Go to Post If you want something done about it, than do something about it. - Tetraman [more]
Unread 07-04-2014, 13:50
tkbletsc tkbletsc is offline
FRC #4561
tkbletsc is just really nicetkbletsc is just really nicetkbletsc is just really nicetkbletsc is just really nice
Layout of off-board compressor (featuring sweet pics)
Our team is doing an off-season build competition that may involve pneumatics, but we don't have a compressor for every team. This means doing an off-board compressor design, but I can't find much info on how to actually do that.
Here's the standard pneumatic layout:
If I charge the system and simply remove the compressor, the air just escapes.
So what if I put a valve after the compressor?
That way when the system is charged, I close it, then remove the compressor.
Only one problem: if I accidentally leave the valve closed when I charge, I'm going to be charging just 6" of tube, and I'm going to have a bad time.
We have the emergency relief valve on the compressor, but I'd rather not rely on that. How are you "supposed" to do it?
Unread 07-04-2014, 13:59
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: Layout of off-board compressor (featuring sweet pics)
See images 4-16 and 4-17 in the Robot Rules, R85/86.
You need to have the pressure relief valve (the blow off valve set to 125PSI) attached directly to the compressor, and a second relief valve on the robot (R87)
You can have the regulator, pressure switch, and pressure gauge (for stored pressure) either on board or off board, so long as they are all together - either all on or all off. If they are off board, then you only have 60 PSI available for storage on the robot.
Most teams will plug it into the manual pressure vent valve in order to charge their system. If you do this, make sure there is a second manual valve somewhere so there is a way to relieve the pressure manually even while charging the robot.
2016: Lake Superior WFFA
Unread 07-04-2014, 14:15
FRC #4561
I'm sorry, I still don't understand. In the pictures you referred to, what prevents all the pressurized air from escaping when you remove the compressor?
Whoosh:
Unread 07-04-2014, 14:34
Mentor, LRI, MN RPC
The pictures don't show it, but you need to have a manual valve in place on the robot side that you can close to prevent the air from escaping.
Unread 07-04-2014, 14:42
Jared Russell's Avatar
Taking a year (mostly) off
That's what the emergency relief valve is there for.
Unread 07-04-2014, 16:29
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
What you need to do is get one of these (similar ones can be found in assorted pneumatics parts that come in old kits or from FIRST Choice):
and connect one of these to it:
Unread 07-04-2014, 16:38
Nate Laverdure's Avatar
FRC #2363
Schematically, your legal options look like this:
Standard "on-board" compression
"Off-board" compression
"Seriously off-board" compression
Unread 07-04-2014, 16:48
Chris is me's Avatar
AKA: Pinecone
For our robot this year, we would plug the offboard compressor into a fitting attached to a manual valve. The other end of the manual valve was attached to a T, which itself was attached to an additional manual valve and our stored pressure regulator / automatic relief valve. After this collection of brass and hardware, we ran a tube to the first storage tank and the rest is the same as an on-board setup. I can post a picture if needed.
Unread 07-04-2014, 23:20
CENTURION's Avatar
CENTURION CENTURION is offline
King of unreasonable designs
AKA: Evan the Shop Princess
FRC #1306 (BadgerBOTS)
CENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant future
You could also hook up a quick-disconnect fitting like this one:
http://www.hydraulic-supply.com/imagesorg/aqpfd41.jpg
Instead of having a manual valve at the point the compressor attaches.
It solves your problem of accidentally trying to charge only a 6" section of tubing, instead of the whole system.
It's also designed to be connected and disconnected many times, whereas the standard kind of tubing fittings used in FRC are really not meant to be used that way (Though they do hold pretty up well under that sort of use).
You can put the male connectors on each pneumatic system, and just one male connector on the hose/tubing coming from your compressor.
Another bonus: These can often be found at local hardware stores, they'll probably be with the air tools (Nail guns and the like).
As far as I know, these connectors are legal for FRC use (Though as you said this is an off-season project, that may not matter).
As others have said, you do need to have a pressure relief valve on the compressor. It's not just the rules; it's so that you don't blow anything up
FRC #1306 - BadgerBOTS - Mechanical/Machining/Safety/Marketing Mentor
FTC #6806 - Ratchet Robotics - Head/Founding Mentor
2010 - Wisconsin Regional Chairman's Award Winner - Wisconsin Regional Quarter-finalist - Curie Division #5 Seed, Quarter-finalist
2011 - Wisconsin Regional Innovation in Control Award Winner - Wisconsin Regional Quarter-finalist
2012 - Wisconsin Regional Engineering Inspiration Award Winner - Wisconsin Regional Semi-finalist
2013 - Wisconsin Regional Chairman's Award Winner
Unread 07-04-2014, 23:45
AKA: Pinecone
The quick disconnects don't seal themselves when not in use? You still need a manual valve between the quick connect and the rest of the system.
Unread 07-04-2014, 23:56
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
The female quick disconnects automatically seal. I think he made a typo
Unread 08-04-2014, 07:29
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
It is an R77-f part. Make sure it is COTS, and bring the pressure rating.
R75 - Must be rated for at least 125 psi. If rated for less, at a regional, we will let you use it if your switch and pressure relief valve are set for the lower rating (robot compliant with the spirit of the rule). At the championship, I am guessing they will not let you compete with the under rated component (robot fully compliant).
Unread 08-04-2014, 11:06
m1506m's Avatar
m1506m m1506m is offline
FRC #1506
m1506m is an unknown quantity at this point
Or use a Schrader valve
Unread 08-04-2014, 11:29
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
+1 to the quick disconnect idea. They come in very small sizes if weight is a concern. This is a standard in multiple industries for repeatedly connecting and disconnecting air lines. IMO this is how one is "supposed to do it."
Unread 11-04-2014, 23:16
CENTURION's Avatar
Oops! Yes, I meant to say that the female connectors should be on the pneumatic system, and the male connector on the compressor.
