FRC Team #3337
AKA: Coach Eiland
FRC #3337 (Panthrobotics)
MysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond repute
Send a message via AIM to MysterE
Improper gearing and power draw
Ok
Quick question; on the field we are drawing way too much power and as a result lose the ability to do much. This is, as was told to us, the result of improper gearing (6:1) and six inch wheels. We have two cims and one mini on each Transmission, one Cim from the shooter, a compressor, and an Andy Mark motor driving our pickup.
We are considering removing both mini cims and installing omni wheels on the back of the bot to help lower traction and lower the power draw. Does this sound like something that would help?
Coach. D. Eiland
Head Coach - Team #3337
Panthrobotics (Woodlawn HS)
2016: Bayou Regional WFFA Winner
2016: Rocket City Regional Judges Award
2015: Bayou Spirit Award, Bayou Chairman's Award, Bayou Dean's List Finalist (Danielle Massey), Bayou Volunteer of the Year Award
2014: Bayou Dean's List Finalist (Witni Widmeier)
2011: Bayou Regional Winner | Judges Award
2010: Rookie Inspiration Award
Unread 05-04-2014, 07:47
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Re: Improper gearing and power draw
That might help, but ratio would be better. You are geared for free speed of 18+ feet per second free speed. This is really fast for a non shifting robot. Any pushing matches will likely cause your snap action breakers to trip. If you were popping your main, pulling the minis might help, but if you are tripping the snap action, you really need more ratio.
Unread 05-04-2014, 07:55
MysterE's Avatar
FRC Team #3337
AKA: Coach Eiland
Fortunately nothing is snapping.. the log just shows an inbordinate drop in power when we start moving around.
Coach. D. Eiland
Unread 05-04-2014, 08:00
D.Allred's Avatar
D.Allred D.Allred is offline
FRC #4451 (Rat Rod Robotics)
D.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond repute
Do you have 4" wheels available? You would still be 12fps.
David
Unread 05-04-2014, 08:13
MysterE's Avatar
FRC Team #3337
AKA: Coach Eiland
Yeah.. four inch would give us clearance problems. The gear boxes are a bit below the frame
Coach. D. Eiland
Unread 05-04-2014, 08:34
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
By drop in power, I assume you mean a drop in voltage.
If you are not direct driving your wheels you may be able to add another output ratio between the gearboxes and the wheels by changing pulley/sprocket sizes.
___________________
- Tennyson, Ulysses
Unread 05-04-2014, 09:15
...improper gearing (6:1) and six inch wheels. We have two cims and one mini on each Transmission, one Cim from the shooter, a compressor, and an Andy Mark motor driving our pickup.
You didn't say: Is this a 6WD or 4WD? Long or wide?
Unread 05-04-2014, 11:50
ktorrico ktorrico is offline
AKA: Kevin
FRC #2910 (Jack In The Bot)
ktorrico is an unknown quantity at this point
Are your speed controllers in "brake" mode?
We had a similar problem at our first district event, and switching to "coast" mode fixed the problem.
