Go to Post I don't think that FIRST is going to get better with a top down solution alone, it is going to take a grass roots effort to strengthen teams. That starts by teams getting off their "islands", self imposed or otherwise. - Fe_Will [more]
Unread 07-04-2014, 21:07
sthreet's Avatar
sthreet sthreet is offline
AKA: scott threet
FRC #4692
sthreet is an unknown quantity at this point
Using multiple classes in java to control one pwm
So I'm trying to figure out how to do multiple classes. This is the strucuture of the classes, where everything in events is a system on the robot.
http://www.chiefdelphi.com/forums/at...5&d=1396919131
The problem is, I put all the pwm stuff in map, so when the second one runs it complains about that pwm already being assigned. How do I get around this?
Here is the error I get, incase I misinterpreted it:
Spoiler for blah:
[cRIO] Uncaught exception in Thread.run():
[cRIO] on thread edu.wpi.first.wpilibj.templates.IO - main
[cRIO] edu.wpi.first.wpilibj.util.AllocationException: PWM channel 1 on module 1 is already allocated
[cRIO] at edu.wpi.first.wpilibj.PWM.initPWM(PWM.java:114)
[cRIO] at edu.wpi.first.wpilibj.PWM.<init>(PWM.java:144)
[cRIO] at edu.wpi.first.wpilibj.SafePWM.<init>(SafePWM.java: 33)
[cRIO] at edu.wpi.first.wpilibj.Talon.<init>(Talon.java:48)
[cRIO] at edu.wpi.first.wpilibj.templates.outputmap.<init>(o utputmap.java:12)
[cRIO] at edu.wpi.first.wpilibj.templates.events.shoot.<init >(shoot.java:8)
[cRIO] at edu.wpi.first.wpilibj.templates.IO.<init>(IO.java: 24)
[cRIO] in virtual method #11 of com.sun.squawk.Klass(bci=53)
[cRIO] at com.sun.squawk.imp.MIDletMainWrapper.main(99)
[cRIO] in virtual method #95 of com.sun.squawk.Klass(bci=25)
[cRIO] at com.sun.squawk.Isolate.run(1506)
[cRIO] at java.lang.Thread.run(231)
[cRIO] in virtual method #47 of com.sun.squawk.VMThread(bci=42)
[cRIO] in static method #3 of com.sun.squawk.VM(bci=6)
Spoiler for gif:
Unread 07-04-2014, 21:11
NWChen's Avatar
NWChen NWChen is offline
Alum
NWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to behold
Re: Using multiple classes in java to control one pwm
Can you paste your map.java?
If at any point a conflict in PWM ports is detected your project will return an error and a stacktrace like the one you pasted. You will probably need to reassign the port in code, as well as move the physical cable itself on your Digital Sidecar.
2012 - 2015 • Team 2601
Unread 08-04-2014, 13:54
vgdude999 vgdude999 is offline
Programmer/Driver
FRC #1751 (Comsewogue Warriors)
vgdude999 is an unknown quantity at this point
If you declare a talon object in map.java, you can just make new variables in the two other classes that point to the existing object.
Ex:
Talon motor = map.getMotor();
Or just map.motor if you make it public, but encapsulation.
2013: Rookie year, programmer-in-training; SBPLI Regional Finalists
2014: Co-Captain, Programmer, Driver; Seeded 15th
2015: Co-Captain, Programmer, Driver
Unread 08-04-2014, 14:12
NWChen's Avatar
Alum
Ex:
@sthreet: Or this, in which case map.java would have to initialize your Talon objects with the constants, e.g.
Talon motor = new Motor(PWM_PORT_ON_DSC);
For this purpose you may want to look into the Singleton design pattern. Be careful that multiple classes aren't attempting to access the Talon object at the same time, which appears to be your initial problem.
Unread 08-04-2014, 16:27
sthreet's Avatar
AKA: scott threet
FRC #4692
Sorry, the one I was using as map was outputmap. I called it map in all the events though. (Map is inputmap, will go ahead and rename it.)
