Go to Post Our prototypes are good and running, now just need to do some magic to transform all that wood to aluminum. :eek: - FIRSTMa2104 [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 13-04-2014, 18:08
using interrupts in FRC
I'd like continue a discussion that started in another thread. I made a new thread here as a courtesy to the OP of the original thread who expressed his desire not to discuss the larger issues involved.
Here are the things I'd like to have a discussion about. I'd like to hear from FRC programming gurus.
Scenario1:
A team has code which uses 100ms and 20ms periodic tasks, and they are running low on throughput margin (i.e. CPU usage is too high). They think that they can reduce CPU usage by using interrupts instead of periodic tasks. What say you?
Scenario2:
A team has subsystems that need to respond to sensor data changes within 1ms. Should they: a) use Interrupt Service Routines to control these subsystems, or b) carefully investigate other approaches (such as a hardware limit switch directly connect to a motor controller for example).
Unread 13-04-2014, 18:13
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Re: using interrupts in FRC
The timing of this thread is impeccable. We actually have a situation where we are going to add a sensor, that we think will only be active for 20-24 msecs. I was worried that we need an interrupt to make sure we capture the input condition of the sensor and was asking around so I can advise my software team what to expect. So we have a situation that we want to run some code based on a quick input condition and trigger based on an interrupt is how we would like to trigger a task or loop as well.
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 13-04-2014, 18:55
foote stepped in
AKA: E. Foote
FRC #0868
If I recall correctly the "best practice" was to use the interrupt to set a flag in the timed routine. That way the interrupt took very few clock cycles and the context switching wasn't too bad. Also it minimized the possibility of getting interrupted during an interrupt.
Obviously this wouldn't work if the sensor had to respond to a condition in an amount of time less than the timer cycle. And from experience, debugging any interrupt routine can be a real pain.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 13-04-2014, 19:46
The Doctor's Avatar
The Doctor The Doctor is offline
Robotics is life
AKA: Hackson
FRC #3216 (MRT)
The Doctor is on a distinguished road
Haha... Ether must be an ISR.
Why cant you just thread?:
If you had a timed task that took as long as in scenario 1, you may want to consider making it into a separate thread (using the Task class in C++ or similar). If any task doesn't require much communication with the main control loop, you could put it in a separate Task.
Now, thoughts on Scenario 1:
If you offload these timed actions into ISRs, they would take up as much (or more) CPU time as if they were running in the main process. The main disadvantage to this is if it happens inside a time-critical operation (like sending data to the host), it could cause problems.
Scenario 2:
If the team in question had code that could respond within 1ms, ISRs are a good choice. A hardwired solution would be very difficult to make, debug, and change, compared to an ISR.
Unread 13-04-2014, 21:07
We actually have a situation where we are going to add a sensor, that we think will only be active for 20-24 msecs. I was worried that we need an interrupt to make sure we capture the input condition of the sensor...
What kind of signal does the sensor provide? If it's a digital input, consider using a counter to capture the occurrence. The FPGA will detect the signal as quickly as it can do anything, and the robot code can watch for the counter to change value on whatever schedule is appropriate for responding to the signal.
Unread 13-04-2014, 21:13
Controls Engineer
AKA: chakorules
Digital Input.
Nice suggestion. We will give that a shot on Monday. You might see it work next Saturday...lol....sounds like we are coming to Kokomo on Saturday to the TechnoKats field at 1pm.
Favorite CD quote:
Unread 14-04-2014, 07:15
For 100ms and 20ms loops, I would first profile to see what is taking CPU. I would probably decide to lighten the processing of the 20ms and 100ms loops by removing Smart Dashboard access, refnum by name access, and perhaps some of the scaling and wrappers of WPILib. If using LV, I'd serialize some of the items in the loop to avoid context switches that I really don't need/want. Unless I have tons of these loops, I suspect that would be good enough.
If I'm trying to respond to something in less than 1ms, I'm probably in trouble anyway since the motor controllers only pay attention to their PWM power value every 5 or 10 ms depending on the model. Other actuators seem slow as well, but I don't know the values. The limit switch and other Jag inputs are polled at 1ms by comparison. CAN messages bridged over serial or enet might be fast enough.
Anyway, I'd have to compare the timed loop with very little inside it versus the interrupt.
If I was relatively certain the code wouldn't change, and had the FPGA tools, I'd move the polling into the FPGA. Depending on the complexity of the response, it may be possible to put it in the FPGA too. But again, if the code is going to change, you will shave many times before you complete the project.
Doing the polling in the FPGA, and the response in RT is essentially what FRC interrupts are. If the polling fits the envelope of what is available, it allows high speed monitoring and flexible response for FRC.
