Go to Post There will be violence next year! YAY! - Koko Ed [more]
Unread 10-04-2014, 23:37
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Heartbleed
In case you haven't heard, now is a really good time to go and change your passwords.
This article explains it better than I can-- maybe some of the network gurus around here have more details?
I didn't see a thread about it anywhere and figured it's probably relevant to a lot of the users here.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 10-04-2014, 23:44
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
Re: Heartbleed
This specific exploit is actually not quite network related. It's more of a programming oversight (with huge implications). Basically, there's a part of the SSL protocol called the heartbeat, which allows for a connection to remain open over time - the client sends a little message to the server saying, "hey! don't kill my connection" and the server acknowledges it and sends some data back.
The way the protocol is defined, the client sends its packet of data and a number representing the size of that data as validation (something pretty common to do). However, openSSL doesn't check that the given size actually corresponds to the actual size of the payload - it just allocates a chuck of memory that sized and returns it. This means that if the user tells openSSL that the payload is bigger that it is, the server will actually dump a portion of its memory back (which can include things like private keys, passwords, etc.).
You can check the vulnerable code out here, and you can see it just does a memcpy and if you look at the surrounding code, those bounds aren't checked.
/* Allocate memory for the response, size is 1 byte
* message type, plus 2 bytes payload length, plus
* payload, plus padding
buffer = OPENSSL_malloc(1 + 2 + payload + padding);
bp = buffer;
/* Enter response type, length and copy payload */
*bp++ = TLS1_HB_RESPONSE;
s2n(payload, bp);
memcpy(bp, pl, payload);
Although the situation is different, the moral of the story remains the same...
Unread 11-04-2014, 09:24
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: Heartbleed
Unread 11-04-2014, 13:29
MCMechTech MCMechTech is offline
FRC #3959 (Morgan County Mech Tech)
MCMechTech is an unknown quantity at this point
Re: Heartbleed
You will want to be sure your web server has been updated to address the vulnerability before you change your passwords. Otherwise you could make the problem worse by exposing both the old and new password to an attack.
Unread 11-04-2014, 14:15
AKA: Nick Aarestad
Re: Heartbleed
We had a security expert come in to my AP Computer Science class who recommended changing all passwords now, and then again in 3-4 weeks. The rationale being that some will have fixed it ASAP, but some will only get around to it later (or something along those lines).
tumblr | twitter
VEXU UMN (2015-??)
Unread 11-04-2014, 14:22
Lucario's Avatar
Lucario Lucario is offline
AKA: Alan
FRC #0422 (Mech Tech Dragons)
Team Role: Operator
Lucario is on a distinguished road
Re: Heartbleed
https://lastpass.com/heartbleed/ actually has a web tool to check if the server's been patched. You can use this to check to see if its time to change your password.
Also, if you're a web-admin, you'll want to check your own site's SSL if you're doing anything sensitive- both the patch and a re-key has to be applied for you to be protected.
Unread 11-04-2014, 14:37
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Re: Heartbleed
Now it is:
Cisco and Juniper, two of the largest router and Internet equipment makers, said today that the vulnerability, which exposes encrypted data like passwords, is present in their routers, switches and firewalls.
http://www.komando.com/blog/247808/t...ery-very-worse
Unread 11-04-2014, 15:29
Lucario's Avatar
AKA: Alan
Team Role: Operator
Re: Heartbleed
Originally Posted by rich2202 View Post
Now it is:
Yep. Also, in Heartbleed-vulnerable routers, since almost all routers also act as a web server, SSL connections between it and clients (such as router management clients) are vulnerable to MITM (Man-In-The-Middle) attacks and decryption.
(a.k.a Rukar.io)
Info, games, and more!
Lucario is the best Pokemon, after all.
Unread 11-04-2014, 19:28
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
Re: Heartbleed
Anyone know if CD is affected? The tool that Alan linked to is inconclusive.
Originally Posted by LastPass
Unable to get HTTP headers for www.chiefdelphi.com
Site: www.chiefdelphi.com
Server software: Not reported
Was vulnerable: Possibly (might use OpenSSL, but we can't tell)
SSL Certificate: Unable to extract SSL information for that host
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 11-04-2014, 20:22
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
Re: Heartbleed
Nope -- CD doesn't use SSL/HTTPS. Port 443 on chiefdelphi.com is blocked.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 11-04-2014, 21:04
In other words, don't use an important password here.
Unread 11-04-2014, 21:18
alex.lew alex.lew is offline
college student
FRC #1912 (Team Combustion), FRC #0558 (Elm City Robo Squad)
alex.lew will become famous soon enoughalex.lew will become famous soon enough
Re: Heartbleed
Is there any password that could be more important?
