Go to Post Strive for excellence in everything you do, but also recognize it in others when you see it, rather than try to drag it down. - Joe G. [more]
Unread 07-04-2014, 12:18
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
G27 Standard
I hope for the Championship, there is a clear standard for G27. During the WI Regional, the G27 rule was updated, and any high speed ramming was called.
During Midwest Regional, only damaging high speed ramming or "inhibition", was called.
The problem with damage is: It is really hard for the Ref's to see damage real-time. Unless a piece comes flying off, or gets severely distorted, how can you tell?
I hope they update G27 to be a clear standard. If damage is the criteria, then teams should be allowed to show damage after the game.
Also, what is the purpose of "inhibition"? If Red prevents Blue from taking a shot, or picking up a ball, why is that not good defense? What is the difference if Red does it full speed, or 1/2 speed? These bots can get up to full speed in one or two bot lengths.
Ditto on G28 - Contact inside the frame perimeter. I think this is more of a problem. There is a lot of contact inside the frame perimeter. But, it is really hard to see damage, such as cutting pneumatic tubing. I think almost any contact inside the frame perimeter should be called. The only exception being if the other bot initiated the contact.
Unread 07-04-2014, 13:14
Anthony Galea's Avatar
Anthony Galea Anthony Galea is offline
Formerly known as 3175student17
Anthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant future
Re: G27 Standard
What would you call the contact that happens around 0:35-0:45 here in the red alliance zone? As a driver, I was confused as to why a foul was not called. It would not have changed the outcome of the match, I would just like to know what others would think. Blue robot was caught in red's shooter, as a result of passing by after intaking the ball.
2013-2016: FRC 3175 Knight Vision, student
2014 Center Line District Finalists with 815 and 280
2016 Woodhaven District Winners with 3604 and 6116
2017-?: Rose-Hulman Institute of Technology
Unread 07-04-2014, 13:23
jlmcmchl jlmcmchl is offline
FF - The Breakfast Company
AKA: Jordan McMichael
FRC #0027 (Team RUSH 27)
jlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud of
Re: G27 Standard
Conversely, I've been confused by the calls made in the St Joe Finals 1-1. Here I believe a penalty was called on 27 of possession of the opponent's ball. That would not have changed the outcome of the match, had it not been called. However, a technical was called here on blue for intrusion into the opponent's perimeter, and I can't figure out how the ref came to that conclusion.
These calls were made in week 5, after most or all of the rule changes had been made.
While these calls leave me frustrated and uncomfortable, I'd like to hear another opinion because I can't figure out what the ref was thinking.
Field reset: Kettering Kickoff ('13, '14), Kettering ('14, '15), Bedford ('14), Woodhaven ('16), Carver ('16), Einstein! ('16)
Referee: Bedford ('15), MARC ('15, '16), Kettering Kickoff ('15, '16), Kettering District (#1&2: '16), Troy ('16)
Unread 07-04-2014, 14:50
Re: G27 Standard
G28 - contact inside the frame perimeter, requires either: Deliberate, or damaging contact. Red 862 did not deliberately contact Blue 3175. Blue 3175 was driving by when it became entrapped. It does not appear that Blue 3175 was damaged. Had Blue 3175 suffered damage (let's say the pole became detached), then there would be a Technical on Red 862 (that is the risk Red takes for having an extended element).
Unread 07-04-2014, 15:04
Re: G27 Standard
Had Blue 17 merely deflected the ball, and it stayed in the field, then I think it was not possession. However, when the ball left the field, it could have been considered Launching, and not Deflecting.
I don't see it either. But, the Ref had a much different angle, and could have seen something. I'm guessing the contact was with the red bot between the blue bot and the Ref, as opposed to the red bot that is closer to the camera.
Unread 07-04-2014, 19:28
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Re: G27 Standard
This call will be like so many others this year and will never get better. Another from St. Joe was in Q47 on us at 2:06 as seen in the video here
Our "wings" are fully within our perimeter unless they are outside of it by the full 16" of extension we gave them.
But, a judgement call is a judgement call. The problem is when a judgement call can take away from students levels of inspiration. Some students expressed that it is hard to have faith in something when a call isn't made on something as black and white as a g28, and also when they are left as grey as a g27.
Edit to add: I think that St. Joe was the first time I saw the game played how it was intended to be played. Rough but not excessive. It was made up of some fast offense, some harsh defense, and mostly clean play sprinkled in between. I don't want to derail this thread away from the OP's point. The only thing to take from my post in regards to that is that this will always be an area decided by the ref on that field, and I don't see how you can put a solid standard to it. Unless we all have impact measuring gauges on our robots, or refs are given radar guns to measure speed prior to impact. Either way, those are more things for a ref to pay attention to, and they have enough on their plates as is.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 07-04-2014, 19:56
TikiTech's Avatar
TikiTech TikiTech is offline
Mr. H
FRC #3880 (Tiki Techs)
TikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really nice
Re: G27 Standard
I think you are correct that a G28 foul should of been called due to damaging contact inside your frame. I do not believe a G27 is warranted since this does not look like a strategy to do deliberate damage.
Were you given a foul for a G24 and an extended G24 technical foul for continually being outside the 20" perimeter?
This is the same situation that happened in Waterloo.
