Go to Post If we can figure out how to make a robot in six weeks, a little thing like personality conflict should be easy to overcome. - Al Skierkiewicz [more]
Unread 14-04-2014, 18:13
Oblarg Oblarg is offline
AKA: Eli Barnett
pic: Offseason Drive Idea
Unread 14-04-2014, 18:15
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Re: pic: Offseason Drive Idea
How does this improve the serviceability of the drivetrain over a WCD, given that you need to remove the output shaft of the gearbox in both setups?
-Plutarch
Unread 14-04-2014, 18:18
AKA: Eli Barnett
In this setup, you don't need to remove the output shaft of the gearbox at all; the center wheel shaft pulls right out after loosening a single shaft collar. It's coupled to the output shaft of the gearbox with a hex sleeve.
Another nice feature is that to pull the gearbox, one only needs to slide it about an inch in after removing the bolts, as opposed to the full length of a WCD-style output shaft.
"The breakfast of champions!"
Unread 14-04-2014, 18:22
Henrique Schmit's Avatar
Henrique Schmit Henrique Schmit is offline
FRC #1156 (Under Control)
Team Role: CAD
Henrique Schmit is an unknown quantity at this point
I think this is a great idea, it saves a lot of space for the electronics, but i think you should consider that this makes you CoG higher, increasing the change of your robot tripping. Also the cims are way more exposed out there, and you should consider that. The cables coming out of the cims will also be out there, you should check if they wont leave the frame perimeter or get bent too much. Where they are right now unfortunate accidents could happen, even if the chance of someone messing up your wiring out there is low you shoud be very carfeful with that, some teams tend to have the worst luck during the regionals. At NYC this year our main braker was exposed and a team managed to accidentally hit it in a way that it turned our robot off, so i suggest making a case for the cims and the wires if you keep that design.
Unread 14-04-2014, 18:24
cxcad cxcad is offline
FRC #1683 (Techno Titans)
cxcad will become famous soon enoughcxcad will become famous soon enough
If you are really concerned about packaging, I would get rid of the 2x1's on the outside of wheel well and replace it with .25 in plate, or get rid of it (WCD axle's are cantilevered; outside support not necessary.)
Unread 14-04-2014, 18:25
AKA: Eli Barnett
These aren't WCD axles, they're dead axles (except for the center, which is a live hex axle coupled rotationally to the gearbox output shaft).
Unread 14-04-2014, 18:52
I don't know about dead axles but with live axles you can replace the box tubing on the sides with plate tubing. I'll try to find a photo of it if you wish to see.
Unread 14-04-2014, 19:23
JoeyL JoeyL is offline
FRC #4069
JoeyL is an unknown quantity at this point
My team had a similar idea for the gearboxes this year, putting 3 CIMs on the outside of the drivebase.
Here's a few shots of the gearbox: https://drive.google.com/folderview?...&usp=sha ring
In our experience, it works quite well for keeping the COG low and keeping the weight on the outside. The gearbox and CIMs are also very accessible. There's quite a bit of force on the inner gearbox plates though (the entire gearbox is essentially resting on them), just something to bear in mind.
Here's what our robot looked like at the end of the season: http://www.chiefdelphi.com/media/photos/40089
Texas Torque did a similar gearbox last year, too. They used WCD. You can see a shot at 53s. http://youtu.be/dSjHFgbcJZc
Unread 14-04-2014, 19:52
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
It is a good start. Here are a few questions though:
Why not get rid of the unnecessary metal on the inner gearbox plates? Leave some meat around the upper bearing and the get rid of the rest.
Why did you place the pulleys on the outside of the wheels? For turning, stability, and other purposes it would be better to get the wheels out the extra ~1" on both sides.
Is your center pulley wide enough to fit 2 belts side-by-side? All the pulleys appear to be the same size.
CG does seem high, but depending on the game this may not matter. If you need essentially no ground clearance (this year), you can have your battery sit about a 1/2" off the ground. [Legally] Max your bumpers out to 20lbs and place them as low as legally allowed.
How are you bolting the chassis and it's components without collapsing the tube? It is not typically a problem with 1/8" walls, but every now and again you will have someone not paying attention and keep cranking on the bolt because they can still turn it.
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
Unread 14-04-2014, 22:33
AKA: Eli Barnett
I fully intend to do this; this is just a rough draft I banged out in an hour or two. The extent of the gearbox plate design was essentially copy-pasting projected geometry from a WCP 3CIM dog shifter and a WCP 3CIM single-speed into a single sketch and then toying with it until the center-to-center on the gears was correct, and adjusting the outline.
Good point, I'll change that.
The center pulley can fit two 9mm belts side-by-side. The outer pulleys would be narrower on the actual thing, but to save time while doing this (again, rough draft) I just copy-pasted the center wheel assembly.
My general solution to this is either a) hover over the students while they assemble it and remind them or b) make wood inserts. I prefer a), since b) adds weight and is a pain. It is 1/8'' wall + gusset plate thickness, though, and I'm pretty sure I saw someone shear a 1/4-20 bolt head off at 449 putting a similarly-constructed thing together without crunching the assembly.
All good points. I did make sure to leave myself a fair bit of breathing room so that I can keep the wires inside the frame perimeter - I find securing them to the body of the motors with zipties works wonders. I'm not so worried about high CG with this given the low clearance of the chassis above the ground.
Unread 14-04-2014, 22:37
rivets?
Unread 14-04-2014, 22:44
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
While I agree with you in principle, I don't think it's a particularly high concern here-- the weight isn't much higher than it would be with 6" wheels (or for that matter, 8" wheels). There are plenty of gearboxes (including the pre-2014 channel kitbot) which used gearboxes that were on the whole significantly higher up (being above the rail), and I don't think any teams had issues from that. Overall it's the other ~70 lbs and batter that you put on it that makes the real difference.
Eli, nice design. I hope you post a more finished version when you've cleaned up the CAD and models. Maybe even a pretty render for us?
I hope to see something similar coming out of your team for competition in the future.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 14-04-2014, 22:45
tim-tim's Avatar
AKA: Tim Miedzinski
rivets?
We used 3/16" aluminum rivers with steel mandrels to hold our chassis together this year - I don't think we're ever going back. They are simple and lightweight.
Another option is Rivet nuts (riv-nuts). They are exactly what they sound like. You can get them from McMaster (94020A335) and other places.
The RoboBees
Unread 14-04-2014, 22:55
Woolly's Avatar
Woolly Woolly is offline
Programming Mentor
AKA: Dillon Woollums
FRC #1806 (S.W.A.T.)
Woolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond repute
If COG is a concern, you could do an 8 wheel drive and rotate the gearbox 90 degrees provided you move the belts to the inside of the drive rail, and design the mounting plate of the gearbox as a frame element.
Team 1806 Student: 2012-2013 | Mentor: 2013-Present
Unread 15-04-2014, 00:47
AKA: Eli Barnett
I'm really not all that concerned about CG; the highest point of this whole assembly is ~10'' off the ground.
Re: Pulley sizes, after toying around a bit I'm pretty sure I'm going to keep them all the same size, for ease of replacement. Making the outer pulleys smaller involves either greatly complicating the wheel spacer arrangement (which is very simple right now) or having the wheels out-of-line, and moreover requires that you keep more backups.