Spoiler for outputmap:
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.AnalogChannel;
import edu.wpi.first.wpilibj.Compressor;
import edu.wpi.first.wpilibj.DigitalInput;
import edu.wpi.first.wpilibj.Solenoid;
import edu.wpi.first.wpilibj.Talon;
public class outputmap
//output
public Talon leftdrive=new Talon(1);
public Talon rightdrive=new Talon(2);
public Compressor compress=new Compressor(1, 1);
public Talon loader=new Talon(3);
public Solenoid shootopen=new Solenoid(1);
public Solenoid shootclose=new Solenoid(2);
public DigitalInput winchstopper=new DigitalInput(2);
public DigitalInput winchstarter=new DigitalInput(3);
public Solenoid largeopen=new Solenoid(5);
public Solenoid largeclose=new Solenoid(6);
public Solenoid smallopen=new Solenoid(3);
public Solenoid smallclose=new Solenoid(4);
public Talon pickup=new Talon(4);
//inputs
public AnalogChannel distance=new AnalogChannel(1);
//constants
public int reversetimer=2000;
public int shoottimer=1000;
public int pistontimer=1000;
public int shootdistance=36;
public int slowdistance=24;
public int stopdistance=12;
Also, how do I make it public so I don't have to write:
import edu.wpi.first.wpilibj.templates.outputmap;
//inside of class
outputmap map=new outputmap();
every time?
Spoiler for gif:
Unread 08-04-2014, 16:42
Domenic Rodriguez's Avatar
Domenic Rodriguez Domenic Rodriguez is offline
FRC #0316 (LuNaTeCs)
Domenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura about
//output
//inputs
//constants
//inside of class
every time?
If you make the variables in the outputmap class static (i.e. class variables instead of instance variables), then you can access them directly without an instance.
    //output
    public static Talon leftdrive=new Talon(1);
    public static Talon rightdrive=new Talon(2);
// Somewhere else in the code
Talon myMotor = outputmap.leftdrive;
As was mentioned before, this is an example of the Singleton design pattern. Note that static classes are not necessarily the best way to handle this scenario. Another method is to have the class manage a single shared instance. See the WPILib DriverStation class for example.
LuNaTeCs - Learning Under Nurturing Adults Teaching Engineering Concepts and Skills - Small and Mighty!
FRC 316 LuNaTeCs - Student (2011-2014), Lead Programmer (2011-2014), Team Captain (2013-2014), Operator (2013), Drive Coach (2014), Mentor (2015-????)
'11 Philly Regional Finalists, '13 Chestnut Hill Finalists, '13 Lenape Champions, '13 Archimedes Division, '14 Chestnut Hill Champions, '14 Lenape Champions
FTC 7071 EngiNerds - Founding Advisor (2013-2014) | FRC 5420 Velocity - Founding Advisor (2015)
Grove City College Class of '18, Electrical/Computer Engineering (B.S.E.E)
Unread 09-04-2014, 16:58
sthreet's Avatar
AKA: scott threet
FRC #4692
Thanks, it worked perfectly. Doesn't seem to like multiple instances.
That is really weird, that you can access a static variable when you can't access a non-static one, I can see something like public/private/semiprivate where semiprivate is the same as current public and public is the same as current public static.
I do come from python and javascript though, so not having types to variables must be weird here.
Spoiler for gif:
Unread 09-04-2014, 23:50
Programmer/Driver
From my (very basic) understanding, non static variables and methods can only be used if an object of their class is created. So, if you kept the talons non static, you would have to actually create an instance of the outputmap.
So,
outputmap x = new outputmap();
Static variables and methods, however, do not require this.
Please correct me if anything I said is horribly wrong
Unread 10-04-2014, 06:19
So,
This is correct. Non-static variables belong to a specific instance of a class; each instance has it's own copy. Static variables belong to the class itself; they exist independent of an instance. Before, when the first instance of outputmap was created, it allocated the IO channels that OP was using. If a second instance was attempted, it would be trying to reallocate those IO ports. Since you can only have one instance of a given IO channel, an AllocationException was thrown.
