Go to Post it isn't about the technology but about the teams working together. Sneaky GDC has done it again. - dtengineering [more]
Unread 14-04-2014, 11:47
The Doctor's Avatar
The Doctor The Doctor is offline
Robotics is life
AKA: Hackson
FRC #3216 (MRT)
The Doctor is on a distinguished road
What's the biggest fix you've had to do in between matches?
Now that the regionals are coming to an end, I am curious, what are some of the biggest repairs you've undertaken in between matches?
In about 15 minutes:
Our team had to replace a round bar which was responsible for turning the ball intake wheels (after it got bent when 2013 ran into us). Immediately after, we had to replace the spring that powered our launcher, because the old one had become stretched and we couldn't shoot as far.
Unread 14-04-2014, 11:53
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
Re: What's the biggest fix you've had to do in between matches?
This year? Replacing chain, reattaching it, struggling to find an effective tensioner, replacing busted wheels. This has included the meager time between finals matches (at TC).
Yeah, the drivetrain has misbehaved a fair bit.
Unread 14-04-2014, 12:10
Canon reeves Canon reeves is offline
FRC #4490
Canon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud of
technically this is between matches, but we had about 15 minutes to completely switch out our PD board before the pits closed friday night! we also replaced wheel bearings and a belt between practice matches.
Unread 14-04-2014, 12:54
Pratik Kunapuli's Avatar
Pratik Kunapuli Pratik Kunapuli is offline
Probably browning-out on Astro-Turf
FRC #1648 (G3 Robotics)(EWCP)
Pratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to all
Last year we had to replace a fried digital sidecar between qualification matches at the Las Vegas Regional. This year we had to go underneath our robot, un bolt one of the transmissions, drop it out, replace it, and replace a spike in between semi finals at Hatboro-Horsham.
Official Driving Record: 101-59-0
2012-2015 Student 341 Miss Daisy
2015-Current Mentor 1648 G3 Robotics
Unread 14-04-2014, 12:59
Andy A. Andy A. is offline
Getting old
FRC #0095
We had a few issues this season.
The one the sticks out in my mind was when we discovered that the screws attaching two of our CIMS to their transmissions had loosened to the point the motors were sort of flopping about. We, naturally, hadn't added any sort of access to get to those screws and removing the transmissions would have been a nightmare. Certainly not something we could do between matches.
The fix ended up being a liberal application of 5 minute epoxy and holding the motors in place while it set. It worked well enough that we never bothered fixing the fix. Quick and pretty easy fix but probably the one I had the least confidence in actually working.
Unread 14-04-2014, 13:03
deshnik deshnik is offline
AKA: Nikhil
FRC #0781 (Kinetic Knights)
Team Role: Student
deshnik is on a distinguished road
We broke 3 welds on our tower for our catapult after 865 ran into us at Waterloo. We bolted it all together and didn't shoot the next match because we didn't know if it would work. At the end of the day we stripped most of the robot and welded it back together.
Unread 14-04-2014, 13:07
Rstrzelecki Rstrzelecki is offline
FRC #0135 (The Black Knights)
Rstrzelecki is an unknown quantity at this point
So far we have had to change wheel bearings and the winch that powers are catapult twice in about 20 minutes
Unread 14-04-2014, 13:21
tickspe15's Avatar
tickspe15 tickspe15 is offline
Purdue University
AKA: Spencer Tickman
FRC #1747 (Harrison Boiler Robotics)
tickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant future
We have had to replace our drive wheels and pullys three times this season and are due for another set in STL.
We are using a KOP drive train and have been heavily defended at our past four competitions resulting in worn down wheels and even cracked pullys. After lots of practice replacing everything takes an hour if we are lucky.
Team 1318: 2011-2015
Team 1747: 2015-Present
NAR (VEX U): 2015-Present
Unread 14-04-2014, 13:32
akmess01's Avatar
akmess01 akmess01 is offline
FRC #3824 (RoHAWKtics)
akmess01 is an unknown quantity at this point
Two members from our drive team had to replace the 120 A circuit breaker on the robot on the field during the time given for robots to be setup for the match.
Alumni/Mentor:
2016- Carson Division Quarterfinalists, Smoky Mountain Regional Winners, #3 Seed; Palmetto Regoinal Semifinalist, #7 Seed
2015- Tesla Division Finalists; Smoky Mountain Regional Winners, #1 Seed; Palmetto Regional Winners, #1 Seed
2014- Newton Division; Smoky Mountain Quarterfinalists; Palmetto Regional Winners, #1 Seed
2013- Curie Division Quarterfinalists, #10 Seed; Smoky Mountain Regional Winners, #1 Seed; Palmetto Regional Finalists
Student:
2012-Peachtree Semifinalists; Smoky Mountain Semifinalists
2011-Galileo Division; Smoky Mountain Quarterfinalists, Smoky Mountain Rookie All-star
Unread 14-04-2014, 13:43
theCADguy's Avatar
theCADguy theCADguy is offline
Design Team Student Leader
AKA: Sean Gibbons
FRC #0020 (The Rocketeers)
Team Role: CAD
theCADguy has a spectacular aura abouttheCADguy has a spectacular aura about
During finals match 2 at the Tech Valley Regional, we busted a bearing in our drive train. We called a time-out after the match, and we had 7-8 students and mentors on the field frantically attempting to replace the broken bearing. We ran out of time, and we were forced to remove a chain and one of our wheels. However, we used west coast drive this year, and we ended up winning our last finals match with only 5 out of 6 wheels.
JOEL340 JOEL340 is offline
340 Alumni, Mentor for 5030 and 340
FRC #0340 (Greater Rochester Robotics)
JOEL340 will become famous soon enough
At the Finger Lakes Regional we had to fix our main drive shaft that goes into our transmission. It broke during one of our semi final matches and we had only the 6 min field time out before the finals and we got it done. It was probably one of the greatest quick fixes I have ever witnessed.
TEAM 5030
2015-Present Mentor
New York City Regional Champions 2016
TEAM 340
2014-Present Mentor
New York Tech Valley Regional Champions 2015
2010-2013 Student
Buckeye Regional Champions 2012
Chairmans Award 2010, 2011, 2012, 2014
Engineering Inspiration2012, 2014
Unread 14-04-2014, 13:48
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
At Palmetto, our catapult snapped in half. Yea, we had to remake and reattach everything out of raw materials, since we didn't trust the material we used to make the catapult.
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 14-04-2014, 13:52
78Grimey78's Avatar
78Grimey78 78Grimey78 is offline
FRC #0078 (AIR Strike)
78Grimey78 is just really nice78Grimey78 is just really nice78Grimey78 is just really nice78Grimey78 is just really nice
During a time out between finals match 2 and 3 we replaced two gears on our shoulder. We got pushed into the one point goal with the arm out trying to score and stripped gears. The last time we replaced them was during lunch break.
AIR Strike 78, GOOO NAVY!!!
Unread 14-04-2014, 14:25
Marcia Roberts Marcia Roberts is offline
FRC #2478 (Westwood Robotics)
Marcia Roberts will become famous soon enoughMarcia Roberts will become famous soon enough
We had to replace an entire motor during a four match turn around...
Unread 14-04-2014, 14:29
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
We've replaced 1 or 2 octocanum modules after each round of district championships this past weekend due to broken mecanum wheel rollers. Luckily, we have a spare set of modules and a ton of spare rollers, so the work takes less time than the field crew needs to run a match. We replace the broken rollers on the modules we've removed and use them as replacements for the next time around.
--Madison--
...down at the Ozdust!