Very unfortunate. It seems that at every event there has been calls that are missed as well as not consistently called. Let alone the FMS...
There were similar issues at our event in HI. We left the field with our 1/8" thick 2x3 pickup system bent and all the welds broken.
I think the small warning in the manual for designing your robot systems robustly should of been bolded and in multiple blue boxes..
A rough game this year is an understatement.
Team 3880 - "Tiki Techs" "Mr. H" - Tiki Technologies Coach / Mentor
Kealakehe High School Robotics - Kailua-Kona, Hawaii
__________________________________________________ _____________________________
2016 Hopper Division | Orlando Regional Engineering Inspiration Award | Hawaii Regional Chairman's Award & Finalist & Woodie Flowers Finalist
2015 Carson Division | Silicon Valley Regional Engineering Inspiration Award | HI Regional Regional Winners & Engineering Inspiration & Deans List Finalist
2014 Newton Division | Hawaii Regional Engineering Inspiration Award & Deans List Finalist
2013 Newton Division | Inland Empire Regional Regional Chairman's & Creativity Award | Los Angles Regional Engineering Inspiration Award | | HI Regional
2012 Curie Division | Hawaii Regional Engineering Inspiration Award
2011 Newton Division | Hawaii Regional Regional Winners & Industrial Design Award
Unread 07-04-2014, 20:17
RCB RCB is offline
AKA: Chris
FRC #3620 (Average Joes)
RCB is an unknown quantity at this point
Re: G27 Standard
Correct me if I'm wrong, but wasn't that just the ref counting down for the two red bots 1502 and 3620 pinning 27?
I believe the technical was actually called here (notice the ref in the bottom left). I can't quite figure out why it was called though, considering how many things robots were getting away with at St. Joe. The way he looked inside 2337 makes me think he saw some kind of damage not visible to the camera, but then again, I don't really know.
I really wish things had gone differently and that our win had not been because of fouls. It was great playing with and against you guys and hopefully we'll see you again next year for a "rematch".
Unread 07-04-2014, 20:26
Re: G27 Standard
Yep, that's the "tomahawk" used to signal a pin count. Definitely NOT a foul or T-foul call.
That's not a technical call, though. Just a regular foul call. Not sure on what, though.
Signals all refs use: "Tomahawk" used to count down a pin, wave red/blue flag for a foul, if Technical foul, follow the foul call by crossing arms in an "X". Pointing at the violator is often used as well. (Some refs will also point at a loose dead ball; most will give a "safe" signal after a pin clears though I didn't see one in the first video.)
Unread 07-04-2014, 21:25
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
Re: G27 Standard
Deflecting versus launching isn't related to in-vs-out of the field. Launching is to a "desired" location, but if the refs thought this location was desired, a G11 would be up. Launching for its part, though, also requires a mechanism in motion relative to the robot. I don't see this in the video, and if this is so, the action cannot meet the definition of launched. If it was indeed a G12 instead of a G11 (I don't see "intentionally" in the video, but I wasn't there), then it wasn't G12c. I suspect there are some ref crews out there that would call it G12b.
Actually, G27 does not require strategy--it can include strategy and/or game play. If the damaging game play was determined to include "actions such as high-speed or repeated, aggressive ramming, attachment, tipping, or entanglement", G27 is warranted regardless of strategic intent.
Unread 07-04-2014, 21:32
Re: G27 Standard
My guess is that it was not called because none of the Ref's saw it. It looks like you had 5 refs. 4 Refs are watching the ball, and the collision happened away from the ball.
I hope at St. Louis, there are 9 refs for each match. Two at each pad, and the Head Ref. The 4 pad refs watch the ball, and the other 4 refs watch their area away from the ball.
Unread 08-04-2014, 11:32
Re: G27 Standard
No foul for us, we went to the wall and parked it as soon as that happened and didn't interact with the ball or other robots at all. I asked if we should disable, and was told it wasn't necessary. The refs were very good about not penalizing for something way outside of your control.
Andrew Basse
Unread 08-04-2014, 11:35
Re: G27 Standard
I always felt like it looked like the head ref was looking straight at it and one other ref as well, but that might just be me.
That seems like an awful lot of refs to be watching the field. I think maybe one or two more at most would be useful. But whatever way it goes, hopefully the rest of this season works as it should and teams gain everything they can out of the experience that this year provides.
Andrew Basse
Unread 08-04-2014, 11:56
Siri's Avatar
Dare greatly
Re: G27 Standard
We did 8+1 refs at NYC elims. 4 for possessions (2 each per alliance) and 4 four fouls (mostly by half-field) plus the HR. I wish there were refs to do it that way everywhere. It's the first time in 3 events that every potential call/non-call we discussed had at least 2 sets of eyes on it, except for a few HP questions. 8+1 is the right number for this game. We ran 8 total in quals, which was also pretty solid.
Unread 08-04-2014, 13:10
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
Re: G27 Standard
I'm curious how you guys would have called this sequence of events in Semi's 2-2 at the OSU district. I'm starting it right before the g28 foul occurs in the lower lefthand corner. It was called on blue 3712 as time expired.
http://youtu.be/ECiXrExJupg?t=2m28s
(2015-?): 973
(2012-2015): 955
