Go to Post Getting a swerve to drive predictably and effectively is arguably harder than designing and building it. - Holtzman [more]
Thread Tools Rating: Thread Rating: 18 votes, 5.00 average. Display Modes
  #31   Spotlight this post!
Unread 06-04-2014, 16:40
Chadfrom308's Avatar
Happy Birthday! Chadfrom308 Chadfrom308 is offline
Slave to the bot
AKA: Chad Krause
FRC #0308 (The Monsters)
Team Role: Driver
Chadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to behold
Re: Swerve Drive vs Mecanum Wheel drive?
We have actually never had any problems with our encoders, even when one broke, the rest of the PIDs made up for it.
As for Field Centric, we never used it. It is way faster to do robot centric.
85% of the time, we don't use the strafing feature of the mecanums. But, the most important 15% we use them. (Like lining up the 1pt goal and lining up for inbounding)
And that has made it worth while
  #32   Spotlight this post!
Unread 06-04-2014, 16:43
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Is there something unique about the way you did it?
Field oriented control has been around for a number of years. It's built-in to LabVIEW and WPILib for Java and C.
It's most unique aspect is that it could automatically correct its orientation when we were pushed or lost traction on a wheel, which made our system much easier to control than it would have been without it and it allowed us to travel in an absolutely straight line, unlike it the past where going sideways often went in an arc instead. This prevented us from needing to be so obsessive about weight distribution, because we could just let software fix our problems.
  #33   Spotlight this post!
Unread 06-04-2014, 17:01
Share the technology: write a paper!
I read about the idea on CD and decided to implement it...
... and give credit where credit is due
  #34   Spotlight this post!
Unread 06-04-2014, 17:07
Dartmouth 2020
AKA: lopsided98
I don't have time to write up about it at the moment but I probably will during the offseason. For now, here is the code for it if anyone is interested in looking at or adapting it for their own use: https://github.com/RobotsByTheC/CMonster2014.
I would tell where specifically I got the idea from on CD, but I don't really remember anymore.
Last edited by Ben Wolsieffer : 06-04-2014 at 17:08. Reason: restructured sentence
  #35   Spotlight this post!
Unread 06-04-2014, 17:19
foote stepped in
AKA: E. Foote
FRC #0868
As a mecanum lover, it really annoys me when people automatically rule out mecanums when the really don't know what they are capable of. Our robots in 2010 (http://youtu.be/rdAKiuimaY4?t=58s) and 2012 (http://youtu.be/tdAncHeHOEQ?t=1m36s) had mecanums and they could traverse the bump and balance on the bridge.
Yep. Same with my old team, and we were very competitive those years.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
  #36   Spotlight this post!
Unread 06-04-2014, 18:42
JohnM's Avatar
JohnM JohnM is offline
FRC #5854 (Glitch)
JohnM has a spectacular aura aboutJohnM has a spectacular aura about
This year is our first year using mecanum wheels, and I have to tell you, I love them. I'm not a big fan of trying to switch to swerve drive next year because we still have not mastered mecanum wheels.
John M
  #37   Spotlight this post!
Unread 07-04-2014, 00:21
kk052's Avatar
kk052 kk052 is offline
CAD extraordinaire
AKA: kyle lundquist
FRC #2517 (the green wrenches)
Team Role: CAD
kk052 can only hope to improve
this year was our first time of swerve, that said it saved our robot, it defenetly has its benifits, and if you where just given both drives on the feild without the need to make or program them, swerve will usually win over machanum. but there are businesses that sell machanum (get them from andymark), but there are none that sell full swerve drives, even though you could buy the lower end of the andymark crab drive, so it will come to desighn, if you biuld a good working swerve, it will beat mach, but if your swerve isn't well made, like how our encoders would slip on our's (locktite fixed that) it will not even move. i would recommend adding a third option of a dual drive/octanum, for a well made swerve will nearly always win a machanum.
FRC TEAM 2517 The Green Wrenches
2012 Autodesk Oregon regional
Chairman's award, Entrepreneurship award, Pit safety award
2013 central Washington regional
Imagery award, Pit safety award
2014 we won something but i forgot
-"the CAD is only accurate if you machine it accurate!!!"
--"its not working because your doing it wrong!!!"
---"is it really ok to put an acronym in an acronym?" (FIRST)RC?
  #38   Spotlight this post!
Unread 07-04-2014, 00:38
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
The problem with mecanum IMO is that they are basically the end. Apart from octacanum drives, mecanums don't have many places to go to design-wise. I think they will remain the same for a long time.
Swerve and tank drives, on the other hand, have a room for improvement. 221's Revolution Swerve weighs only a couple pounds per wheel, and their in-wheel Wild Swerve is fantastic. However, I still think that there is room for improvement- nobody's just found it yet.
