Go to Post The math isn't that hard. It's just a tool, like a screwdriver or soldering iron. Sure you get tired of picking up the same old thing everyday, but when you have to tighten a screw you still reach for the screwdriver. - Al Skierkiewicz [more]
Go Back   Chief Delphi > Competition > District Events
Unread 13-04-2014, 12:41
XaulZan11's Avatar
XaulZan11 XaulZan11 is online now
AKA: John Christiansen
FRC #1732
XaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond repute
Send a message via AIM to XaulZan11
Re: What are we doing wrong at MSC?
I didn't watch enough of MSC to say why you did not get picked, but in general teams typically don't understand that sometimes it is better to be the 3rd best 'support' robot than the 15th best scoring robot. This requires a an understanding of which type of robot alliances will want with their 3rd pick, an honest and accurate assessment of where you stack up with the other robots, and the willingness to put your pride aside and play the less glamorous role (which can be hard as your team spent 10+ weeks working on being the scoring robot). This may or may not apply to your situation.
Unread 13-04-2014, 14:03
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
In the scouting seminar that Jim Z and I covered, one of the topics that we kept stressing was you have to scout your own team with as open of eyes as possible.
When I was the scouting mentor for 33, I would often have the "why didn't we get picked" conversation with teams, and they would often get very upset with me for telling them my perspective of the truth. The most common statement I heard from many teams is "we thought we would get picked earlier in the draft".... This tends to track with the "over-inflated" perception folks have about teams (I was just as guilty of this with 33 as the next team). The real thing is, it is easy to focus on your teams strengths, and shrug off a bad match, or dropped ball, or missed auton, or foul because you know the full story of what happened. Often scouts don't know the 100% story and thus that is relevant information.
I did not do thorough objective scouting at MSC this weekend, but watched a lot of matches, and know a lot of capabilities of teams. My guess (which aligns with earlier comments) was that 2959 was "on the bubble" for a lot of teams lists. I know this was true of 33's list last year as I helped make that one. Last year, you guys were awesome with the run and gun and pretty good with with the 10 point climb. You guys tended to shoot from the same "favorite" spot as 33 though which was a bit awkward in matches if the robots "got in sync". As was 314 at MSC and World's for 33 in 2013, but was edged out by other competitors (68 at MSC due to better defensive ability and 1519 at World's because they were an FSC with more height).
For 2014, 2959 was a really good machine with a pretty accurate shot. At least at Escanaba, your collector was slow*. I think it took about 3+ seconds to acquire a ball. Not sure if you put faster motors on for MSC (I believe it was window motors at Escanaba).
Also as others have stated, the pedestal style shooting mechanism could be bumped to cause you to drop the ball, and thuse require a new acquisition (see above). While this didn't occur often, it would occur anytime someone gave you a good hit, which in Elims is any time you get ready to shoot.
Other than that, it is like many others have said, the depth at MSC this year was great, and the parity of teams was quite broad as well. This meant that really another 5-10 robots likely would have been good picks (2959 included) to play in Elims. But as FIRST only lets you pick 1, that is all you can pick, and teams try to pick the ones that will work out best for them.
If you ever want objective advice on how to improve your robot, talk to the scouts of another team you respect after the event. During the event, they may not tell you all the details, but after an event, they will often give you a nice list of things to work on. The biggies are usually auto accuracy, piece manipulation, speed, traction, driving, defense, and strategic awareness tend to be the normal ones. By the back end of the draft, teams are usually deficient in some of these areas. Some years/robots, it is a specific design feature (type of wheels, long vs. short in 2012).
*If possible, for collecting a ball, you want the surface of your roller to be at 2X the ground speed you want to be able to collect at. IE for a 7 FPS drivetrain, a 14 FPS surface speed on the roller will really snap up the ball. You have to balance speed though with enough torque to do the action so that the collector doesn't stall. IE if you have a 15 FPS chassis, a 30 FPS collector is crazy fast and will likely stall.
