Go to Post Who says engineers can't be poets? - Wayne TenBrink [more]
Unread 05-04-2014, 14:57
Akolbi Akolbi is offline
FRC #4607
Akolbi will become famous soon enough
Speaker Wiring and Programming
We want to put a speaker on our robot, we just finished our regional and think it would be hilarious to play an evil laugh when the catapult shoots.
what do we need, will a standard audio hookup work?
where/how do we plug it in?
what do we need to do programming wise (labview)?
Unread 05-04-2014, 15:39
dubiousSwain's Avatar
dubiousSwain dubiousSwain is offline
The ride never ends
AKA: Christian Steward
FRC #5420 (Velocity)
dubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond repute
Re: Speaker Wiring and Programming
Hmm...
My first thought would be to check for libraries in labview that have functionality to play WAV files, and have the file as a dependency
Not sure about hooking it up
You might want to check the rules about speakers on the robot, I think I might have read something about it
also I'm not sure what you are trying to achieve, a speaker small enough to fit in your bot wouldn't be audible over the DJ's sound system and the crowd noise
2015 MAR District Champions
Unread 05-04-2014, 16:03
OWilliamson's Avatar
OWilliamson OWilliamson is offline
FRC #2594 (NASKCO)
OWilliamson is a glorious beacon of lightOWilliamson is a glorious beacon of lightOWilliamson is a glorious beacon of lightOWilliamson is a glorious beacon of lightOWilliamson is a glorious beacon of light
Originally Posted by dubiousSwain View Post
Hmm...
If you check TBA, 4607 is done playing for this year. That means they don't have to meet all the rules with their robot any more. I'm assuming they are adding it for demo purposes or something like that.
2015: Utah Regional - Quarter-Finalists (3374 & 4158)
2014: Utah Regional - Semi-Finalists (1619 & 399)
2013: Utah Regional - Quarter-Finalists (1332 & 3562)
2012: Utah Regional
Unread 07-04-2014, 10:36
sparkytwd's Avatar
sparkytwd sparkytwd is offline
FRC #3574
sparkytwd will become famous soon enough
Simplest thing might be something like this: https://www.sparkfun.com/products/11029
Grant Imahara used it to build a robot for The Late Late Show: http://www.aamicron.com/3/post/2010/...proaching.html
With that you should be able to use a DIO to trigger a sound clip.
Unread 10-04-2014, 22:48
Sparky,
That is actually an interesting solution for the audio. You will need to follow up with a power amp to feed the speaker. Several are available for a 12 volt supply. You could even use an old car radio and a small FM module to transmit sound to the robot from any source.