Tank drives have changed little over the past few years, but gearboxes get more interesting every year.
  #39   Spotlight this post!
Unread 07-04-2014, 12:56
I can think of several directions for improvement of mecanum-style wheels. Figuring out a way for the rollers to never stick would be at the top of my list, followed by a simple roller lock to improve the maximum forward torque before losing traction, and eventually adding powered rollers to give better sideways power.
Optimizing mecanum material selection and mechanical design isn't done at all. Just increasing robustness while decreasing weight would go a long way toward making mecanum wheels better for FRC team use.
  #40   Spotlight this post!
Unread 07-04-2014, 13:22
XaulZan11's Avatar
XaulZan11 XaulZan11 is offline
AKA: John Christiansen
FRC #1732
XaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond repute
Send a message via AIM to XaulZan11
I'd agree with this 100%. But, at least in 2012, I think you were competitive because of your accurate shooter and probably not your drive train (I wonder if you would have been better on bridges with a traction drive). Like you mentioned earlier with the good teams that build swerve probably are the teams with good scoring mechanisms and good team organization. These teams will be competitive no matter what drive train they select. Drive train selection is even more important for the fringe competitive teams; teams who may or may not have consistent scoring mechanisms or who may or may not have ample time to practice. The competitive teams that will have consistent scoring mechanisms and gave their drivers enough practice will be competitive with a swerve, tank or mecanum drive.
  #41   Spotlight this post!
Unread 07-04-2014, 14:26
The Doctor's Avatar
The Doctor The Doctor is offline
Robotics is life
AKA: Hackson
FRC #3216 (MRT)
The Doctor is on a distinguished road
My experience with mecanum is that it causes a serious power drain when strafing (going sideways). Our battery is usually at 11.5v when going forward (using 4 CIM motors & Toughboxes), but it drops to 8v when strafing.
  #42   Spotlight this post!
Unread 07-04-2014, 15:07
Too much friction in the rollers.
It can be quite tricky to obtain an acceptably small level of roller friction in the affordable COTS mecanum wheels used by most FRC teams.
  #43   Spotlight this post!
Unread 08-04-2014, 21:32
ekapalka's Avatar
ekapalka ekapalka is offline
FRC #3216
ekapalka has a spectacular aura aboutekapalka has a spectacular aura about
Originally Posted by BBray_T1296 View Post
They work an unbelievably better when controlled by encoders and PID
I've heard that PID control begins acting unusually when you have a constantly moving setpoint because the tuning parameters were only set for one particular speed. Is that not so, or has your team found a way to work around this (such as a lookup table for different setpoints)? My team never really got around to putting encoders on our wheels, and as a result wound up tediously multiplying each wheel by a particular constant depending on its direction (because our motors have a 20-30% speed bias in a particular direction), which was a pain to figure out through trial and error.
I've been tentatively skimming through this code for around half an hour and can't seem to find where the magic happens... I'm not particularly accustomed to the command based model :P Could someone point me in the right direction? Thanks!
  #44   Spotlight this post!
Unread 08-04-2014, 21:43
Niezrecki's Avatar
Niezrecki Niezrecki is offline
AKA: Justin Niezrecki
FRC #1124 (ÜberBots) + FRC #5686 (Wirecats)
Niezrecki has a spectacular aura aboutNiezrecki has a spectacular aura aboutNiezrecki has a spectacular aura about
Originally Posted by Joe195 View Post
Overall, swerve drive has much better control, but is very challenging to design and program. Mecanum is easier to program, but doesn't give you the same power. I would say swerve drive is better, but only if your team can use it to its fullest potential
I am in full agreement. We have done swerve drive before and it has the ability to keep control and deliver some amount of force as well. Swerve also commonly consists of one CIM per wheel which delivers a nice amount of power. Mecanum has a history of being pushed quite easily in FIRST and tends to impress other teams less. Swerve however definitely delivers a better turning capacity than Mecanum. It's also beautiful to watch. I am looking at you Apple Pi (2014).
  #45   Spotlight this post!
Unread 09-04-2014, 13:06
Citrus Dad's Avatar
Citrus Dad Citrus Dad is offline
Business and Scouting Mentor
AKA: Richard McCann
FRC #1678 (Citrus Circuits)
Citrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond repute
From a scouting perspective, we heavily discount robots with mecanum drive because they don't have the same defensive abilities as tank drive. To be honest, we haven't see a high-scoring mecanum drive robot, even at Worlds, so I don't have an opinion about the use there.
Offensive robots with swerve are amazing. 368 was amazing on our alliance at SVR, and of course 1717 has produced some of the best robots possible.
My assessment: if you're not ready to contend for being one of the very best robots at your regionals, then stick with tank drive, but if you're going to make that plunge, choose swerve over mecanum.
