Go to Post My suggestion is to first focus in on your drive base. Get it running, and drive it into the ground and see what breaks. Then fix it. Rinse wash and repeat. - Andy A. [more]
Unread 28-03-2014, 21:34
xForceDee's Avatar
xForceDee xForceDee is offline
AKA: Bart Kerfeld
FRC #4239 (Warpspeed)
xForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to behold
Best Way(s) to Implement a Delay in Command Groups
Today, my former team asked me what the best way to implement a delay in a command group is. They are well aware of the built in delays in the adding of the commands.
addSequential(new DriveForward(), DELAY_TIME);
But they want there to be a period where the robot does absolutely nothing for a while for some reason (I assume to let the ball settle). They seem convinced
Timer.delay(DELAY_TIME);
did not do what they wanted. I know one way to do it could be to make a command that does nothing but that seems a bit excessive, and I am not sure if you can make a command that doesn't require a subsystem (never have done that before) and don't know if that is fair game. So if someone could answer that, it would be cool also. Anyway, back to the real question, does anyone have a clean solution to this I could report back to them with?
Unread 28-03-2014, 21:45
kylelanman's Avatar
kylelanman kylelanman is offline
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
kylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to all
Re: Best Way(s) to Implement a Delay in Command Groups
AddSequential(new WaitCommand(1)); //Wait 1 second.
"May the coms be with you"
Is this a "programming error" or a "programmer error"?
Unread 04-04-2014, 00:00
Joey1939's Avatar
Joey1939 Joey1939 is offline
AKA: Joey Holliday
FRC #1939 (Kuhnigits)
Joey1939 has a spectacular aura aboutJoey1939 has a spectacular aura aboutJoey1939 has a spectacular aura about
I discovered that it is best to not use Timer.delay() because that will pause your entire robot (Every other command and every other subsystem). My solution was to create a Wait command that accepts a timeout as an argument. It then sets its timeout (this.setTimeout(arg)) to the argument. Then isFinished() returns this.isTimedout(). This will effectively put a delay in the command group because they command won't finish until the timeout has elapsed.
Unread 04-04-2014, 19:31
bvisness's Avatar
bvisness bvisness is offline
Programming Mentor, Former Driver
bvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of light
Our team uses the same approach mentioned by Joey1939. I've attached the .java file for the command we use. (You might want to just copy/paste the important bits - there's a lot of unnecessary RobotBuilder crap in here that we never cleaned out.)
We call it in command groups like so:
addSequential(new Delay(1.25));
Unread 04-04-2014, 22:56
TFleig78's Avatar
TFleig78 TFleig78 is offline
AKA: Tyler
FRC #0078 (Air Strike)
TFleig78 will become famous soon enoughTFleig78 will become famous soon enough
We use:
addSequential(new WaitCommand(WAIT_TIME));
This WaitCommand is built into the WPI Library.
Also, it is possible to have a command that does not require a subsystem, as we have done this before, but probably is not recommended.
Unread 05-04-2014, 20:36
bvisness's Avatar
Wow, I had no idea that was even there. They really ought to put that in the ScreenSteps documentation somewhere...
Unread 06-04-2014, 15:08
bvisness's Avatar
Why would this be a problem? Understandably, you could have two commands trying to use a subsystem at the same time. But I'm sure the WaitCommand itself doesn't require a subsystem, and neither do a lot of the commands that our team used this year.
Unread 11-04-2014, 07:01
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Our team uses States to determine what to do. Drive has a State Machine that is independent of the Shooter. Delays are implemented using timers. Set a timer, and check the time each loop.
Note: Having everything doing "nothing" requires a little thought. Do you disable the compressor so it does not run too? If you are moving, do you stop moving (and if so, how? Drop power abruptly, or gradually)? etc.