Greg McKaskle
Unread 14-04-2014, 08:05
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
We haven't used the interrupt handling abilities of WPILib (C++) on our team -- is there any guidance around as to what works/doesn't work from inside an ISR? For example, I don't remember seeing any special logic in WPILib to allow concurrent access to the actuator or sensor classes.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 14-04-2014, 09:01
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
The period of the tasks is well within the bandwidth of the OS and hardware we use in FRC. The real question is the run time in each period. If we have 3 tasks that run t1, t2, t3 periods and require c1, c2, c3 computation time in each period then you calculate c1/t1+c2/t2+c3/t3 and have some feeling for how much bandwidth is being used. Of course there are other things going on. The OS consumes bandwidth for its clock and scheduler. In FRC robots some bandwidth is used by the task receiving DS messages plus one might have PID callbacks etc. If the sum of all terms for the OS, app and WPI tasks gets anywhere near 1 then you are in trouble (actually lower than 1, see http://en.wikipedia.org/wiki/Rate-monotonic_scheduling).
If the events that generate the interrupts are periodic and you are running the same-ish code to handle the event then you are not saving much time. However if the events are aperiodic using interrupts may save considerable bandwidth. If they use interrupts, the best practice is to quickly 1) determine if your hardware caused the interrupt 2) clear/reset the interrupt cause 3) set a flag, give a semaphore etc to synchronize with code running in a task to react to the event.
1ms interrupts can be handled by the hardware and OS we use in FRC. The interrupt latency of our system is measured in single microseconds. Again the real question is how long does it take to "handle" the interrupt. If the interrupt is periodic or the worst case is nearly periodic you can analyze the effect on the system just as you would a task.
BTW, handling a mechanical limit switch using interrupts is a little tricky if the hardware does not debounce the input. I don't know that our DIO inputs do this.
HTH
Unread 14-04-2014, 13:39
We have used interrupts on the cRIO before in previous years, and my advice is to run away screaming. Most of the times, they work quite well, but occasionally, we would get a full cRIO reboot without any debug information coming back from the cRIO about why. Our programmers very carefully read the docs on what instructions were and weren't allowed in the interrupt, and were handling the interrupt by incrementing a semaphore which would then wake up a high priority task to do the actual work. The code was looked over with a fine tooth comb. Maybe we were still managing to do something wrong, but given the number of matches that it cost us where we either sat dead or were stuck in an infinite reboot loop, we won't be doing it again.
In our case, we were using the interrupts to capture an encoder value when a magnet would pass over a zeroing hall effect. In my opinion, this is a perfect use case for using an interrupt where you want a very fast response time.
Unread 14-04-2014, 14:11
Did you actually care about the encoder value? Or, as the "zeroing" description implies, were you just reading it in order to use as a reference for later readings of the delta? If that's all you were using it for, you wouldn't have needed to do any special programming. The FPGA lets you define a digital input pin as an encoder reset signal.
Unread 14-04-2014, 19:02
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
I tried to use interrupts this year and concur - something is flaky. But it is somewhere in the library or the FPGA. Interrupts are used on FRC robots for the main timer, for the arrival of network data and many other purposes - so they do work. In my case interrupts would fire for a while and then stop firing. The rest of the code continued to run (not crash as in Austin's case) but the limit switch I tied to the interrupt pin just stopped generating interrupts.
There is a list of OS functions (not to call) in the VxWorks Programmer's Guide. Basically do not call anything that only makes sense from a task context (no taking semaphores, no delays, no memory allocation, no formatted I/O, no mutexes, doing anything that might block etc) plus no floating point math (unless you save/restore the floating point context).
In Austin's example my (wild) guess is that the source of the interrupts (occasionally) did not get turned off. If more interrupts occur than the VxWorks can handle its internal queue will overflow (something like a Windoze BSoD).
Unread 14-04-2014, 19:34
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
I used interrupts in the first year that the cRio was used, and didn't have any problems. YMMV though…
I would probably recommend restructuring the code so that everything can run in a single thread. In an FRC context, my opinion is that typically threads cause more trouble than they're worth.
First, I would ask if they *really* need 1ms response time. If possible, I would try to reframe the problem so that the response time isn't required.
I like Alan's suggestion to use a counter, that sounds like a real winner.
As a sidenote, when possible, I connect my limit switches to Jaguars.
Unread 14-04-2014, 19:39
In this case (we were locating discs in our indexer), we really did need the encoder value. That is a handy feature, though. Thanks for sharing!
Unread 14-04-2014, 20:07
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
Yikes - a little conservative maybe?. We have a a world-class real-time multi-tasking OS at our disposal and we don't use it? In years where our students don't "get" the multi-tasking from the start I create templates that prevent them from messing up the timing. WPILib hides synchronization and mutual exclusion pretty well and the messaging API is straight forward. By the end of build season the students always seem to "get it".