Assuming a Window motor, and I think those collector wheels are around 4" diameter, the rollers likely spin at around 85 rpm. This would be roughly 1.5 revs/second which for a 4" roller is about 1.5 feet/second. The 2 foot diameter ball has to roll about 1/2 to 1 revolution to roll into a robot. This is 3 feet to 6 feet. At 1.5 FPS, collection would require 2-4 seconds to collect. If your robot was to intake the ball each of 4 cycles, the collection process would use 8-16 seconds of the match. If all 3 robots collected at this speed, 24-48 seconds of a 31 pt. cycle style of play would be bringing collecting. Possibly more if to pass you have to spit the ball back out the intake. I think your intake was faster than that, but still took a while to collect.
Unread 13-04-2014, 15:23
safetysid's Avatar
safetysid safetysid is offline
FRC #2959 (CW Tech Robotarians)
safetysid is a splendid one to beholdsafetysid is a splendid one to beholdsafetysid is a splendid one to beholdsafetysid is a splendid one to beholdsafetysid is a splendid one to beholdsafetysid is a splendid one to beholdsafetysid is a splendid one to behold
Thank you for all your input! This is really going to help us, we really appreciate it.
Unread 14-04-2014, 20:49
safetysid's Avatar
Once again, thank you so much for your input. After Escanaba, we also realized that was too slow for this game. Since then we put a different motor on so now it intakes a ball at almost less than a second. The next week we went down to the Boilermaker regional and that really helped us, we actually made it to finals with Argos and the Earthquakers. Other improvements include adding a bungy cord to the PVC to secure the ball better and a new kicker arm. The ball does move around a lot but I can assure you, doesn't fall out when hit. Times that it does, usually only when the ball hasn't settled in the shooter which happens to even the best robots. And the new kicker arm is a lot more powerful than our old piece of strut with a pool noodle on it. It has made all our shots with under inflatable balls accurate as well as a lot more powerful with balls verging on the edge of too inflated. But again, all these comments have changed the way we look at things and are greatly appreciated!
Unread 15-04-2014, 07:17
Debbie's Avatar
Debbie Debbie is offline
AKA: Debbie May
FRC #1023 (Bedford Express)
Debbie has a reputation beyond reputeDebbie has a reputation beyond reputeDebbie has a reputation beyond reputeDebbie has a reputation beyond reputeDebbie has a reputation beyond reputeDebbie has a reputation beyond reputeDebbie has a reputation beyond reputeDebbie has a reputation beyond reputeDebbie has a reputation beyond reputeDebbie has a reputation beyond reputeDebbie has a reputation beyond repute
You were also on our pick list.
FRC 1023 - Bedford Express - Coach, 2009 - present
FTC 160 - Dana Broncobytes Coach - 2007 - 2009
FLL - Dana Unicorns Coach - 2000 - 2006
Bedford Express Varsity Letter Video BX Facebook
Unread 15-04-2014, 09:19
Mech-Mod Mech-Mod is offline
Mech-Mod will become famous soon enough
I want to thank everyone who answered Sidney honestly. We are not looking to walk away from this post with hurt feeling, just the opposite; we are looking at hearing what stings. Our mentors and students alike, feel that last year we crossed that threshold from been an average team to the start of becoming a good team and it all started with a 5-10 minute conversation with a couple mentors from 33 Killer Bees at MSC last year. Sidney posted this after we had asked ourselves these questions, what did we do wrong? What did we do right? Where does our next 5-10 minute conversation need to come from? We are trying to walk in the footsteps of the great teams ahead of us like Rush, Killer Bees, Wings of Fire, HOT, Truck Town Thunder, R.O.B.O.T.I.C.S., Las Guerrillas, Mech Warriors and Bedford Express just to name a few. We are striving to be like them as both a team that builds a robot and as an organization the builds a community.
