Go to Post Many people follow that advice, as if Ohio is Mordor or something. - Travis Hoffman [more]
Unread 11-04-2014, 18:19
Henrique Schmit's Avatar
Henrique Schmit Henrique Schmit is offline
FRC #1156 (Under Control)
Team Role: CAD
Henrique Schmit is an unknown quantity at this point
Re: Low Rider Club 2014
We didn't suppose to have such a low robot, but for some time there was the head of a bolt scratching the ground, so we had to change the side of a spring washer so it didn't happen, that would make our robot 1mm away from the ground, or 0.0393701 inches.
Unread 11-04-2014, 19:30
Botwoon's Avatar
Botwoon Botwoon is offline
A.K.A. Matthew Ruane
FRC #0207 (Metalcrafters)
Botwoon will become famous soon enough
Our robot scrapes the ground when it rides on carpet, do we win?
Unread 11-04-2014, 19:37
Team Role: CAD
I guess you can't get closer than that, there were a few parts of our robot scraping the ground, but we managed to fix those, so we're not so far away from you.
Unread 11-04-2014, 20:05
jbsmithtx's Avatar
jbsmithtx jbsmithtx is offline
FIRST Fanatic
AKA: Josh Smith
FRC #4206 (RoboVikes)
jbsmithtx is a jewel in the roughjbsmithtx is a jewel in the roughjbsmithtx is a jewel in the rough
Originally Posted by BBray_T1296 View Post
On this year's robot, we had roughly 1/16" ground clearance.
Our ground clearance started just below 1/8", where the bottom of our lexan bellypan was. There were originally pan head bolts and rivets below the bellypan, but as the robot wore in (ie: was pounded in) we began to completely ruin the whole field of tape at Dallas (2 times) as our tubing frame slightly shifted. We moved all of the bolts and busted out the Dremel to ground down some bolt "tails" so the lowest point of the robot was the bellypan itself, which had sunk down to 1/16".
After 2 regionals, we have huge scratch marks (like sandpaper) all along our plastic bellypan where we were still slightly sliding around.
Ground clearance is defined in this club as the height of your bellypan (or similar large, horizontal plate) off of the ground. How low are you?
It would have been funny for you guys to play in our last qualification match at Dallas. Our mecanum wheels broke, and I bet a roller would have high-centered you guys
Unread 11-04-2014, 23:10
Rynocorn's Avatar
Rynocorn Rynocorn is offline
Strategist and Designer
AKA: Ryan Jacobs
FRC #1466 (Webb Robotics)
Rynocorn is on a distinguished road
Our robots belly pan was on the ground in the center during most of our matches and the bolts holding it one he front and bag dragged along the ground. We called it an "traction device" and not a cad error. At one point, some tape had overlapped on the field wand the carpet was a tad pulled up and I got the robot stuck on it for a bit.
My favorite parts: Surgical tubing, Grab catches, churro tubing, and waffle tread.
Unread 11-04-2014, 23:26
rkgoyankees's Avatar
rkgoyankees rkgoyankees is offline
Mechanical Lead
AKA: Ryan Kelly
FRC #1425 (Error Code Xero)
rkgoyankees is an unknown quantity at this point
Our gear covers are at best 1/8'' off the ground.
Unread 11-04-2014, 23:30
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Originally Posted by TikiTech View Post
We have upgraded to Colsons for the championships.. Hope they wear better.
We ran 3" diam, 1.5" wide Colson wheels (hence our low ground clearance) and replaced them for each regional, not because they wore, but because we swapped our whole drive-trains for unrelated reasons.
Anybody who saw us could attest that we were arguably the pushiest robot on the field, running 6CIM, 6w tank drive, with 2 speeds geared 5.5fps and 15.5 fps. We prided ourselves on bulldozing just about everybody down the field at both regionals.
The Colsons show some superficial wear on them. They felt a little softer after the regional than they were at the start, but they were neither (visual comparison) smaller than brand new wheels, nor did they push less hard.
