Go to Post I guess this is where theory vs reality comes into play. - PhilBot [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 15-04-2014, 07:40
Re: using interrupts in FRC
In '08, for the introduction of the cRIO, some AEs built an ambitious robot named NItro. It had three omni wheels with encoders and they decided to use NI Soft Motion and interrupts to calculate the Jacobian for the motor control values for path planning.
I came on late to help them finish the project and found that they weren't acknowledging the interrupts but were still running fine. I also found that they were running over 15k interrupt handlers per second, but again, running fine. At the booth, they ran the robot all day long in its wooden pen going through battery after battery.
This was with LV, so I cannot comment on the C++ handlers, and this was before the FRC FPGA was complete, so it is not apples to apples.
Anyway, interrupts are in the product and should work. If you have issues, please provide details so that we can improve them or their documentation.
Greg McKaskle
Unread 15-04-2014, 09:25
Hugh Meyer's Avatar
Hugh Meyer Hugh Meyer is offline
FRC #1741 (Red Alert Robotics)
Hugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud of
Originally Posted by Alan Anderson View Post
.....you wouldn't have needed to do any special programming. The FPGA lets you define a digital input pin as an encoder reset signal.
Alan,
Would you provide more information about how to do this? Links to docs would be great. C++
Thanks.
-Hugh
Unread 15-04-2014, 10:59
It's obvious and straightforward in LabVIEW. The External Reset input terminal, and its associated polarity select, are at the top of the Encoder Open function icon.
In Java, some of the Encoder constructors accept a third Digital Input to specify the index signal.
In C++, it looks like the reset/index feature is not exposed in the Encoder class. That's unfortunate. I don't know enough about the low-level resource interface to the FPGA to be comfortable trying to suggest adding a new constructor that includes it.
Unread 15-04-2014, 11:12
Is this edge triggered or will it clamp to 0 whenever the input is active? The former seems better as you can travel over the sensor and be fine (so long as you don't go past the sensor. )
Unread 15-04-2014, 11:24
The LabVIEW help suggests that the External Reset is level sensitive, meaning it should continuously zero the encoder value as long as it is active. I can't verify that with complete certainty using the documentation I have access to.
Unread 15-04-2014, 11:49
Hugh Meyer's Avatar
Alan – Thanks for pointing out this feature. We were attempting to use an index pulse in C++ this past season but could not find how to reset the encoder count with an index pulse. We didn’t think to look in Java and Labview.
Hey Greg, how about exposing the index function in C++ for us C++ users?
-Hugh
