Go to Post Imagination is important, but try not to use it as a substitute for actual information. - Alan Anderson [more]
Unread 21-02-2003, 18:31
Joe P Joe P is offline
Joe P will become famous soon enoughJoe P will become famous soon enough
Drill gearbox clutch
Any suggestions on how to lock the clutch on this year's drill motor gearbox?
Unread 21-02-2003, 19:12
Patrick Wang Patrick Wang is offline
#0115 (MVRT Alumni)
Patrick Wang has a spectacular aura aboutPatrick Wang has a spectacular aura about
Send a message via AIM to Patrick Wang
Why?
We've never had to lock the clutch, once you set it into Drill Mode, it's very hard to knock is out from normal operation.
We went through all of last year's bashing and the clutch never gave us a problem.
I don't think you'll need to worry about it
Patrick Wang
WRRF
Unread 22-02-2003, 09:00
DougHogg DougHogg is offline
Robot-A-Holic
FRC #0980 (The ThunderBots)
DougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud of
There is another thread on this subject.
We are using a premium cable tie (ie cable ties with metal teeth from Home Depot or McMaster Carr) to lock our drill motor in gear.
FIRST Team 980, The ThunderBots
2002: S. California Rookie All Stars
2004: S. California: Regional Champion,
Championship Event: Galileo 2nd seed,
IRI: Competition Winner, Cal Games: Competition Winner
2005: Arizona: 1st seed
Silicon Valley: Regional Champion (Thanks Teams 254 and 22)
S. California: Regional Runners Up (Thanks Teams 22 and 968)
Unread 12-03-2003, 13:22
the doors's Avatar
the doors the doors is offline
#0234 (CyberBlue)
the doors is an unknown quantity at this point
Send a message via AIM to the doors
There is also a method of locking the drill tranny into high gear by machining a steel (or HDPE) ring that fits inside of the transmission itself. If machining capabilities are available, this can prove to be a very effective method.
"Automatic Transmission" Madison Technical Discussion 70 24-11-2003 09:03
Disabling drill transmission clutch Charlie B Motors 2 31-01-2003 10:02
drill gearbox schematic? Jeff Sharpe Technical Discussion 3 21-01-2003 00:18
Locking the drill motor clutch? Rick Gibbs Motors 1 06-01-2003 09:46
Specs for drill motor gearbox? archiver 2000 4 23-06-2002 22:36
