Go to Post Hopefully LMFAO will cross paths with FRC71. They've been shufflin' since 2002. - Taylor [more]
Thread Tools Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
Unread 09-04-2014, 23:53
23Nerdy7 23Nerdy7 is offline
FRC #2337 (EngiNERDs)
23Nerdy7 is an unknown quantity at this point
Out stretching surgical tubing.
So my team has come with a recent problem that we started noticing after week 4(our second comp.), the surgical tubing that pulls our launching mechanism is becoming out stretched, therefore some of our shots(mostly our auto shots) are starting to miss.
What do you think would be the best way to fix the problem?
So far there are two ideas that our team has come up with:
1.Have a constant in auto that makes the robot drive further so we can hit each shot, and just drive further in teleop.
2.Replace the tubing every x amount of matches.
I'd like to know what your thoughts are on the two ideas or if you have your own, I believe that option 1 is inefficient compared to 2, even though we would have to replace them every so often.
Unread 09-04-2014, 23:59
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Re: Out stretching surgical tubing.
We started this thread about the same issue:
http://www.chiefdelphi.com/forums/sh...d.php?t=127734
Maybe you'll find some useful ideas in there...
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 10-04-2014, 00:43
Chief Hedgehog's Avatar
Chief Hedgehog Chief Hedgehog is offline
FRC #4607 (C.I.S.)
Chief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond repute
We found that we would have the same issues after working with our Twinbot 'Betsy'. So we ordered 7/16" speargun tubing (from Amazon). That coupled with our lead screw we used for tensioning, we found that we could dial in as we needed. We used a donated pressure scale (much like a fish or deer scale) - it was from an old prison. The story is that it was used to check the pressure from the boiler unit. No matter, it DOES look like something from a prison.
In the photo, you can barely see the leadscrew - it is just to the lower-left of the speargun tubing.
"An error does not become a mistake until you refuse to correct it" ~JFK
Unread 10-04-2014, 00:51
JohnFogarty's Avatar
AKA: @doctorfogarty
Ive found that speargun tubing doesnt stretch out as quickly/easily as regualr surgical tubing. Definitely not in the time of a regional espcially if tension isn't always left fully applied to it throughout the course of the event. I would suggest looking to see if you can adapt some for your team's use.
John Fogarty
Unread 10-04-2014, 01:00
themccannman's Avatar
themccannman themccannman is offline
registered lurker
AKA: Jake McCann
FRC #3501
themccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond repute
Greasing your surgical tubing greatly increases it's life since the tubing tends to crack over time from frictional rubbing with other surgical tubing or with the bars it's mounted to. Elastic materials lose their stretchiness based on how far they get stretches relative to their starting length.
I'm not a professional so this may be wrong, but with most elastic materials it seems that stretching the material a longer distance has an exponential affect on it's life; e.g. stretching the same tubing twice the distance for a half the number of repetitions seems to wear it out faster than stretching it half the distance for twice as many repetitions.
Thicker walled surgical tubing tends to live longer before it loses it's stretchiness due to the fact you can get the same force while stretching it a shorter distance. We also found that using more wraps of tubing while reducing the overall travel also increases the life of each piece as each one is being stretched less but you're getting a larger net force between all of the pieces.
Aside from that, just spend a lot of time checking your shot, if it's losing power re-wrap the tubing or replace it.
All posts here are purely my own opinion.
2011-2015: 1678
2016: 846
2017 - current: 3501
Unread 10-04-2014, 01:11
Josh Fox Josh Fox is offline
AKA: Foxy
FRC #0027 (Team RUSH)
Josh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud of
When 27 ran our surgical tubing catapult in '08 we made "cartridges" using carabiners (rated for climbing and with a proper safety factor) that would provide 50 pounds of force when stretched the desired amount, and would test them after events to determine if they needed replacing or not.
I don't recall for sure, but I believe after every event we just replaced the tubing.
Team RUSH Alumnus and Mentor, Mechanical Engineer
Unread 10-04-2014, 01:34
FRC #4607 (C.I.S.)
What type of grease did you use?
