Go to Post FIRST inspired me to become a pain in the patootie or something. :) - Madison [more]
Unread 15-04-2014, 22:53
Rauhul Varma Rauhul Varma is offline
Drivetrain and Design Lead
FRC #0192 (GRT)
Rauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud of
pic: Team 192's Engineering Excellence Awards
Unread 15-04-2014, 22:54
Botwoon's Avatar
Botwoon Botwoon is offline
A.K.A. Matthew Ruane
FRC #0207 (Metalcrafters)
Botwoon will become famous soon enough
Re: pic: Team 192's Engineering Excellence Awards
I see that the belts from the motors were swapped top-to-bottom and a tensioner added. Did your team find problems with the bridged belt slipping? Excellent work, by the way.
Unread 16-04-2014, 00:18
FRC #0192 (GRT)
The bridged belt itself was sound, however when I was calculating the belt path in Inventor I accidentally referenced the wrong dimension and ended up with a path 4mm too short. This resulted in the serpentine belt slipping over the output pulley under high torque.
A shorter belt to fit wasn't an option but I was able to use an existing bolt to create an idler with R4a bearings. I swapped the belts to reduce the distance the idler (and the pulleys) would be cantilevered.
Thanks!
