Go to Post FIRST is not all about the competitions. FIRST is about what you learn to get to wherever you got to, whether that be first seed or last. - StephLee [more]
Unread 13-04-2014, 23:00
Tool for searching for matches affected by short autonomous glitch
Based on several earlier reports and the replays of QF1-1 at the Michigan State Championship, I decided to create a tool that will measure the length of autonomous in matches connected to FMS. It will search through all logs in a specified directory (it defaults to the default directory for logs on Windows 7 C:\Users\Public\Documents\FRC\Log Files). It will determine which ones were FMS connected and then display the length of the Autonomous as commanded by the field.
For example, on a clean match it will display:
2014_04_05 14_38_16 Sat.dslog: 10.14
On a match that was affected by the glitch, it will display two outputs for the same log file:
2014_04_05 13_13_05 Sat.dslog: 1.50
2014_04_05 13_13_05 Sat.dslog: 8.28
To start, run the exe, select the path of your log files (if necessary), and press the start button. The output box will update as it scans through the matches. The tool requires both the .dslog and .dsevents files.
If you find a match that was affected, please post your log.
It is a LabVIEW program, and should be runnable by any computer that has the Driver Station installed (a full LabVIEW installation should not be necessary, but has not been tested).
Unread 13-04-2014, 23:37
tStano tStano is offline
AKA: Sparks
Team Role: Electrical
tStano will become famous soon enough
Re: Tool for searching for matches affected by short autonomous glitch
This comes from the match in Milwaukee (Week 4) where we rammed our alliance partner.
Unread 14-04-2014, 12:20
This log doesn't look like it comes from a match. It doesn't show any autonomous period at all.
Unread 14-04-2014, 12:28
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
I'll ping him about it, we definitely found one, but he may have attached the wrong file.
Unread 14-04-2014, 23:41
AKA: Sparks
This log is definitely the only one the tool spits out as bad. If it isn't an actual match, we don't have a bad log to submit. Do you need the dsevents file as well? Sorry I'm so bad at this.
Unread 15-04-2014, 00:04
Sure. Thanks.
Unread 15-04-2014, 10:18
AKA: Sparks
Both the files are in this folder now. Hope it works this time.
Unread 15-04-2014, 10:39
Yes it did. The log file does show the issue.
I didn't realize that the .dsevents file was required for the log viewer to function properly.
Unread 29-04-2014, 18:27
rrossbach rrossbach is offline
AKA: Ron R
FRC #2607 (RoboVikings)
rrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to behold
Out of curiosity, has there been any word on the root cause determination and elimination?
FIRST Mid-Atlantic Volunteer
FRC Team #2607 Mentor
Unread 02-05-2014, 14:34
I didn't hear anything, although I did hear that it affected such a tiny percentage of matches that the fact it happened twice in a row in Michigan was amazing.
