Go to Post For every hour you spend screwing pieces of your robot together, 20 hours of important stuff goes on behind your back. - Eric Bareiss [more]
Go Back   Chief Delphi > Competition > Championship Event
Unread 07-04-2014, 17:46
popnbrown's Avatar
popnbrown popnbrown is offline
FIRST 5125 HOTH Lead Mentor
AKA: Sravan S
FRC #5125 (Hawks on the Horizon)
popnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond repute
Re: Crate Help
Originally Posted by Mark McLeod View Post
We add eyelets to the sides around the bottom and midway up the crate to use as tiedown points. Then use wide straps wrapped around the robot bag mid to top points of the robot superstructure that gets tied to the mid-level eyelets. Same around the bottom.
I think I understand the bottom, I'm not exactly sure how you tie it down in the mid. Do you wrap it around the robot and basically tighten it enough so that the robot would be hitting the wrap either way it went?
We reinforce the walls of the lower foot or so of the crate on the two forklift ends to better sustain incidental forklift misses. I'd suggest putting the door, especially if it's hinged, on a side the forklift won't use. We've lost a couple of doors to near misses by forklift operators over the years.
How do you reinforce the lower foot? I'm planning on building a frame and mounting the 1/2" plywood to the frame. So there's a 2x2 at the bottom of all four sides, do you recommend throwing another 12" piece of 1/2" plywood at the bottom?
I am an employee of FIRST. However, the postings on this site are of my own perspective as a FIRST mentor and volunteer and do not necessarily reflect the views of FIRST.
FIRST Team 5125 Hawks on the Horizon Lead Mentor
FRC Team 4096 Ctrl-Z Former Mentor
FTC Team 5203 #19@! Former Mentor
FRC Team 1403 Cougar Robotics Alumni
Unread 07-04-2014, 20:51
Re: Crate Help
It depends on what shape the superstructure takes, but in general the strap is tight around some firm or substantial parts of the robot high up around the bag. Then the strap is tied to the eyelets either with left over strap or additional pieces of rope.
It forms a sort of spiderweb cushion for when the crate is tipped. Even tight, the ropes give a little spring to absorb shocks from drops, tilts, rough roadbeds.
We add additional inside plywood for a foot or two up the front and back. The highest a forklift has speared our crate has been about a foot and a half above the floor. None of our robots have been damaged luckily, but they have gotten through the first layer of plywood.
Unread 08-04-2014, 08:11
801DOC's Avatar
801DOC 801DOC is offline
FRC Team 801 and FRC Team 1592
FRC #0801 (Horsepower and Bionic Tigers)
801DOC is just really nice801DOC is just really nice801DOC is just really nice801DOC is just really nice
Re: Crate Help
Here is a picture of our crate at Championships last year. It is now in its 5th year and still going strong.
Its basic features are that it splits in half with shelves that can be stowed to accommodate the robot. It has 4x4s on the bottom to assist with forklifting and we use a removable transportation adapter that can be attached to our cart to move the robot around. We used a thinner plywood on the sides for weight and have transported a robot, bumpers, banners and a robot cart in the same crate in the past.
In the pits, we use the bottom half for tote storage and the top hals as a work space. We install lighting on the top to add additional lighting in the pits but they can be easily removed and positioned on the robot if needed.
I have a .zip file with detailed pictures and can email it to you, and anyone else who desires. I think there are currently 5-10 teams who are using this design.
EVERYDAY!
DOC
"If you can't be perfect, at least be unforgettable." -DOC
Unread 08-04-2014, 14:37
popnbrown's Avatar
AKA: Sravan S
Re: Crate Help
I'm going to be ambitious and go for this split design. How do you hold the two half bottom pieces together? Unless the bottom piece comes out completely?
