Go to Post FIRST robots definitely meet many commonly agreed upon definitions of robots. Some will disagree. Good for them. In my opinion, it's not worth arguing over. - Mikell Taylor [more]
Unread 07-04-2014, 15:23
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Passing/Trapping - Assist?
It just occurred to me: Trapping is "holding ... Balls agasint a ... Robot".
Situation 1: Two red bots are passing a ball between each other - bot to bot with bumpers touching. As soon as Bot 2 touches the ball, is that considered possession by Bot 2?
Situation 2: On carpet pass between Bot 1 and Bot 2. Bot 2 is having trouble picking it up. Bot 1 pushes the ball against Bot 2 to assist in the pickup. At some point, the ball is trapped between Bot 1 and Bot 2 while Bot 2 is trying to pick it up.
Are not both situations considered Trapping Possessions? The ball can be considered trapped by Bot 2 against Bot 1. So, does Bot 2 get a deemed possession?
Unread 07-04-2014, 15:43
MrTechCenter's Avatar
MrTechCenter MrTechCenter is offline
INTENSITY
AKA: Harsharan "Harsh" Dhaliwal
FRC #2073 (Eagleforce)
MrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant future
Re: Passing/Trapping - Assist?
It might be considered possession at one regional and not at another, just depends on the officiating.
2011 Sacramento Regional Finalists; 2011 MadTown Throwdown VIP Excellence in Engineering Award; 2012 Sacramento Regional Innovation in Control Award; 2012 Silicon Valley Regional Judges' Award; 2012 CalGames Autonomous Challenge Award; 2012 MadTown Throwdown Finalists; 2013 P0W3RH0U53 PWNAGE Gracios Professionalism Award; 2014 Central Valley Regional Innovation in Control; 2014 Sacramento Regional Innovation in Control; 2014 Curie Division Gracious Professionalism Award; 2015 Sacramento Regional Innovation in Control
Unread 08-04-2014, 08:20
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Passing/Trapping - Assist?
I would think trapping would be applied to red robot alliance doing that to blue robot alliance
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 08-04-2014, 14:37
Shanmancan Shanmancan is offline
AKA: Noah Shandelman
FRC #1712 (Dawgma)
Team Role: Driver
Shanmancan is an unknown quantity at this point
Agreed, trapping only applies when a robot is purposefully attempting to keep an apposite alliances ball away from them by using field elements or other robots on your alliance.
G12
An ALLIANCE may not POSSESS their opponent’s BALLS. The following criteria define POSSESSION :
D. “trapping” (overt isolation or holding one or more BALLS against a FIELD element or ROBOT in an attempt to shield them).
Unread 08-04-2014, 16:16
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
G12
You'd (and I'd) think it should be, but it's not. I Q&A'd it a while ago.
Q. Is is possible for G12d to apply to an offensive robot (robot with its own ball)? i.e. Can "trapping" lead to an ASSIST-eligible POSSESSION [provided 3.1.4 and other rules are otherwise followed], as offensive play wouldn't be "an attempt to shield [the ball]"?
A. Yes.
They really, really, ought to change this verbiage in the rule. The inconsistency continues to be ridiculous.
Unread 08-04-2014, 16:29
Josh Goodman's Avatar
Josh Goodman Josh Goodman is offline
The Voice of WNY
FRC #1511 (Rolling Thunder)
Josh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond repute
This is super gray area. But yes, that is an assist.
If you can find match video of the Finger Lakes Regional, that was the strategy consistently used by FRC Team 1511. It would go something like: Receive inbounded ball, hold the ball up to their alliance partners until it was scored as an assist, release the ball, pick it back up, go to the next unique robot a unique zone and repeat for a full 3 assists before shooting.
Definitely gray-area strategy, but allowable in the manual. I'm sure CD User pandemonium can elaborate as he's the strategy mentor for that team.
