Go to Post To put it simply, its clearly become this. The teams that can score a lot, do well. Rather shocking, isn't it? It doesn't matter if you're a shooter, dumper, power dumper, gravity dumper, spitter, flinger, dunker, shumper, barfer, dropper, or whatchamacallit. Points are points. - Looking Forward [more]
Unread 13-04-2014, 16:43
kklokreach kklokreach is offline
kklokreach is an unknown quantity at this point
Help with Gear Ratio Calculations
Hello everyone, sorry I know this is a very rookie question but I've searched everywhere and can not find the answer. How exactly do you calculate the gear ratio for a gearbox by hand?? I understand that it is Input gear/Output gear but I don't understand which constants to use and what to do when converting because when I do the math I get FPS and Torque output to be in the thousands.
Thanks in advance!
Nick
Unread 13-04-2014, 17:27
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Help with Gear Ratio Calculations
Can you show us your work so we can try to spot the error?
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Now are you wanting to do it by hand? Because there are gearbox calculators out there for FRC applications that I would be happy to get you a link.
Unread 13-04-2014, 17:33
Rauhul Varma Rauhul Varma is offline
Drivetrain and Design Lead
FRC #0192 (GRT)
Rauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud of
The gear ratio of a gearbox is usually expressed in turns of the input to turns of the output. To find this you divide the number of teeth on the bull gear (the gear on the output side) by the number of teeth on the pinion gear (the gear on the input side). For each additional stage you multiply the ratios of each stage together. So if your first stage was 12:48 (input : output) and the second stage was 20:40, your overall gear ratio would be (48/12)*(40/20):1 which is equal to 8:1.
For gears in series like this:
You only need to use the number of teeth on the first gear and the number on the last gear as the intermediary gear(s) do(es) not affect the ratio. For example if the above picture was a 12 tooth gear connected to a 40 tooth gear connected to a 72 tooth gear the ratio would be (72/12) = 6:1 which is the same as if you calculated each pair's ratios and multiplied them together; (40/12)*(72/40) = 6:1
First lets define some variables:
tau(i) = your motors' stall torque
tau(o) = your gearbox's max torque output
omega(i) = your motor's free speed (unloaded rpm)
omega(o) = your gearbox's max rpm output
r = you gearbox's overall gear ratio
R = your wheel radius (in feet)
v(o) = your robot's maximum translational velocity
To get the maximum torque the gearbox will output you simply multiply your motor's stall torque by the gearbox's gear ratio:
tau(o) = tau(i) * r
To get your robot's maximum speed you first need your max rpm which is:
omega(o) = omega(i) * (1/r)
Then to get the max speed you need to convert the rpm (angular velocity) to translational velocity, which is:
v(o) = omega(o)*(2piR)/60
(note you're robot will never be traveling at that speed as you will have energy loss due to friction and other sources and your motors will always have some amount of load on them as well which will make them rotate more slowly than they do at their free speed)
The simplest way to do all of these calculations would be to just use a premade excel spread sheet like JVN’s design calculator which can be found here:
http://www.chiefdelphi.com/media/papers/2755
Unread 14-04-2014, 14:55
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
More shameless self-promotion!!
http://www.chiefdelphi.com/forums/sh...d.php?t=128531
I made this handy motor / gearbox reference sheet that has most of the equations you need for gearbox calculations.
If you want more specific numbers (factoring in things like ideal voltage vs. actual voltage, COF, etc.) you will need to find some of the other reference sheets here on CD. If that is what you are after trying searching for "Motor Data" or "MCALC". If you can't find the right thing, I can probably link them for you.
Unread 15-04-2014, 19:03
Thanks this helps a lot, i finally got the numbers to come out right. Though now I have another question, how does the number of motors affect the speed and torque of the drivetrain? Of course this means more torque and speed due to an extra motor, but how does this translate to the fps and torque mathematically?
-Nick
Unread 15-04-2014, 19:21
Tyler2517's Avatar
Tyler2517 Tyler2517 is offline
ShortOnes
AKA: Tyler Gibb
FRC #2517 (Evergreen Robotics)
Tyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura about
I don't think adding a motor directly increases your speed. It does increase acceleration as you are adding more power but the max rpm of your drive will not be increased. It does add pushing power but in most frc scenarios drive trains are traction limited and not limited by the motors but the do help. Most teams use the extra acceleration to reach higher speeds. Correct me if i am wrong.
Unread 15-04-2014, 19:29
Andrew Lawrence
Posts: n/a
-Nick
You can add as many motors as you want* and your final speed isn't going to change. Motors increase torque, but not output velocity (if you have one motor at a thousand rpm, and you add another motor at a thousand rpm, the first motor isn't suddenly going two thousand rpm). Torque is calculated linearly. Double the amount of motors, double the amount of torque.
*This is assuming all motors have the same or similar output speeds. Of course adding a motor that's twice as fast as the original motor is going to speed things up a bit, but that's a situation you should rarely come across in FRC. CIMs and Mini CIMs, for example, are about the same speed.
Unread 17-04-2014, 20:28
Oh ok, so if you add M amount of cim motors then your torque increases by xM? Like having two CIMs means double the amount of torque and three CIMs triples the amount of torque?
-Nick
Unread 17-04-2014, 21:04
DonRotolo's Avatar
Back to humble
FRC #0832
-Nick
Yes, almost exactly.
In the real world, additional loss due to friction is a consequence of additional motors, but compared to the motor output it is very small and can safely be ignored in most cases.
Unread 18-04-2014, 00:02
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
the on line calculators are great - but it is good to take some time to do some hand calculations so you understand what is happening in the gearing system. after you understand, then the calculator tools are great for making faster decisions and playing "what if'.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 06-05-2014, 00:46
highlander's Avatar
highlander highlander is offline
Registered Boss
Team Role: Student
highlander has a spectacular aura abouthighlander has a spectacular aura abouthighlander has a spectacular aura about
Can't agree more.
