Go to Post The gearbox can be anything, just as long as it weighs less than 0 lbs, and yes, I'm talking about negative weight here. - NoodleKnight [more]
Unread 03-04-2014, 12:35
Rob3653's Avatar
Rob3653 Rob3653 is offline
Alumni
FRC #3653 (Botcats)
Rob3653 is an unknown quantity at this point
Starting configuration in the Goalie Zone
Hello, I have a question about the starting configuration in the goalie zone.
Are we allowed to start with an arm that is about 8 ft high at the start of the match? Can you cite the rule please?
Thanks!
Unread 03-04-2014, 12:39
AdamHeard's Avatar
Lead Mentor
Re: Starting configuration in the Goalie Zone
Just for a little exercise, can you cite a rule saying you CAN'T start 8' tall in the goalie zone?
Unread 03-04-2014, 13:12
rlowe61's Avatar
rlowe61 rlowe61 is offline
AKA: Roger
FRC #0624 (CRyptonite)
rlowe61 has a brilliant futurerlowe61 has a brilliant futurerlowe61 has a brilliant futurerlowe61 has a brilliant futurerlowe61 has a brilliant futurerlowe61 has a brilliant futurerlowe61 has a brilliant futurerlowe61 has a brilliant futurerlowe61 has a brilliant futurerlowe61 has a brilliant futurerlowe61 has a brilliant future
HINT #1
Here is part of the answer:
3.2.5.6 G23
If a ROBOT is in contact with carpet in its GOALIE ZONE, and for only one ROBOT per ALLIANCE at a time, ......
But don't just look at the one place in the rules. Remember many places in the rules cover the robot and what can and can't be done.
Hint #2
There is another part of the rules that mentions "STARTING CONFIGURATION"
Happy Hunting.
Roger
1986, Team Titanium, 2011 - 2012
624, CRyptonite, 2013 - ????
Unread 03-04-2014, 13:34
tanmaker
Posts: n/a
There is nothing in the rules that gives a maximum height for the starting configuration. We talked about this at OKC and allowed a robot starting in the goalie zone to have an unlimited height. We had Frank Merick there too, so I'm guessing if that wasn't allowed, he would have said something.
Unread 03-04-2014, 13:58
rlowe61's Avatar
AKA: Roger
Hint #2
4.1.4 R4
In the STARTING CONFIGURATION, the ROBOT must constrain itself such that no part of the ROBOT extends
outside the vertical projection of the FRAME PERIMETER, with the exception of minor protrusions such as bolt heads,
fastener ends, rivets, etc.
Nowhere does it state a horizontal limit.
Roger
Unread 03-04-2014, 13:59
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
I went back and re-read the rules and the glossary for STARTING CONFIGURATION and I think your interpretation at OKC was correct. I didn't catch that one.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 03-04-2014, 14:09
tanmaker
Posts: n/a
Originally Posted by rlowe61 View Post
Hint #2
4.1.4 R4
I'm guessing you meant to say vertical instead of horizontal.
Unread 03-04-2014, 14:17
themccannman's Avatar
themccannman themccannman is offline
registered lurker
AKA: Jake McCann
FRC #3501
themccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond repute
Hint #2
4.1.4 R4
It states the horizontal limit right there. "no part of the robot extends outside the vertical projection of the frame perimeter." That means the imaginary vertical wall that is 20" from your frame. There is no rule however stating that vertical height limits are any different in starting configuration than they are during tele-op.
All posts here are purely my own opinion.
2011-2015: 1678
2016: 846
2017 - current: 3501
Unread 06-04-2014, 10:14
RallyJeff's Avatar
RallyJeff RallyJeff is offline
FRC Referee & FLL Many-Hats-Wearer
AKA: Jeff Hagan
Rookie Year: 1995
RallyJeff has a spectacular aura aboutRallyJeff has a spectacular aura aboutRallyJeff has a spectacular aura about
The frame perimeter is the imaginary vertical plane defined by the outside face of the frame.
The 20" distance you mentioned has to do with the restriction during the match, not the starting configuration.
Unread 06-04-2014, 10:20
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
You do know there is a ceiling? Would that be considered contact outside of the field?
Unread 06-04-2014, 10:26
samfruth's Avatar
samfruth samfruth is offline
FRC #1710 (Ravonics Revolution)
Team Role: Driver
samfruth will become famous soon enough
You can extend as high as you want, as shown by our static 8 ft robot . But the biggest problems we came into were doors and loading onto the field.
Unread 06-04-2014, 15:00
registered lurker
AKA: Jake McCann
FRC #3501
Whoops, I didn't mean to put in the 20", I was just referring to frame perimeter limits.
2011-2015: 1678
2016: 846
Unread 07-04-2014, 11:20
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Looks like you can have an 8' robot. Just be careful to always be in contact with the goalie zone.
In theory an opponent can push you out of the goalie zone. I would not call that a G14 violation because the purpose of pushing you out is to get you to drop to 5' to make their shots easier. Just because your robot is incapable of dropping below 5' is not their problem.
Unread 21-04-2014, 12:23
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Another question as per the rules, can a Goalie robot be pre-placed anywhere in the goalie zone or does it need to start centered and move itself to defend the goal after autonomous starts?
Unread 21-04-2014, 12:27
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
It may be placed anywhere, but you have to declare a final position, after which offensive (non-goalie zone) bots get to pick positions.
