Go to Post Anyone know anything about a missing plastic flamingo from NASA HQ? I should mention before you answer that tampering with federal property, even if it's weird stuff from (Dave's) office, is punishable by painful delivery of ChiefDelphi negative rep points. - Rich Kressly [more]
Unread 06-04-2014, 14:20
Chris is me's Avatar
AKA: Pinecone
Re: Best Wheels For Drop-Center Drivetrain.
Honestly, with the number of COTS options it's hard to go wrong here.
KoP wheels are fine. Cheap, easy to use. Not the grippiest but good enough to get you going, and better than past options.
Colsons are a very good grip and very low maintenance wheel. You will not need to replace your competition robot's wheels within a regular season. They aren't too expensive even with the hubs. Main drawback is weight.
Treaded traction wheels (either VexPro Traction or AM Performance) combined with roughtop tread are the best commonly available off the shelf traction solution. The gains in traction come with the cost of regular maintenance as these wheels require tread changes fairly often. Expect to change tread at least a few times a season.
Ultimately, I think Colsons are close enough to optimal that they're the best option for a lot of teams and drivetrains, but really any of the above can work. I have heard good things about VersaWheels but I do not have first hand experience.
