Go to Post F.I.R.S.T. Troubleshooting Rule #1 - If you work on software, the problem is always with hardware. If you work with hardware, the problem is always with software ;) - Redneck [more]
Unread 14-04-2014, 14:33
Boe's Avatar
Boe Boe is offline
2175 Alum
AKA: Brian Boehm
Boe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud of
Re: What's the biggest fix you've had to do in between matches?
Full cRIO swap in the semifinals at northstar last year. We sat dead on the field for one match since we didnt finish imaging it before the match, but lucky 967 managed to win the match without us.
2014 IRI-Quarterfinalists (Thanks 368, 1477, 233)
2014 Minnesota State Championship-Winner (Thanks 2052, 4778)
2014 Archimedes Division-Quaterfinalists (Thanks 399, 2056, 2834)
2014 North Star-Semifinalists (Thanks 967, 4607)-Creativity Award-Safety Award
2014 Northern Lights-Winners (Thanks 359, 2502)-Excellence in Engineering-Safety Award
2013 Minne-Mini-Winners (Thanks 2169, 3883, 4239)
2013 MRI-Winners (Thanks 2052, 3130, 3313)
2013 MN State Fair-Winners
2013 IRI-Participant
2013 Minnesota State Championship-Winners (Thanks 2052, 4607)
2013 Galileo Division-Finalists (Thanks 2169, 3284)
2013 North Star Regional-Team Spirit Award-Winners (Thanks 967, 4607)
2013 Northern Lights Regional-Entrepreneurship Award-Quarterfinalists (Thanks 3130, 1675)
2012 North Star Regional-Creativity Award-Quarterfinalists (Thanks 2549, 3130)
2012 Lake Superior Regional-Coopertition Award-Quarterfinalists (Thanks 1625, 2957)
Unread 14-04-2014, 14:39
Caitlinnnnn99's Avatar
Caitlinnnnn99 Caitlinnnnn99 is offline
Why does bag come so soon?
AKA: Caitlin T-HB
FRC #3250 (Kennedy Robotics)
Caitlinnnnn99 will become famous soon enough
We had to replace vex gears in our drivetrain. All the teeth had been stripped off.
Unread 14-04-2014, 14:45
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
In Hub City, we had to cut all of the small bolt ends off our mecum rollers, replace a damaged hinge, a jaguar, and switch bumpers with one match before our next one. I now truly know the definition of chaos.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 14-04-2014, 15:23
MissRaptor's Avatar
MissRaptor MissRaptor is offline
Master CADster
AKA: Melanie
FRC #2052 (KnightKrawler)
MissRaptor is an unknown quantity at this point
At Lake Superior we lost our shooter in Quarter Finals because a hard hit knock off some magnets and messed up how we worked it, Didn't have a good way to get to it at the time and moving everything risked causing issues with our pick up so we opted to let it be. (We were seeded 5th and picked by the 2nd seed, won the thing. Super exciting matches) I think it would have been some sort of anxiety trying to fix it between matches. We got it fixed up at 10,000 lakes properly. There were lots of in between fixes there as well. Various things with the pick up and shooter, however I'm quite glad there were issues at the regional because we have them not only fixed but also managed to improve them as well (We won 10k Lakes as well. Also very fun regional)
Madly in love with FIRST everywhere
2014 Lake Superior Regional Winner
2014 10,000 Lakes Regional Winner
2014 MNSHL Championship Winner
Unread 14-04-2014, 15:27
Oblarg Oblarg is offline
AKA: Eli Barnett
So, this wasn't in-between matches (too big to possibly fix in that span of time), but it's one of the biggest mechanical failures I've ever dealt with in FRC.
Originally, our roller arm was driven by two PG188 gearmotors.
During match 4 of Greater DC, our roller arm took a significant hit while it was lowering, shearing both of the output shafts clean in half.
Due in part to lacking the requisite number of replacement parts, and in part to not wanting to repeat the failure, we decided to switch to a pneumatically-actuated arm. This entailed completely redesigning the arm's attachment to the frame, improvising connection points for the pneumatic cylinders, and significantly expanding our pneumatic system.
It took all of our pit time for the rest of qualifications to finish.
"The breakfast of champions!"
Unread 14-04-2014, 15:33
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
In 2012 at Duel on the Delaware, our shooter and turret fell off (about 20lbs worth of robot) between eliminations matches. The lazy susan bearing literally snapped. However, all the zipties in our and 341's pit managed to reattach the turret enough to work for auton, and we wound up winning with our amazing partners, 341. That was an interesting day.
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
Unread 14-04-2014, 15:40
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
This year... replacing a #25 master link. That's the only actual repair the team has had to do all season! This certainly is different from year's past... last time we made it to champs, it seemed like we were swapping out motors every single match due to a design that burned them out!
