Go to Post According to a 6 year old I once met at a demo, our FRC machine was not a robot because, "How can it be a robot if it doesn't have a face?" - Jared Russell [more]
Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
Unread 05-04-2014, 19:32
jeremylee's Avatar
jeremylee jeremylee is offline
FRC #2526 (Crimson Robotics)
jeremylee is a jewel in the roughjeremylee is a jewel in the roughjeremylee is a jewel in the rough
Re: Main breaker tripping, dead CIM
I think you could be geared a little fast. If its not too hard to swap, a 50:24 gearkit and some 14T or 13T pinions would fix it, though you lose some top speed. Checkout WCP website for ratio options.
Unread 05-04-2014, 19:56
Oblarg Oblarg is offline
AKA: Eli Barnett
The problem is that doing this on a KOP chassis is about 2-3 hours of work. We might go this route if we don't think any other option will suffice, but it's not a particularly favorable option.
"The breakfast of champions!"
Unread 05-04-2014, 22:58
m1506m's Avatar
m1506m m1506m is offline
FRC #1506
m1506m is an unknown quantity at this point
Does anyone have any advice (other than ditching a bunch of weight and cleaning out the gearboxes) for ensuring we're not tripping our breaker at worlds?[/quote]
Pull one cim off each side and replace them with mini cims. Making a 2cim/1mini cim gear box on each side.
Unread 06-04-2014, 08:54
mman1506's Avatar
mman1506 mman1506 is offline
Hater of Tiny Molex Connectors
AKA: Marcus Quintilian
no team (WARP7)
Originally Posted by Ian Curtis View Post
I was always under the impression that once a main breaker had tripped you should replace it since it took less energy for subsequent trips. Is that actually true?
It seems to be true in our case. Switching out the breaker solved almost all our problems. We also copied the poofs and used a upside down can of compressed air to freeze the main breaker before a match.
2016: FRC 865 Mentor
Unread 06-04-2014, 12:34
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Programming options:
1: easy: set a maximum current flow lower than 100%
2: more challenging: limit current to CIMs at a gearbox when it is not turning and you've been at high power for a bit. This requires distinguishing "starting at rest" from "been pushing for a while".
3: more challenging: like 2, but turn off other motors/compressor on robot when in pushing situations
4: more challenging: like 2, but implement this as a "current budget" where you estimate current flows and heat dissipation, with the latter decaying over time.
5: easy: like 1, exception implement a driver controlled "pushing mode" on your robot, that lowers maximum current levels
6: more challenging: like 2, but only when driver selects "pushing mode"
Next year's control system should open up some interesting options in this scenario.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 06-04-2014, 17:14
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
We've observed this on multiple occasions, and my understanding is that the tripping action is caused by the bending of a bimetal strip inside the breaker. I imagine that the strip could be subject to plastic deformation near the trip point and wouldn't have the same characteristics afterwards.
Whenever we trip a main breaker in competition (twice so far this year) it gets thrown into the nearest trash can and a new one goes on the robot. As Marcus said, between matches with tight turnaround we cool it down with compressed air.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 06-04-2014, 17:24
NotInControl NotInControl is offline
Controls Engineer
AKA: Kevin
FRC #2168 (Aluminum Falcons)
NotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond repute
Originally Posted by Ryan Dognaux View Post
You could try implementing a voltage ramp in software. We did this in-between Central Illinois & St. Louis and never had another issue.
We did some testing on our practice drive at our school and found we were able to force the robot's radio or CRIO to reboot using 6 full sized CIMs geared similarly to what you described. Once we implemented the voltage ramp the problem was solved and we couldn't re-create the symptoms.
+1 for voltage ramp. Doing this will lower the probability of all of your motors drawing peak current. We too do this on all of our 6-cim robots.
What language do you use? I am sure many teams on here can provide an example for the implementation in your programming language.
I know im side tracking here, but I am curious, do you know what was causing you to trip the main breaker?