Josh Goodman
Mentor and Volunteer
Team 1511: Rolling Thunder
joshuapgoodman@gmail.com
Unread 08-04-2014, 16:48
TheRamAlakazaam TheRamAlakazaam is offline
AKA: Raul Martinez
FRC #0231 (High Voltage)
TheRamAlakazaam is an unknown quantity at this point
Our team was undefeated until we got a technical foul for being in possession of the ball since the opposite alliance ball simply bounced off a robot...... so we ended up getting seeded in third place.. but I saw other situations where robots were obviously holding the ball against a field element and didn't receive technical fouls. And some technical fouls were given off as 20 pts while our technical foul was 50 pts. So it really depends on the referees
This was at LoneStar
Unread 09-04-2014, 08:05
IbleedPink233's Avatar
IbleedPink233 IbleedPink233 is offline
FRC #0233 (The Pink Team)
IbleedPink233 is a splendid one to beholdIbleedPink233 is a splendid one to beholdIbleedPink233 is a splendid one to beholdIbleedPink233 is a splendid one to beholdIbleedPink233 is a splendid one to beholdIbleedPink233 is a splendid one to behold
It is still amazing to me that in this strategy robots got credit for assists when the ball was still clearly being controlled by 1511's machine.
Unread 09-04-2014, 10:01
Siri's Avatar
Dare greatly
And it's not even just who's controlling. By the manual (rather than my Q&A provoked by but apparently not remedying the utter inconsistency), neither of these robots should be attempting to shield their own ball, which is an explicit G12d requirement. I honestly rank G12d inconsistency as one of the biggest problems with this game, just because so much of it would be so easy to standardize if they wanted to do so.
Unread 09-04-2014, 12:38
Chinmay's Avatar
Chinmay Chinmay is offline
incurable FIRSTaholic
FRC #0846 (Funky Monkeys)
Chinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant future
How about in this case with Titanium? Check out the video around 1:09. I think that is a very deliberate and well done assist using the passing and trapping method. I think that this should totally count for an assist. I haven't seen many other teams try assists like this.
https://www.youtube.com/watch?v=G0LF...AwqUlCg# t=69
Member 846 Funky Monkeys 2007-2011
Mentor 558 Robosquad 2012
Mentor 846 Funky Monkeys 2011-Present
http://www.becauserobots.org
Man is a robot with Defects
Unread 09-04-2014, 13:06
It looked to me that Titanium's teammate clearly took possession of the ball in that technique. Titanium may or may not lose contact, but their teammate was deciding where the ball was going (which is for me a logical summary of the "Possession" definition). They also have to activate their roller to get control back.
1511's technique was clearly different: in many cases going up to the side of a robot that is not moving, rolling the ball forward within the manipulator until it touches the partner robot and the ground. The touched robot gets a possession credit and 1511 moves on. The difference is that 1511 never lost control of the ball - at any point in the operation, they could back up and the ball would still come with them.
Unread 09-04-2014, 13:53
Adam Freeman's Avatar
Adam Freeman Adam Freeman is offline
Forever HOT!
FRC #0148 (Robowranglers)
Adam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond repute
There is a cycle at 1:56 - 2:05, where the ball is inbounded to 1986. It seems clear to me that the ball never leaves their possesion, but at the end of the cycle they are creditted with a 2 assist cycle.
How am I missing an assist? If so, I know we aren't getting these in MI.
-Adam
2005 FIRST World Champions (330, 67, 503)
2009 FIRST World Champions (111, 67, 971)
2010 FIRST World Champions (294, 67, 177)
Unread 09-04-2014, 14:07
Siri's Avatar
Dare greatly
-Adam
The only thing I can think of is that the inbound at 1:56 isn't actually the start of the cycle (it's the return of an out of bounds ball), and the 2nd assist is late coming to 1986. If not, we don't get these in MAR either.
I've watched teams not get credited with trapping assists when they hold their ball against the low goal longer than the 1:09 trap while attempting to score. With rulings like that, why would anyone expect innovative teams to waste cycle time honing in on even more novel assist styles? It's not just the teams that are acting differently, it's disparate calls that are influencing behavior variations.
Unread 09-04-2014, 14:52
pandamonium's Avatar
pandamonium pandamonium is offline
FRC #1836 (Milken Knights)
pandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond repute
It was amazing to us too! In some cases the ball never even was spit out we kind of just drove into / onto our alliance partners. I wish someone would load some matches so we could share this more
Unread 09-04-2014, 15:23
I know Team 20 took match footage for scouting. I don't know if they are planning/would be willing to upload.