2016: Lake Superior WFFA
Unread 14-04-2014, 15:44
JeremyLansing's Avatar
JeremyLansing JeremyLansing is offline
Team 967 Alumni
FRC #0171 (Cheese Curd Herd)
JeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud of
This year at Wisconsin we had a drivetrain issue in our last match before lunch. When we tried to drive forward power to one side of the drivetrain would only be applied intermittently. Since I thought it was a control issue I offered to stay in the pits and try to find it while everyone else got lunch. After I powered up the robot, I realized it was actually a gearbox issue. Myself and another mentor took apart the entire left side of our drivetrain and found that nobody had greased the gears, so during a pushing match, the already worn teeth had stripped off about 3/4 of the gear. Luckily we had some steel gears with us and were able to replace them and got them greased, the other side had been greased but we changed them out for steel and regreased any way.
Once some students got back we finished and reassembled the drive, but we basically did a complete rebuild of our drivetrain over lunch. Now people seem to think that aluminum gears are too weak for FRC, even though these held up for 1 1/2 regionals with NO GREASE. I am quite impressed they managed to hold up that long, and I am quite certain that aluminum gears, if grease properly are more than sufficient for FRC. I only wish I had a photo of all the shavings we dumped out of that Toughbox, it was quite hilarious.
2015 Midwest Regional Finalists (Thanks to 2338 and 1756)
2014 Central Illinois Regional Finalists (Thanks to 4143 and 2039)
2013 Curie Division Semifinalists (Thanks to 2056 and 3990)
2013 North Star Regional Champions (Thanks to 2175 and 4607)
2011 10,000 Lakes Regional Champions (Thanks to 525 and 3642)
JCharlton's Avatar
JCharlton JCharlton is offline
AKA: JC
JCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to behold
After our first match Friday morning the robot inspectors deemed our ground clearance too low, we were causing damage to the field. While I drove across town to find some larger omni wheels back at the school the team took apart our four drives and enlarged the openings in our Octobase. Didn't quite finish before our next match, had to skip one, but it was a great show of skill and tenacity from our pit crew to do it so quickly.
"There is no problem so bad that you can’t make it worse." - via Chris Hadfield
Unread 14-04-2014, 15:47
Joining the 900 Meme Team
FRC #0079
Originally Posted by 78Grimey78 View Post
During a time out between finals match 2 and 3 we replaced two gears on our shoulder. We got pushed into the one point goal with the arm out trying to score and stripped gears. The last time we replaced them was during lunch break.
Possibly one of the top 5 most impressive repair jobs I've seen in FRC.
Unread 14-04-2014, 16:05
Brandon Holley's Avatar
Agreed. Done on the field, in 6 minutes, including the removal of a pot that indicated arm angle. Pot was removed/restored without losing presets.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 14-04-2014, 16:11
FRC #0079
-Brando
Presets were adjusted. While you and Joe were setting the bot up their STUDENT programmer came out and fixed them. Color me impressed.
Unread 14-04-2014, 16:16
bbradf44's Avatar
bbradf44 bbradf44 is offline
AKA: Brad
FRC #3344 (Robocopz)
Team Role: Driver
bbradf44 is just really nicebbradf44 is just really nicebbradf44 is just really nicebbradf44 is just really nice
There wasn't a time where people weren't in our pit trying to fix something this year at peachtree. Not our best year
2011: FRC 1922 Team Member
2012 (Build weeks 1-3): FRC 1922 Team Member
2012 (Weeks 4-Competition): FRC 3344 Mechanic and Pit Crew
2013: FRC 3344 Mechanical Lead and Head Driver
2014: FRC 3344 Team Captain and Head Driver
Record as driver: 7-11-0 and Proud of it
Unread 14-04-2014, 16:28
2004 Great Lakes Regional would probably count, if it hadn't happened at the end of what turned out to be the TechnoKats' final match.
http://www.chiefdelphi.com/media/photos/16516
The "Year of Fried Sidecars" at 2011 Boilermaker gets my vote, but that's mostly because replacing the Digital Sidecar on that robot 1) involved removing and replacing a lot of wires with almost no room underneath a bizarre assembly of chains and sprockets, and 2) had to be done several times during the weekend.
Unread 14-04-2014, 16:42
Jarren Harkema's Avatar
Jarren Harkema Jarren Harkema is offline
Dancing Drive Coach
FRC #4967 (That ONE Team)
Jarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to all
We had the exact same issue with our last match before lunch at MSC, the robot behaved exactly as yours did. Upon opening up the gear box we were treated with a giant pile of aluminum dust. We are so thankful for all of the teams who donated replacement gears to get us back up and running in time for the next match!