Controls Engineer, Team 2168 - The Aluminum Falcons
[2016 Season] - World Championship Controls Award, District Controls Award, 3rd BlueBanner
-World Championship- #45 seed in Quals, World Championship Innovation in Controls Award - Curie
-NE Championship- #26 seed in Quals, winner(195,125,2168)
[2015 Season] - NE Championship Controls Award, 2nd Blue Banner
-NE Championship- #26 seed in Quals, NE Championship Innovation in Controls Award
-MA District Event- #17 seed in Quals, Winner(2168,3718,3146)
[2014 Season] - NE Championship Controls Award & Semi-finalists, District Controls Award, Creativity Award, & Finalists
-NE Championship- #36 seed in Quals, SemiFinalist(228,2168,3525), NE Championship Innovation in Controls Award
-RI District Event- #7 seed in Quals, Finalist(1519,2168,5163), Innovation in Controls Award
-Groton District Event- #9 seed in Quals, QuarterFinalist(2168, 125, 5112), Creativity Award
[2013 Season] - WPI Regional Winner - 1st Blue Banner
Unread 06-04-2014, 17:46
Circuit Breaker
Usually it's stalling a six-CIM drivetrain while trying to get out of a pin or T-bone, sometimes exacerbated by having had another match right before for the breaker to heat up.
Perhaps it's time for FIRST to consider distributing a higher-amperage breaker in the Kit of Parts? With all the motor power available to teams now, this seems like a pitfall that a lot of teams are falling into.
Patrick Fairbank
patfairbank.com
Unread 06-04-2014, 17:54
Travis Schuh Travis Schuh is offline
FRC #0971 (Spartan Robotics)
Travis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant future
Or perhaps it is time for teams to back down on the number of motors they stall at the same time. Our experience with 6 CIM drive in 2013 was that we lost more matches due to blowing the main breaker than we won by having that little extra in our drive train. We went back to 4 CIMs in the 2013 off season and this year and have been very happy with the results (IE no blown breakers, just fine pushing and speed). The extra 2 CIMS in the drive isn't really adding 50% more performance. I would be interested to see some testing/analysis (which is on our todo list) of how much of a difference 6 CIMs vs 4 CIMs makes on performance given the limitations of the battery.
Unread 06-04-2014, 18:16
Mr V's Avatar
Mr V Mr V is online now
FRC #5588 (Reign)
But to allow a higher amperage breaker would mean requiring larger gauge wire, higher capacity Anderson Connectors and a battery that could sustain a higher continuous current. I'm sure many teams would be upset as some have a rather significant investment in the current batteries and associated pieces.
Unread 06-04-2014, 20:29
AKA: Eli Barnett
The crucial bit we noticed is that at our gearing, our breaker is fine unless we stall the CIMs, i.e. while slipping the wheels we have no problem, and the CIMs do not stall on a fully topped-up battery if the compressor is not running.
So, it seems our short-term options (barring changing our gear ratio - if anyone thinks this is really our best solution even with the 2-3 hour investment to get it done, please let me know) are to not turn on our compressor if we are going to be playing defense and to make sure our batteries are in absolute top shape before going out on the field.
Does anyone know if there's a reliable way to test if batteries are actually charged? We have all new batteries this year, but the charge indicator on the charger can be misleading.
(As a side note, I'm wary about swapping two of our CIMs for mini-CIMs, as this could have the opposite of the desired effect by making it absolutely impossible for us to slip our wheels in a pushing match.)
Unread 06-04-2014, 20:53
Here's a possible software solution:
Measure the voltage drop across the main breaker with an analog input. Sample it and square each sample. Run the squared samples through a low-pass filter (a simple IIR would probably suffice). If the filtered value exceeds some experimentally-determined threshold, reduce the commands to the drive motors until the filtered value drops below the threshold.
Unread 06-04-2014, 21:54
AKA: Eli Barnett
This certainly sounds like it's worth trying. Unfortunately, I'm a mechanical mentor, and am not sure how to implement this; what would be the best way to actually wire that, and what sort of low-pass filter code would you recommend (I know how to do simple exponential smoothing, but that's about it)?
Unread 06-04-2014, 22:24
Perhaps something like this.
Unread 06-04-2014, 22:34
AKA: Eli Barnett
Amusingly, that's essentially exactly what my naive approach would have been, software-wise. Thanks.
I'm still partially leaning towards swapping out our gearkit to 7:1 or 8:1; we've got two spare gearboxes which should expedite the process greatly (much easier to switch out the whole gearbox than to change the gearkits of the ones on the bot). We can probably absorb the hit in top speed without too much trouble, as our defensive strategy is very much based on positioning and pushing.
