Go to Post Dave was an evil genius in his previous life. - Koko Ed [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 29-09-2013, 18:40
xForceDee's Avatar
xForceDee xForceDee is offline
AKA: Bart Kerfeld
FRC #4239 (Warpspeed)
xForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to behold
Attaching Tread on Vex Traction Wheels
To those of you that have used Vex Traction wheels in the past, what method did you use to attach tread to them and what tread did you use?
Unread 29-09-2013, 18:43
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
Re: Attaching Tread on Vex Traction Wheels
We used the roughtop tread directly from Vex and attached it with rivets-that seems to be the most common method for attaching tread (barring the Andymark ziptie wheels)
Unread 30-09-2013, 09:33
Blackphantom91's Avatar
Blackphantom91 Blackphantom91 is offline
Mentor + 4 = Stuck For Life
AKA: Malcolm Stirckland
FRC #1986 (Team Titanium)
Blackphantom91 has a spectacular aura aboutBlackphantom91 has a spectacular aura aboutBlackphantom91 has a spectacular aura about
We drilled pilot holes first then attached the tread through rivets. I may suggest 2 for holding applications. Andy mark traction This is pretty nice.
[img*]http://i.imgur.com/Os2oTET.jpg[/img*]
Unread 30-09-2013, 18:39
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
We didn't use the VEXpro traction wheels this year. However we have used traction wheels in the past and many teams get the tread from other sources such as McMaster-Carr, that's how they get blue or black tread.
Unread 30-09-2013, 18:49
Wren Hensgen's Avatar
Wren Hensgen Wren Hensgen is offline
Alum, Mentor, Volunteer
AKA: Wren Hensgen
FTC #10353 (MetalWorks)
Wren Hensgen is a jewel in the roughWren Hensgen is a jewel in the roughWren Hensgen is a jewel in the rough
We swapped out 4-inch Higrip wheels from AM with 4-inch Vex traction wheels for the increased traction. We used McMaster roughtop tread, which you can find with a simple search on their website. Using 6 rivets per wheel has ensured that they remain firmly attached, and the tread lasted us 3 competitions before it needed to be replaced
Unread 30-09-2013, 18:56
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Our tread is the blue nitrile tread from Mcmaster, bought in sheets and cut on a saw. The blue tread wears extremely well. We used to go through red/orange thread quickly. We'd have to replace them 3 times a year, or every 2 competitions. In 2013, we used the blue and did not have to change it a single time.
Get large-head rivets and double rivet the ends of the tread. A couple intermediate rivets along the length will insure it never comes off.
This year I may take a look at different ways to use zip-ties to attach the tread.
Unread 11-04-2014, 17:12
de_ de_ is offline
AKA: Dave Edwards
FRC #1310 (Runnymede Robotics)
de_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the rough
Re: Attaching Tread on VexPro 2104 Traction Wheels
Since the wheels are glass filled nylon, were rivet backing plates used to stop the rivet from pulling to the wheel or trying to split wheel ?
If no backing plates were used, did your rivets pass fully out of the rim (as per traditional rivets) or were they buried (which I would think would put huge pressure on the holes).|
Also the wheels have support ridges cast into the wheels exactly where ideally the rivets should go. Could grind off the ridge where the rivet would pass through but not happy with that. Else the rivets have to be moved in from the ideal spot. What did everyone else do ?
How long a rivet did you use ? Diameter 3/16 ?
Unread 11-04-2014, 20:54
rkbot's Avatar
rkbot rkbot is offline
Riley
AKA: Riley
FRC #2013 (Cyber Gnomes)
rkbot will become famous soon enoughrkbot will become famous soon enough
2013 use 1/8 by 1/2 rivets to attach our tread (conveyor belting from a sponsor). we also used a 3m marine adhesive to fill in those ridges and to make sure the tread would stick on well. (for the most part the rivets are for insurance, as the adhesive is very strong) They seem to be holding up very well. Our first set of wheels we only riveted and the treads ripped right off of our wheels.
Unread 11-04-2014, 21:01
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
1640 has an article on their wiki about using threaded inserts and bolts with large heads to attach the tread. We are planning on implementing this next year in our custom wheels.
