Go to Post Our coolant system consists of a freshman with a squirt bottle. - Holtzman [more]
Unread 06-04-2014, 14:56
Chadfrom308's Avatar
Chadfrom308 Chadfrom308 is offline
Slave to the bot
AKA: Chad Krause
FRC #0308 (The Monsters)
Team Role: Driver
Chadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to behold
pic: 308's Shredded mini CIM pinion
Unread 06-04-2014, 14:58
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Re: pic: 308's Shredded mini CIM pinion
Could you give us more information on the toothcount, load, gearbox, material, supplier, runtime, lubrication, etc? We've seen similar failures of an old run of the WCP 11T pinions before, but nothing that looks quite like that.
-Plutarch
Unread 06-04-2014, 15:12
MrBydlon's Avatar
MrBydlon MrBydlon is offline
AKA: Jeremy Bydlon
FRC #3313 (Mechatronics)
MrBydlon has much to be proud ofMrBydlon has much to be proud ofMrBydlon has much to be proud ofMrBydlon has much to be proud ofMrBydlon has much to be proud ofMrBydlon has much to be proud ofMrBydlon has much to be proud ofMrBydlon has much to be proud ofMrBydlon has much to be proud ofMrBydlon has much to be proud of
We had an extremely similar problem this season. We competed at two Regionals for the first time this year and used the new AndyMark14U KOP chassis. We used the standard Mini-Cims with 2 CIMs on each side of the drive train.
2 gears stripped
During our last Regional, in the semifinals and finals, we basically could not drive on the right side. During the finals, we investigated and found that the 14-tooth gears that are attached to the Cims were stripped bare. Unfortunately, we had no replacements so we had to just roll with it.
Here is a link to the specific gear that we had such trouble with. CIM gear, 14 tooth
We were planning on emailing AndyMark in the future to let them know about the situation.
We attribute it to poor lubrication. We accept some responsibility on this. We should have greased them during both Regionals. We have played a combined about 45 matches in 2 Regionals (finals reached in both). However, there was a very small amount of grease provided in the package initially. So even from the start, we believe they were poorly lubricated.
Anyway, we have bought replacements for Champs and will put them in there.
Head Coach
FRC Team 3313 Mechatronics
Alexandria, MN
2014 10,000 Lakes: Chairman's Award Winner
2014 10,000 Lakes: Winner with 2052 and 2227
2014 Lake Superior: Finalist and Engineering Excellence
Website Twitter Facebook YouTube
Unread 06-04-2014, 15:31
Best Available Data
FRC #1778 (Chill Out!)
We've seen similar failures with the AndyMark kit gearboxes. We were never able to confirm how well they were initial greased, but when the gears look like that they probably aren't being greased well. The Andymark grease packets are quite small and may be applied by people who don't know how important it is. We now liberally grease them with our own big bucket of grease to ensure they don't run dry and haven't had another failure.
Unread 06-04-2014, 15:48
MrBydlon's Avatar
AKA: Jeremy Bydlon
Count this season as a "lesson learned" for our team. We've never had a robot play this hard, this much, this fast. We have a giant tube of red grease ready for champs.
Head Coach
Alexandria, MN
Unread 06-04-2014, 16:49
Slave to the bot
AKA: Chad Krause
Team Role: Driver
The gear was on a miniCIM on a toughbox paired with a big CIM for the drivetrain. We have 4 big CIMs and 4 mini CIMs on our drivetrain(one pair on each mecanum wheel) and this particular wheel was sounding weird. We ended up playing a few more matches on it because the time it takes to replace it.
Anyways, we opened the toughbox mini and a whole bunch of powder fell out of it. Apparently, they were not greased enough.
We used the standard Andymark grease and some of it got lost in the transition. (The toughbox was mounted directly to the chassis)
We replaced it and added as much grease as possible, and so far, no problems
Unread 06-04-2014, 19:22
Iaquinto.Joe's Avatar
Iaquinto.Joe Iaquinto.Joe is offline
RPI 2018
AKA: Joe Iaquinto
Iaquinto.Joe is a jewel in the roughIaquinto.Joe is a jewel in the roughIaquinto.Joe is a jewel in the rough
And despite having one motor less on one corner, the bot still drove straight! It's all due to the fact that each encoder rate is controlled with a PID relative to the driver's inputs. Additionally, a PID is used with our current gyro angle and desired angle. The result is a robot that fights back on it's own when you apply an external force!
4 year 2011 - 2014 FRC team 308 member, Lead Programmer - C++ / LabVIEW
3 year 2011, 2013, 2014 OCCRA member, Co-Captain OCCRA team 308
  • OCCRA Engineering Excellence - Waterford Kettering 2013
  • Innovation in Control - 2011
  • Quality award- Northville 2012
  • Engineering Excellence- Howell 2014
  • Innovation in Controls- Livonia 2014
Unread 06-04-2014, 19:29
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
After seeing what happened to your gearbox, I am getting worried that the same thing could happen to us soon because I am pretty sure we only used the grease that was included with the gearboxes.
In 2010, we lost in the quarterfinals partially due to a busted gearbox.
