Go to Post Another year, another picture of a Tytus injury. - Andy Baker [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 17-04-2014, 11:27
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: [FRC Blog] Orlando Incident
Originally Posted by Jon Stratis View Post
How is that not well defined? ANY change to the robot, except those expressly permitted per T8, requires a reinspection. The problem is teams simply don't follow this rule. ...snip..
And yes, reinspections should include replacing tread on wheels - that is the main part of the robot that interacts with the carpet, ...snip...
These reinspections are not cursory, they are not lighter or less rigorous than the initial inspection. The only difference is the scope - we don't have to worry about the entire robot any more, just the small area where the change was made.
What is not well defined is exactly what is an "re-inspection" & how it gets documented. T8 speaks to modification not repairs. Just when a repair becomes a modification is a judgement call not all defined by the rules. If you expect robots to be reinspected after every repair, then the process is fundamentally flawed & you can't fault teams for not following it a 100%. You are also going to need a lot more inspectors. The other Frank says the process is going to get some attention. I am expecting positive changes.
Removing a mechanism present during the original inspection does not trigger a need for re inspection per T8. Adding the ballast to compensate would require reinspection. As a side note reinstalling the mechanism if the ballast + mechanism exceeded the allowed robot weight would probably be against the rules.