The link
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 11-04-2014, 21:38
Naveed Riaziat's Avatar
Naveed Riaziat Naveed Riaziat is offline
FRC #0649
Naveed Riaziat is an unknown quantity at this point
Team 649 also highly recommends the blue nitrite tread. We install ours on AndyMark high performance wheels. After cutting them to the proper length and width on the bandsaw, we cut two notches out of each end, making a smaller portion that fits in the slot provided in the wheel. We then drill a hole through both ends, insert them in the slot, and pull them tight. While one person hold the tread tight, another slips in a zip tie and ties it through the holes and through the wheel. Used the orange stuff last year, but with the same method. Havent had a failure yet.
Unread 11-04-2014, 21:43
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
+1 for the glue. We use glue, and then rivets.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 13-04-2014, 21:59
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Attaching Tread on Vex Traction Wheels
When we use traction material on our wheels, we use "Shoe Goop" as the adhesive we sand the mating surfaces and clean with alcohol to remove oil and dust. We make up sheet metal clamps out of soft steel and square bar stock and pull tight with a vise or vise grips until the glue has cured. After the glue has cured, we then drill holes on the perimeter of the wheel rim near the spokes, slightly larger than the stainless safety wire we use. We then loop the safety wire across the tread, and twist the safety wire with a safety wire plier and cut to length and fold to the interior of the wheel. Drill double holes where you join the ends about 3/8" apart so you can tie down the ends of the tread joint. Cut the tread slightly shorter ( 1/16-1/8") than what you determine by hand wrapping. This will prevent buckling at the joint when clamping. Never lost a tread yet, and tread can be replaced by cutting the safety wire and peeling the tread back and away from the wheel. We normally place the tread joint in the middle of the spokes for more room for the double holes. We build two sets as insurance which will allow us to change out worn tread, and allow overnight glue curing of the repaired wheels. Just FYI, we have changed to Colson's this year. A lot less work, and no loss of performance.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 14-04-2014, 09:47
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
We used rivets exclusively on our Vex traction wheels. We've used glue in the past on other traction wheels but due to the uneven surface on the Vex wheels we determined it would be impractical (and use a lot of glue). Regardless, we had no issues with tread coming off and the Vex roughtop tread we used lasted 2 events before needing to be replaced.
We did find that it was extremely difficult to find adequately long pop rivets to hold the tread that also had large enough heads (so the tread didn't just slip off). We ended up using long rivets with small heads and using washers to prevent tread slipping off.
Unread 14-04-2014, 10:15
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
We used these 97447A317 from McMaster-Carr. 2 on each end & 1 additional in two places about 60 degrees apart. The rivets were placed in valleys and the tread pulled tight around the wheels. You have to watch not to drill into the screw holes that hold the wheels together. We have not had issues with the tread coming off.
I used to glue tires on my bicycle. Major PIA. I am not sure what if anything this has to do with robots.
Unread 14-04-2014, 15:20
ice.berg's Avatar
ice.berg ice.berg is offline
Strategy Mentor & Drive Team Coach
AKA: Alex Bergal
ice.berg has a spectacular aura aboutice.berg has a spectacular aura about
We used the vex wheels and attached the tread with 6 rivets and 3M 2 part epoxy. We did not have any problems with them falling off or separation. One key aspect of this is we used high quality steel mandrel and body rivets not aluminum for extra strength. You can get these on McMaster or at Fastenal. Also make sure when putting the rivet into the wheel is to make sure you are putting it through the high parts of wheel and not the low valleys. This way the tread is attached smooth and not bumpy.(hopefully you get what I mean by this)
I can attach pictures later for more details. Best of luck
TEAM 2512 DULUTH EAST DAREDEVILS
'12-'15: Strategy and Build Mentor
'15 Hopper Division Champions and Einstein Finalists thanks 987, 2826, 4265
'15 Minnesota State Champions thanks 3130 and 4215
'15 Northern Lights Chairmans Winner and Regional Finalists & Central Illinois Regional Finalists
'10-'11:Build Captain
'13 Midwest Champion '12 North Star Champion '11 Lake Superior Champion
Website Facebook Twitter Youtube Flickr