QUOTE=themccannman;1372023]Greasing your surgical tubing greatly increases it's life since the tubing tends to crack over time from frictional rubbing with other surgical tubing or with the bars it's mounted to. Elastic materials lose their stretchiness based on how far they get stretches relative to their starting length.
Aside from that, just spend a lot of time checking your shot, if it's losing power re-wrap the tubing or replace it.[/quote]
Unread 10-04-2014, 02:05
registered lurker
AKA: Jake McCann
FRC #3501
Lithium grease works well, so does high pressure grease. I'd have to ask T^2 what specific brand we're using. It's important to get the grease in places where it's either contacting other tubing, or where it's being bent around something such as a cross-bar that it's wrapped around.
2011-2015: 1678
2016: 846
Unread 10-04-2014, 07:43
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
Be careful. Most oil-based lubricants are not compatible with latex. I can't say how long it would be until you have problems, but if you want to be safe, pick up a vial of silicone o-ring grease instead: http://www.mcmaster.com/#9463k33/=rh3f7n
Unread 10-04-2014, 09:32
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
We use a fish scale to periodically measure the force on our catapult at a specific pull distance. This tells us if the tubing is losing its pull, and lets us either adjust it or replace it as needed, ensuring we can get consistent results each time we modify it.
2016: Lake Superior WFFA
Unread 10-04-2014, 09:58
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Use the Bobcat solution:
Buy these: http://www.mcmaster.com/#extension-springs/=rh55nd
Replace every event for consitant performance.
Trusted source of spring force on Bobcat designs since 2008.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 10-04-2014, 12:28
jijiglobe's Avatar
jijiglobe jijiglobe is offline
FRC #0694
jijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant future
Our team had a similar problem but we came up with a 3 point solution to it that made us not have to change our surgical tubing for both of our regionals(besides the ruined stuff from build season). The system is as follow:
1) Have a system where you can take off surgical tubing without cutting the zipties or whatever holds it. We accomplished this by using an eye bolt with a hole to hook surgical tubing into. Then only put surgical tubing onto robot while in queue.
2) Never stretch surgical tubing more than half of its initial length.
3) Find out how much force it takes to move your catapult using a spring scale(use the same one every time in case it's off) You have to measure from a specific point in the motion of the part every time. Then check that you match that number before each match.
It's a little tedious but we went through 2 days of competition at the Buckeye and 3 days at New York without having to change and without having noticeable drops in accuracy.
Unread 10-04-2014, 12:49
registered lurker
AKA: Jake McCann
FRC #3501
This is definitely true. However, the majority of the friction our tubing (with our design) is encountering is not abrasive friction but more so caused by being stretched around a curved surface. I'm not sure how much oil based lubricants will affect latex in lower friction environments but definitely keep this mind as large amounts of latex tubing can be hazardous if it snaps.
We also use a fishscale to check the power of our shot, it's a good consistent way to track changes in your tubing.
2011-2015: 1678
2016: 846
Unread 10-04-2014, 16:41
Deke's Avatar
Deke Deke is offline
no team (No Team)
Deke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the rough
If you can tension in the elastic range of the material, you drastically increase the life. I'm not sure i have seen a material or mechanical specification stating the elastic range of surgical tubing, but some testing can go a long ways. One way would be reducing pre tension and adding more tubes, or the tubes may have to be longer depending on the stroke required.
We used steel springs but went through a few iterations to find springs with the correct force and range required in the elastic range. We ruined a number of springs by over stretching into the plastic range of the material.
Our last spring combo made it through two competitions and numerous test shots without any loss off power.
Unread 10-04-2014, 22:29
menns menns is offline
AKA: Michel Enns
FRC #1310 (Runnymede Robotics)
menns has a spectacular aura aboutmenns has a spectacular aura about
The curious thing we discovered about stretching surgical tubing is that the restoring force decrease by about 10% for about 40 seconds to a minute after it's stretched. We get the most catapulting force if we stretch it and release it immediately. We suspect this was throwing off our two ball autonomous.
I'm guessing this a thermal effect. Rubber produces heat when stretched. It then cools to room temperature but rubber expands when it cools so less restoring force.