Our team was extremely satisfied with the Colson wheel's performance, and we will definitely run them anytime we need traction in future games (who needs wheels in next year's water game )
Unread 12-04-2014, 01:19
JCharlton's Avatar
JCharlton JCharlton is offline
AKA: JC
JCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to behold
We were in your club, but after our first match and some unfortunate skid marks in the carpet wherever we had travelled forced us to change out our 4-inch omnis for some 6-inch ones. That was a fun morning, let's not go in to it...
"There is no problem so bad that you can’t make it worse." - via Chris Hadfield
Unread 12-04-2014, 06:32
Bryce Paputa's Avatar
Bryce Paputa Bryce Paputa is offline
FF TSL: Frog Farce
FRC #0503 (Frog Force)
Bryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond repute
We barely clear the ground, any extra clearance is a higher cog.
Unread 14-04-2014, 18:18
TikiTech's Avatar
TikiTech TikiTech is offline
Mr. H
FRC #3880 (Tiki Techs)
TikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really nice
Originally Posted by AllenGregoryIV View Post
Pictures?
Here is the wear after our autonomous burnout at the field wall.
By the time the auto ended and teleop started the tire material had cooled and adhered to the carpet..
No teleop for our first practice match and some grumpy field techs..
We have upgraded to colsons now. I would like to try it again and compare wear though I doubt we would be popular after that.
I doubt we could of drove much after burning off that much material. We only have 1/16" of clearance..
Still looking for picture of carpet damage..
Team 3880 - "Tiki Techs" "Mr. H" - Tiki Technologies Coach / Mentor
Kealakehe High School Robotics - Kailua-Kona, Hawaii
__________________________________________________ _____________________________
2016 Hopper Division | Orlando Regional Engineering Inspiration Award | Hawaii Regional Chairman's Award & Finalist & Woodie Flowers Finalist
2015 Carson Division | Silicon Valley Regional Engineering Inspiration Award | HI Regional Regional Winners & Engineering Inspiration & Deans List Finalist
2014 Newton Division | Hawaii Regional Engineering Inspiration Award & Deans List Finalist
2013 Newton Division | Inland Empire Regional Regional Chairman's & Creativity Award | Los Angles Regional Engineering Inspiration Award | | HI Regional
2012 Curie Division | Hawaii Regional Engineering Inspiration Award
2011 Newton Division | Hawaii Regional Regional Winners & Industrial Design Award
Unread 14-04-2014, 18:30
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
857 is something like 1/2". Makes our 2013 bot look absolutely silly with about 3.5" clearance, with then several more inches up to our electrical board.
Unread 15-04-2014, 00:26
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
4301 had its belly pan dragging on the ground for an entire regional. When on a hard floor, there's barely enough clearance to slip a sheet of paper underneath.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 15-04-2014, 01:22
michael.saxon's Avatar
michael.saxon michael.saxon is offline
Robots are so metal
FRC #2478 (Westwood Robotics)
michael.saxon is an unknown quantity at this point
Pretty much. We were in a similar situation with the heads of rivets on the bottom of our belly pan. We had to put packing tape over them to keep them from ripping up the gaffer's tape
2010 - 2013 Plasma Robotics, FRC 2403, Zero Robotics 15
2010 Arizona Winners
2012 Utah Winners
2013 Zero Robotics World Simulation Champions
2013 Las Vegas Finalist, Engineering Inspiration
2014 - ? Westwood Robotics, FRC 2478, Zero Robotics 280
2014 Las Vegas Winners
Unread 15-04-2014, 01:42
nathannfm's Avatar
nathannfm nathannfm is online now
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
Some of you guys sure would have had a fun time at MAR CMP, the cement floor was so bad there were gaps where they couldn't get parts of the field to fit together right. Needless to say the carpet wasn't exactily flat and was the most torn up FRC carpet I have ever seen by the end of the day.
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
