Go to Post We need to find the female engineering mentors in FIRST and start having them present/co-present technical conferences at the championships. We need to start showing the girls on the teams that there are female engineering "rock stars" to look up to. - Kims Robot [more]
Unread 18-04-2014, 13:25
bbradf44's Avatar
bbradf44 bbradf44 is offline
AKA: Brad
FRC #3344 (Robocopz)
Team Role: Driver
bbradf44 is just really nicebbradf44 is just really nicebbradf44 is just really nicebbradf44 is just really nice
Re: Swerve drives
Heres a couple images of our inventor creation. Its still missing the gears, chain, axles, and belts but this is the basic design. This is only a rough and dirty concept. Below the piece of wood is the lazy suzan bearing. about 1/2 inch above the wood is a sprocket for the turning
2011: FRC 1922 Team Member
2012 (Build weeks 1-3): FRC 1922 Team Member
2012 (Weeks 4-Competition): FRC 3344 Mechanic and Pit Crew
2013: FRC 3344 Mechanical Lead and Head Driver
2014: FRC 3344 Team Captain and Head Driver
Record as driver: 7-11-0 and Proud of it
Unread 18-04-2014, 14:11
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
Re: Swerve drives
Originally Posted by Gdeaver View Post
I like the 6127's. We did have problems losing calibration. We used plastic beam couplers from Automation Direct. They would some times slip requiring calibration. This year we took advantage of the good AL beam couplers that were on First Choice and they do not slip.
Ours were really easy to set up compared to the USD encoders we were using. We thankfully decided to get the fattened shaft version. This means that the setscrew we use to pin them down will not slip, and we don't have to find the junction between 0v and 5v on each one individually. We know that when the flat of the shaft is facing towards the BI symbol of the encoder, it is at "zero". We then mount them to the drive so that when the encoder is at zero the set screw is accessible. We then turn the module to a 45 degree angle,(witch is where we used to put the index) and slide on the plastic encoder gear.
We haven't done extensive testing, but the process seams promising.
PS. How do you interface with the output pins on the 6127's? We just solder PWM cables to them.
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
Unread 18-04-2014, 19:13
ekapalka's Avatar
ekapalka ekapalka is offline
FRC #3216
ekapalka has a spectacular aura aboutekapalka has a spectacular aura about
Re: Swerve drives
I'm not sure if this is true or not, but I've been told that a good thing to use for swerve drives are ten-turn potentiometers. The benefit being that you can easily plug it into the following
angle=(potentiometer_voltage-inherent_zero)*voltage_to_degrees
to get to the angle, whereas with other potentiometers you need to account for some sort of wraparound
Unread 19-04-2014, 12:41
Orion.DeYoe Orion.DeYoe is offline
FRC #5413 (Stellar Robotics)
Orion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to behold
Re: Swerve drives
Swerve is something I've wanted to build in the offseason for a while. I understand the mechanical and control concept of it and I know how it's driven and mostly how the modules need to be constructed.
The point that I have a really hard time understanding is how the pivot is set up. Does it just ride metal on metal? Or is there some sort of bearings, rollers, or slip pads/blocks? How do you contain the rotating module (the yoke) up and down and side-to-side while still being able to disassemble it? No one seems to have any good cross section views of the modules in an assembled state.
Unread 19-04-2014, 13:44
Tyler2517's Avatar
Tyler2517 Tyler2517 is offline
ShortOnes
AKA: Tyler Gibb
FRC #2517 (Evergreen Robotics)
Tyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura about
Re: Swerve drives
We use thrust bearings in the top of the yoke so that it can carry weight but still rotate freely.
What do you mean by contain the rotating module? We have a retaining ring at the top of the pivot shaft that keeps it from falling out the bottom. The sides of our yoke have 3 bolts that have threads on the top of the yoke to connect. On ours at least it takes about 2 hours to get every thing to go together, to take it apart it can take up to 6 after a little use(with the help of a hammer). Our pivot shaft is thermal press fit in to the top of the yoke. We can not get it out even if we wanted to.
Unread 19-04-2014, 14:42
The Doctor's Avatar
The Doctor The Doctor is offline
Robotics is life
AKA: Hackson
FRC #3216 (MRT)
The Doctor is on a distinguished road
Re: Swerve drives
Team PWNage was using a $60 Absolute value encoder to figure out the angle.
Unread 19-04-2014, 15:27
Jefferson Jefferson is offline
AKA: Jeff Clements
FRC #0016 (Bomb Squad)
Jefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond repute
Re: Swerve drives
If you are using the WPILib PIDController, it's as simple as setting the PIDController to continuous when using a continuous rotation encoder/potentiometer.
You have to keep up with turns and unwind if you get close to the limit on a 10 turn pot.
Unread 19-04-2014, 15:38
ekapalka's Avatar
FRC #3216
Re: Swerve drives
Believe it or not, our team (your team) is quite familiar with those. We have them on more than one of our older robots.
Unread 19-04-2014, 16:39
mman1506's Avatar
mman1506 mman1506 is offline
Hater of Tiny Molex Connectors
AKA: Marcus Quintilian
no team (WARP7)
Re: Swerve drives
Any tips for preventing the tiny wire on the connectors breaking?
2016: FRC 865 Mentor
Unread 19-04-2014, 17:26
ekapalka's Avatar
FRC #3216
Re: Swerve drives
We connected ours by simply removing one wire (and 1/4 of the connector itself) from one of the 4 wire connectors that we had acquired for our OEM encoders (because we bought the 3 pin analogue versions). We've never had any problems with this setup, but we probably would have been better off with one designed for this task. We also cut the top off of a Mountain Dew bottle and used it to shield the sensor because it was located a bit precariously
