Go to Post Hasn't that always been the mission of FIRST? Don't settle for what works; strive for what amazes. - Sam Lipscomb [more]
Thread Tools Rating: Thread Rating: 57 votes, 4.93 average. Display Modes
  #46   Spotlight this post!
Unread 09-04-2014, 15:38
Re: Team 254 Presents: CheesyVision
In elims at SVR, Brian from 971 and I coded up their robot to use this app (we just let them use our backup driver station laptop to make the install process easier).
They only needed 1 bit of data: whether or not the goal directly in front of them was hot. They used this bit of data to determine whether to wait 3 or 7 seconds to shoot from when auton started. We just used the driver's right hand to signal this bit. The left side was a no care.
  #47   Spotlight this post!
Unread 09-04-2014, 15:51
PayneTrain's Avatar
PayneTrain PayneTrain is offline
Trickle-Down CMP Allocation
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
If I recall correctly, it only ever missed once, and that was due to the spectacular new and exciting failure of FMS switching between tleeop and auto at random, correct? This is super neat stuff.
  #48   Spotlight this post!
Unread 09-04-2014, 15:57
Yes. In QF1-1 you can clearly see both our robots double clutch in auto.
  #49   Spotlight this post!
Unread 09-04-2014, 17:22
Jared's Avatar
Jared Jared is offline
This is really cool. We were planning on using the kinect, but we haven't had spectacular results in testing when we try it with people walking around in the background.
After playing around with it, I found it really useful to be able to lock the calibration color value so that I could hold a green index card in front of the calibration square, save that calibration value, then use both hands to hold up two cards in the boxes so that I can drop one hand out of the way to signal.
To add the lock-
above the while loop
locked = 0
after the statement in the while loop beginning with cal, left, right
if locked == 1:
            cal = lastCal
        lastCal = cal
at the bottom where the keys are checked
elif key == ord('l'):
            locked = 1
        elif key == ord('u'):
            locked = 0
Pressing l locks the current calibration value, and u resets it to normal.
  #50   Spotlight this post!
Unread 09-04-2014, 19:03
Jared Russell's Avatar
Taking a year (mostly) off
To add the lock-
locked = 0
if locked == 1:
            cal = lastCal
        lastCal = cal
            locked = 1
            locked = 0
This is in fact how our original prototype worked, but we switched to continuous on-line calibration because we found that bumping the laptop could throw things off.
  #51   Spotlight this post!
Unread 09-04-2014, 19:30
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
I imagine changes in lightning would create a problem as well. The LED strip right in front of the DS is green prior to a match, then off during Autonomous. That alone would change the calibration. So, a realtime cal is very important.
  #52   Spotlight this post!
Unread 09-04-2014, 21:46
Jared's Avatar
We found the same thing with our test tonight, but we saw a lot of improvement with a really bright green index card. We're now just comparing the amount of green in the two squares and ignoring the calibration one. The side with the most green in it becomes the hot side, and the other is the cold one. This seems to work the best for us.
  #53   Spotlight this post!
Unread 10-04-2014, 01:15
DjScribbles DjScribbles is offline
Programming Mentor
AKA: Joe S
FRC #2474 (Team Excel)
DjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to behold
I haven't seen any talk of a C++ port, so I started a thread in the C++ sub forum here to avoid derailing this thread:
http://www.chiefdelphi.com/forums/sh...26#post1372026
My prototype code is linked in the thread, it is completely untested, but any contributions are welcome.
Thanks Poofs, very awesome implementation; looking forward to trying this out.
  #54   Spotlight this post!
Unread 10-04-2014, 01:19
Volunteer, WPILib Contributor
no team (Waiting for 2021)
It wouldnt let me edit my original post, but I did some testing today and got a version of this that uses NetworkTables to work. It worked on my simulator setup and should work the exact same on a real robot. It just uses 2 bool's, one for each hand. I attached the file to this, and my post on page 1 has the link to the pynetworktables for windows.
I plan bringing this to the regional championship in case anybody needs help with the hot goal. I really like this way, and if we hadn't already coded the kinect we would most likely use it.
Team 4488 - Mentor 2013-2016
  #55   Spotlight this post!
Unread 10-04-2014, 07:09
Programming Mentor
AKA: Joe S
I plan bringing this to the regional championship in case anybody needs help with the hot goal. I really like this way, and if we hadn't already coded the kinect we would most likely use it.[/quote]
In case anybody needs a helping hand with pynetworktables, I believe this would be the dependency you need: https://github.com/robotpy/pynetworktables
Is this correct Thad?
  #56   Spotlight this post!
Unread 10-04-2014, 09:30
Thats if you want to build it from source. If you use this link it gives you a windows installer so you do not need to install any of the build stuff.
http://firstforge.wpi.edu/sf/frs/do/...ktables.2014_4
  #57   Spotlight this post!
Unread 10-04-2014, 19:57
Programming Mentor
AKA: Joe S
I just wanted to post back and say I got the C++ port up and running (with minimal changes).
https://github.com/FirstTeamExcel/Ro...sionServer.cpp
Feel free to shamelessly steal the code, but I'd love to hear if it helps anyone out.
  #58   Spotlight this post!
Unread 11-04-2014, 09:23
phurley67 phurley67 is offline
Programming Mentor
phurley67 is an unknown quantity at this point
Wanted to say thank you. I helped our team get it working with labview yesterday at the Michigan Championship. I made a couple minor changes to the python script: classmate laptop already flipped the image, so I removed the flip logic and fixed left/right, switched to using UDP, and slowed down the send frequency. UDP made the reconnect stuff unnecessary and simplified the labview interface as well.
While there I also helped 107 with a copy of the code and while I did not touch base to see if they got everything working, I know in testing they also had it working in auton (controlling wheels for easy testing).
The whole team got a real kick out of playing with the code. Thanks again for an elegant and cheesy solution.
  #59   Spotlight this post!
Unread 11-04-2014, 10:23
Yeah, UDP is definitely a more straightforward way to do this, but we had already implemented a TCP server on our robot and decided to repurpose it.
  #60   Spotlight this post!
Unread 11-04-2014, 11:27
Also the squawk JVM that runs on the cRIO doesn't support UDP listen sockets.
