Go to Post ...I'm still waiting for a Chiefdelph-aholics group to form at the local YMCA. - KelliV [more]
Unread 11-04-2014, 11:44
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Low Rider Club 2014
On this year's robot, we had roughly 1/16" ground clearance.
Our ground clearance started just below 1/8", where the bottom of our lexan bellypan was. There were originally pan head bolts and rivets below the bellypan, but as the robot wore in (ie: was pounded in) we began to completely ruin the whole field of tape at Dallas (2 times) as our tubing frame slightly shifted. We moved all of the bolts and busted out the Dremel to ground down some bolt "tails" so the lowest point of the robot was the bellypan itself, which had sunk down to 1/16".
After 2 regionals, we have huge scratch marks (like sandpaper) all along our plastic bellypan where we were still slightly sliding around.
Ground clearance is defined in this club as the height of your bellypan (or similar large, horizontal plate) off of the ground. How low are you?
Unread 11-04-2014, 12:12
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Re: Low Rider Club 2014
When we're on our omni-wheels our belly pan is just under a 1/4" from the ground. We have bolts and the 72 tooth gears that come close enough to the ground to collect any loose bits of carpet. We collected a lot of carpet this year. Our pretty white frame isn't so pretty on the inside anymore.
Unread 11-04-2014, 12:14
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
The bolt heads out the bottom of our frame are just a smidge over 0.25" from the ground. We didn't go lower because we didn't want any issues with running over loose nuts/bolts on the field.
GitHub
Unread 11-04-2014, 12:26
Canon reeves Canon reeves is offline
FRC #4490
Canon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud of
We have about 3/4 of an inch of clearances, at one point we ripped up a piece of loose tape and it cost us a bearing and a belt!
Unread 11-04-2014, 13:08
Chris is me's Avatar
AKA: Pinecone
At the lowest point, our bellypan is .4375 inches from the ground. The completely flat field let us switch to 4" wheels while still using the 3" drive tubes we are used to. We did not experience any scraping this year.
In the past we've had CIMs as close as 3/8-1/4" from the ground. These CIMs had scrapes on them as well as a collection of metal shavings presumably grabbed off the ground.
Unread 11-04-2014, 13:17
RoboChair's Avatar
AKA: Devin Castellucci
You sir have an amazing drive base if your belly pan can hold a half a thousands tolerance!!!!!!
Unread 11-04-2014, 13:21
AKA: Pinecone
It's probably more like .435 factoring in that the plate is probably .063" thick rather than exactly 1/16th. Also forgot to factor in powdercoat, which adds at least 2 thou.
Unread 11-04-2014, 13:24
RoboChair's Avatar
Now we just need the field and the field TAPE to live up to these numbers!
Unread 11-04-2014, 16:33
SkittlesCharge's Avatar
SkittlesCharge SkittlesCharge is offline
Alumnus Extraordinaire
AKA: Klager
FRC #0537 (Charger Robotics)
SkittlesCharge is a name known to allSkittlesCharge is a name known to allSkittlesCharge is a name known to allSkittlesCharge is a name known to allSkittlesCharge is a name known to allSkittlesCharge is a name known to all
537 had 1/2" inch ground clearance with our belly pan this year. In our videos from competitions, you can see our belly pan sticking out below the bumpers, but you can't (easily) see the wheels, so it kind of looks like our robot is hovering 1/2" off the ground.
Team 537 Website
At The Control - FRC Webcast Dashboard
Unread 11-04-2014, 16:34
cadandcookies's Avatar
cadandcookies cadandcookies is online now
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Geez, makes us feel positively sky high with ~3/4" clearance.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 11-04-2014, 17:06
TikiTech's Avatar
TikiTech TikiTech is offline
Mr. H
FRC #3880 (Tiki Techs)
TikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really nice
Add us to the 1/16" low rider club...
Our cross braces and electronics mounting rails are welded under our frame, so everything sits nested inside the frame.
It only became a concern when we had a code issue in auto. Our first practice match of the season we ran into the wall in our torque gear and in those 10 seconds we burned through the carpet and toasted a brand new set of Vex 4" Versa wheels.
In fact, that practice match in teleop we were unable to move since in the time between auto and teleop the carpet and what was left of the tire material cooled and we were GLUED in place. The field techs were so happy with us!! Took a good 10 minutes to pry the robot from the field.
Of course the practice matches were held on the game field and every time we set up our robot throughout the event we could not help but smile. We were concerned that we would trip breakers with our 6 CIM drive. After the wall burnout we felt that was no longer an issue. Plus seeing your "patch" when you went to set up you robot, priceless....
Luckly we had a bunch of spares. This is our first time using a west coast drive and wasn't sure of how badly they could wear tires out during defense.
We have upgraded to Colsons for the championships.. Hope they wear better.
Aloha!
Team 3880 - "Tiki Techs" "Mr. H" - Tiki Technologies Coach / Mentor
Kealakehe High School Robotics - Kailua-Kona, Hawaii
__________________________________________________ _____________________________
2016 Hopper Division | Orlando Regional Engineering Inspiration Award | Hawaii Regional Chairman's Award & Finalist & Woodie Flowers Finalist
2015 Carson Division | Silicon Valley Regional Engineering Inspiration Award | HI Regional Regional Winners & Engineering Inspiration & Deans List Finalist
2014 Newton Division | Hawaii Regional Engineering Inspiration Award & Deans List Finalist
2013 Newton Division | Inland Empire Regional Regional Chairman's & Creativity Award | Los Angles Regional Engineering Inspiration Award | | HI Regional
2012 Curie Division | Hawaii Regional Engineering Inspiration Award
2011 Newton Division | Hawaii Regional Regional Winners & Industrial Design Award
Unread 11-04-2014, 17:21
Engineering Coach
Pictures?
Unread 11-04-2014, 17:25
TikiTech's Avatar
Mr. H
I will check with the students.
The field crew was not amused so they might not of gotten one. We were kind of busy pealing the robot off the floor.
I will check to see if the worn tires are not in the crate. If they are not I will post a picture of them tonight after our meeting. I was amazed.. We put them on our intake for the rest of practice as a badge of honor. Sadly they did effect the pick up and we replaced them before the qualifications.
Unread 11-04-2014, 17:29
Tyler2517's Avatar
Tyler2517 Tyler2517 is offline
ShortOnes
AKA: Tyler Gibb
FRC #2517 (Evergreen Robotics)
Tyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura about
When we lost one our wheels we were 1/4 off the ground on that side. (running eliminations like that) other wise we were 1/2-3/4 off the ground. We some how still got lots of carpet in out bevel gears 6 inches off the ground still not sure how that happens.
Unread 11-04-2014, 18:06
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
Our practice bot was at 1/2", and we lowered the comp bot once we tried driving over uneven carpet tape and found that it could keep going. 1/4".
